Battery charging!
Battery charging!
Old 04-09-20, 10:04 PM
Frankenbike27
Quoted: 11 Post(s)
Liked 4 Times in 4 Posts
Battery charging!
You will never see this question again. i have a 24 volt battery (29.4 volts) 450 watt motor, here's my question, can i charge it with an 18 volt laptop charger, 2 amps, connections the same, secondly can i charge it with a 18 volt, maxium 24 volt solar panel? need an answer by tomorrow please
Frankenbike27 is offline
Old 04-09-20, 10:22 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
No
trailangel is offline
Old 04-12-20, 11:05 PM
TonyVov
Bikes: Bambu bike with Bafang Hub kit
No but it is very cheap to buy a buck boost amplifier that will use your inputs and boost them to charging values , just 4$-5$, even better get somethinglike this, MPT-7210A Aluminium Alloy LCD Display MPPT Solar Panel Charge, this handles your battery safely with a CC-CV charging circuit on output and an MPPT input circuit to efficiently use the solar panel power.
TonyVov is offline
Old 05-23-20, 05:45 PM
nob
Quoted: 45 Post(s)
I use portable solar panels to collect solar energy from the sun. I can charge USB devices directly from them or save power in a portable power supply for the future. The portable solar panel has a wide range of power outputs for powering and recharging important devices, devices and electronics directly from a portable charger. I constantly use a portable device, because it is very economical and convenient.
nob is offline
Old 05-24-20, 07:31 AM
kobike86
no
kobike86 is offline
Old 05-24-20, 10:04 AM
Bluesfrog
Quoted: 32 Post(s)
Liked 19 Times in 18 Posts
What did you come up with to fix it? Be Well, Bluesfrog.
Bluesfrog is offline
