Bikesdirect Mini Velo upgrade thread
#51
Here's some pics of mine with parts bin updates: Cinelli bar and stem, seat from a
Fuji Team Carbon, 54T chainring, clipless mountain bike pedals. Schwalbe 20x1.1 Durano's on the way.
Likes For 762x54:
#52
All ur bike r belong Enki
Some single-speed goodness was just delivered:
170 grams for all you see here.
#53
Check-out this pedal and strap combo deal over at Fyxation. Colors to match both black and orange Nanos.
https://www.fyxation.com/shop/product.php?id_product=87
#55
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 10 Times
That is cool, where did you get all the parts from?
Speed Uno
Dawes Kingpin 2speed
Speed Uno
#56
Surly 15T single-speed cog:
https://www.universalcycles.com/shopp...ls.php?id=9745
Gussett Squire chain tensioner:
https://www.universalcycles.com/shopp...s.php?id=30651
Fibonacci spacer kit:
https://endlessbikes.com/index.php?pr...20Spacer%20Kit
54T Origin 8 (Rocket Ring) flat chainring:
https://www.niagaracycle.com/product_...ducts_id=31445
KMC 3/32 half link:
https://www.universalcycles.com/shopp...s.php?id=23022
I also got some single-stack aluminum chainring bolts, but had to ditch them for the stock steel ones because they mushroomed once I torqued them down. Luckily, the stock chainring bolts are the perfect length to accommodate the single chainring. I re-used the stock chain and just cut it down and added a half-link to get the length right.
Other notes:
-There was enough clearance with the chainstay for me to be able to mount the 54T chainring on the inside crank spider. This gave me a 43mm front chainline.
-The stock chainrings are heavy...appear to be made of stamped steel.
-The bike feels like it went on a diet.
-The drivetrain is smooth as glass.
KMC 3/32 half link:
Other notes:
#57
Looks like a 67 inch gear which should be quite comfortable. Any chance you could ditch that chain tensioner? How much does the bike weigh after modification?
#58
It might be possible with a 16T cog, but the resulting gear ratio would be unacceptable. The bike lost about 2 lbs so far in the process. Will lose even more when I get my lighter tires and tubes in today.
#59
Two pounds is a significant weight reduction. Terrain is quite flat where I live and I have rarely used the 42T chainring. I'm thinking about going to an eight speed setup by removing the inner chainring and front derailluer and shifter. I'm interested to see which tires you will use.
#60
Bikes: Dahon Mu Uno, Mercier Mini Velo Nano, 99' Haro Cyclocross
Has anyone replaced the tires yet? I just received my marathon racers and cannot get these suckers on. Spent the last hour and tried a little soap and tire levers, but no luck. Its driving me nuts
#61
This bike is cat approved
Bikes: To many to list...
Do you have a heat gun? I used one on some tires that were a bit tough to get on the rims and it worked pretty well.
#62
Quoted: 11 Post(s)
Liked 10 Times
I installed the Marathon Racers. I did it outside with the temperature at 70 degrees and it was sunny. I didnt have a problem getting the Kendas off. I didnt have a problem getting the Racers on.
Speed Uno
Speed Uno
#63
I've been able to get mine on...but it has been a struggle! I got some duranos size 20x1.1
#64
Got my Panaracers on. Was also a bit of a struggle. Haven't ridden them yet. Ride report tomorrow.
Also got a Origin 8 Classic stem:
Almost done with my upgrades. Just waiting for my new seatpost to come in.
#65
Grr I'm having bad luck with my upgrades so far
Blew a tube trying to get my durano's on - and no stores near me have a 20x1 presta tube
Also, the rear derailleur needs some serious adjusting, I was tinkering with it for 2 hours and the chain is still skipping sporadically
And finally, my tekro brakes from bikeisland aren't long enough! at least i can swap the levers, haha...i still really want to replace these damn brakes...
#66
If you're ordering upgrades, do yourself a favor and order in some extra tubes on the same order...
#67
My Panaracer Minits Tough tires are what you'd expect of a narrow, slick tread tire: quick acceleration, roll forever, bumpy ride. Nothing too different from any other tire with similar specs. The wow factor really kicks-in in at high speed. Whereas most tires I've ridden seem to show more rolling resistance the faster you ride, these tires do not have that characteristic at all. No matter how fast you push them, they simply respond with no added rolling resistance. These tires remind me a lot of the Greenspeed Scorchers, except with a much narrower width.
The only thing I am hesitant to comment on at this point is durability and puncture resistance. Though they are marketed as "designed specifically for urban commuters", I won't be convinced until after 2 weeks of torture testing on the streets of downtown SF. I can say, however, that I wouldn't buy them again as they ride far too rough for urban commuting. I miss being able to just bomb over rail car tracks and buckled pavement and potholes like I could with the larger, heavier Kenda Kwests.
I really wish IRC would bring back their 20x1.25 Metro tire.
https://www.amazon.com/IRC-Metro-Tire.../dp/B000C17LT0
#68
Quoted: 11 Post(s)
Liked 10 Times
Try the Marathon Racer it rides nice and accelerates quickly. Not a bad price https://www.utahtrikes.com/PRODINFO-S...acer_Tire.html and they shipped quickly.
Speed Uno
Speed Uno
#69
#70
Quoted: 11 Post(s)
Liked 10 Times
I was going to go to a smaller size but I am glad that I stayed with the 1.50 for comfort.
Speed Uno
Speed Uno
#71
The 20x1.25 on the Nano is actually not nearly as bone-jarring as the 20x1.35 on my aluminum Swift folding bike. The Nano's frame does an excellent job of isolating road vibration.
#72
Finally got my Racers on... although I'm missing a few layers of skin on my thumbs! Love your upgrades james ... If I didn't have my Mu Uno, I'd probably follow your upgrade path.
#73
Quoted: 147 Post(s)
Liked 8 Times
You should try Greenspeed Scorcher. Forum member Vik wrote a review of them and they're my favorite tire. The Bike Friday folder community raves about them!
#74
Quoted: 11 Post(s)
Liked 10 Times
Calhoun Cycle has them https://www.calhouncycle.com/productc...&idproduct=969
Speed Uno
Speed Uno
#75
In retrospect, the Scorchers should've been my first choice, but I had been curious about the Panaracers for quite some time.
