Frame saver alternatives
Quoted: 5890 Post(s)
Liked 3,475 Times
I've used JP Weigle frame saver (now problem solvers frame saver) for a while but it is out of stock in the various places I've checked and do business with.
Are there any alternatives that I should consider?
Quoted: 3016 Post(s)
Liked 3,810 Times
Don't ride that bike in the rain.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 680 Times
Fluid Film is the one I'm going for.
I've seen a couple of heavy duty tests and it beat Frame Saver in both.
Likes For Aardwolf:
Quoted: 569 Post(s)
Liked 595 Times
ProGold Steel Frame Protector seems to work as well on my daughters Portland, OR bikes and is available on line with lots of places. I have heard the Muc-Off
brand is also good.
brand is also good.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,107 Times
Boeshield spray and the traditional method of boiled linseed oil are alternatives. For the most part though I ride an aluminum or plastic bike in wet weather and if one of the steel bikes gets wet and grimy I just clean and dry it right after.
Likes For Spaghetti Legs:
Here’s a thread on MTBR where the poster conducts a controlled test of 6 different anti corrosion products suitable for steel frames.
https://www.mtbr.com/threads/anti-co...otout.1073581/
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 265 Times
Eastwood
Eastwood sells a number of products for rust encapsulation and rust prevention.
they sell a nozzle that can be fed into the frame tubing. The nozzle tip sprays 360 degrees ensuring the inside of the tubing is coated. Much better than frame saver.
https://www.eastwood.com/internal-fr...ce=google&wv=4
Likes For brewerkz:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,056 Times
Boiled linseed oil.
Likes For clubman:
Bikes: old ones
Quoted: 26438 Post(s)
Liked 10,402 Times
Quoted: 4816 Post(s)
Liked 3,945 Times
I've been using AMS Oil Heavy Duty Metal Protection https://syntheticoilpros.com/shop/cl...tal-protector/ for about 15 years. Not expensive, not hard to use and seems to work quite well. I've had no surprises. Yes, some of the AMS sales reps are quite fervent But I've always come away with just can in hand and all my limbs and finances intact. It's been a few years (the cans do several bikes) but I never paid much more than $8 per.
It seems tor me that buying a product cheap enough that you feel free to use maybe too much and make a mess is a great tradeoff vs an expensive one you want to use wisely when you enemy is water, famous for finding its way to the farthest corners. That H2O stuff is incredibly patient and persistent.
Likes For 79pmooney:
Liked 3,475 Times
Liked 3,475 Times
Wheelman
Quoted: 298 Post(s)
Liked 680 Times
Apparently it smells nice too (if you like sheep).
A thing I have discovered is that a lot of advertised "Fluid Film extension hoses" don't work with the Fluid Film can.
The can I've got is a "female" top, ie, the cap inserts into the top, so specifically not supported by this: https://www.ebay.co.uk/itm/385241435...oAAOSw~OZjgNvf
On the other hand Amazon sells thin plastic tube that would fit on the nozzle.
Likes For Aardwolf:
On the inside of the tubes just about anything will work great, up to and including waste oil from your last oil change. You know how you can still see that spot of oil in the pavement from that oil change last year? And that is oil that was exposed to the elements and traffic. Just oil on the inner tube will occupy all the nook, crannies, and pores in the metal. Being hydrophobic would stop humidity from getting in contact with the metal. Being protected inside of the tubes it will never degrade or move away.
Personally I use boiled linseed oil mostly because of old school snobbery.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I use Boeshield. Spray it on everything. Frames, derailleurs, pasta, broccoli - multipurpose stuff.
Likes For tyrion:
Liked 3,475 Times
