Go Back  Bike Forums > Bike Forums > Fatbikes
Studs in used tires?
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 08-20-19, 05:49 AM
slothead
Quoted: 7 Post(s)
Will installing studs in used tires risk cutting case threads and weakening it?
slothead is offline
Old 08-20-19, 12:49 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
which tires and what type of studs?
Are you running tubeless?
qclabrat is offline
Old 08-21-19, 11:33 AM
slothead
Quoted: 7 Post(s)
At the moment no, but was considering it. I guess that would make a difference regardless of the inner tire stud profile?
slothead is offline
Old 08-22-19, 06:44 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
are you planning to use studdeable tires or just looking to screw them in? I've seen the latter with mostly minimal success.
Main benefits of tubeless is to run single digit tire pressures while not having to worry about pinch flats.
qclabrat is offline
Old 08-22-19, 07:55 AM
slothead
Quoted: 7 Post(s)
I didn't realize they screwed in, I thought they pressed in with some type of press (thus potentially cutting tire casing threads). I need to learn more about tubeless and studs in general.
Thanks,
Tom
slothead is offline
Old 08-26-19, 10:47 AM
Hypno Toad
meh
Hypno Toad's Avatar
Quoted: 1111 Post(s)
Liked 1,013 Times in 519 Posts
Thanks,
Tom
Are you adding studs to a tire that's ready to accept them? This is a video about installing studs in a 45NRTH tire designed to for studs.
Otherwise, if you're looking to DYI studded tires, I'm not much help.
Hypno Toad is offline
Likes For Hypno Toad:
Old 08-26-19, 11:07 AM
slothead
Quoted: 7 Post(s)
Thanks Toad, that was extremely helpful!
slothead is offline
Likes For slothead:
Old 10-04-19, 06:47 AM
savski
I bought the tyres with studs already in, were not too expensive and lasted me a couple of winters.
savski is offline
jimmie65
General Cycling Discussion
11
03-08-18 09:21 PM
StephenH
1
03-07-18 07:09 PM
Mdavis5011
Road Cycling
40
02-08-18 03:24 PM
Hiro11
32
11-05-16 09:44 PM
patthepunk
Singlespeed & Fixed Gear
5
07-22-10 02:27 AM
