Vintage Gravel Grinders
#51
This '74 Harry Quinn Tourist has the widest clearance of any of my last-century vintage frames. 43-622/700c nominal will fit, but with clearance pretty tight under the crown and between the chainstays. Switched to 38s for a little more breathing room. The fork crown/blades look totally optimized to cram as much rubber underneath/between as possible.
It's only got a drive-side downtube cable stop/shifter mount, so maybe it was built for a 5spd freewheel w/single ring, or maybe for an internal-gear hub? Or they knew in '74 I'd want to do a restomod 1x build in 2016?
In the studio, kinda recently, with 38-622/700c:
Previous build, in the wild, with 43s:
1st build, maybe 35s here?
Fuggedaboutit!
Fuggedaboutit!
#52
Quoted: 81 Post(s)
Liked 221 Times
My mother taught me that you never ask an unmarried woman how many cats she has, and you never ask someone how much they spent on the components for their vintage bike build.
#53
Quoted: 964 Post(s)
Liked 1,451 Times
Wasn't askin', just observin'
#54
Quoted: 964 Post(s)
Liked 1,451 Times
Maybe someone liked suicide shifters?
#55
Vintage and gravel capable.
#58
I guess my Covid project fits pretty well in this thread. I just finished putting this together a couple of weeks ago. It's a 1982 Trek 710 to which I added cantilever posts, a few other braze-on bits, and dimpled the chainstays to make some room for real tires. The end result works well with 650b x 42 Rene Herse Pumpkin Ridge knobbies. The tires are great on gravel roads, jeep trails and single track, but they're also amazingly fast on the 25 miles of pavement I need to ride before I get to the good stuff.
#59
Quoted: 1627 Post(s)
Liked 630 Times
Any old* bike will do.
* That is, old enough to have some big tire clearance. Early 70s Nishiki Semi Pro has enough for 700x38 tires, but I may step it down to 35s and put fenders on it. Sure I ride gravel all the time, but 38 seems like a little overkill sometimes.
Likes For Lascauxcaveman:
#60
Bikes: '85 Trek 620, '88 Schwinn Cimarron, '88 Novara Ponderosa, '6#? Magni, '93 Stumpjumper w/Dirt Drops, 70's Raleigh Competition G.S., '80 Bill Vetter, '90's IF Deluxe
Quoted: 7 Post(s)
Liked 30 Times
I picked this Competition GS up this spring. My "gravelizing" included swapping out the crankset, rear derailleur, freewheel, tires, and stem and handlebars. It is still a work in progress. I'll likely go from the downtube shifters to suntour barcons. In the meantime, it is performing admirably here in the Green Mountains, even on some of our finest "class 4" rough stuff. I like it so much that I just sold my Salsa Casseroll, as the two bikes really fit in the same niche.
Likes For gmvelo:
#61
Quoted: 823 Post(s)
Liked 1,395 Times
This is the ‘73 Raleigh Competition seen earlier in this thread, photographed Saturday morning when I finally got to really test the whole concept of the Dingle-Speed Drive. As always, the 70-in fixed gear provided by the 44x17 combo works nicely on the pavement. What I was unprepared for was just how perfect the 60-in fixed gear of the 42x19 was on the mixed gravel, hard pack and red clay mud of this area’s dirt roads. This bike exceeds all my expectations - it just rides so well on mixed and loose stuff!
#62
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
I'm of the mind that any bike is a gravel bike.
The tires on this measure at 26mm.....it's been to Eroica CA and Cino.
But wider is nicer.....this '66 Frejus sports 35 Paselas.
#63
I picked up a '73 Cinelli Speciale Corse a few yeras ago that is in really rough shape and is not my size. I like a 58 and this is a 61. It sat for many years and then I had the idea to make a French-fit gravel grinder out of it. Still a work in progress, as you can see, but those are 32mm Gravel King slicks on there and they feel great on the road.
Likes For jet sanchEz:
#64
Quoted: 3810 Post(s)
Liked 6,699 Times
This 1969 Raleigh Sprite did remarkably well yesterday on the unpaved surface part of my ride. Felt very well balanced and never mired down in any of the soft stuff.
Likes For nlerner:
#65
Bikes: Trek 720, Trek 620, Trek 520, Steel Schwinns, AD Puch, Kona, Nishiki Pro, All City Disc Spacehorse, Waterford
Quoted: 151 Post(s)
Liked 101 Times
I really enjoy riding my two speed kickback Eclair
#66
Quoted: 7348 Post(s)
Liked 2,470 Times
So am I, but it's not a mindset that works for everyone. I did some gravel riding on my road racing bike (with 28mm tires) and told the tale on a local cycling Facebook group. Someone asked how hard it is in a way that revealed they were not experienced. Someone else said I shouldn't encourage people to do that. I said that's true, because if you don't know how to handle a fishtailing rear wheel near a cliff, well, there could be trouble.
Likes For noglider:
#67
Quoted: 823 Post(s)
Liked 1,395 Times
Twenty years ago, when there was an active cycling club here, I wound up leading some rides that would include short stretches of reasonably well-groomed gravel - never more than a mile or two at a stretch, and often a good example of a short cut to get to a more interesting or quieter road. I would usually warn potential riders in advance, "Hey, you're gonna want at least a 25 mm tire for this," because I had found that the actual/measured Continental Sport 1000s I used in those years were just fine. And those cyclists who DID join me on those rides had a blast. Those would be the rides through the back of beyond, off the buttery smooth asphalt but also far from traffic, and those were the rides where we'd stop in some small town and eat lunch like a bunch of British or French club cyclists before returning home. The local racer wannabes and the middle-aged guys who wanted to be wannabe racers would scowl and declare that it wasn't their kind of cycling.
Last time I checked, most of those who complained now have gravel bikes. But I bet they still don't stop for lunch ...
#69
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
My first gravel bike was a drop bar converted early 90s Univega hybrid.
I changed the bars, bar end shifters, stem, brakes, tires, and crankset.
The frame was way too small for me, but I made it work and comfortably did rides up to 45mi I think, which seemed big then.
Minimal investment to make sure i liked it before dropping more money into a nicer and better fitting frame.
It fit 40mm tires without issue and the gearing was wide enough for me to figure out what I wanted for my next gravel bike.
I ended up selling the frame to a forum member. It was such a cool color!
Likes For mstateglfr:
#70
As found
Here is that 1973 Cinelli I posted before, finally sorted out, minus the pedals, obviously.
It was "leaning against a shed in Sudbury, Ontario for many years" according to the seller. Luckily, everything was well-greased and nothing was seized except the seat-post clamp.
The brake hood is a re-production campy hood and ripped within when I was putting on the bartape.
The stem is super fugly but the frame is too big for me and this was the shortest stem I had on hand.
Wheels are these black Phil Wood hubs that are 130mm but oddly take a threaded freewheel (?) laced to Mavic Open Sports that I found on CL
I am kind of enjoying it for cruising, I am going for a French fit gravel-grinder kind of thing
I wil to try to get some old Honjo fenders on there but I may have to change the tires out from 32s to 28s (I love the green with the gold, anyone know of a 28mm green gumwall tire, I don't think Panaracer makes GKs that thin)
Last pic is how I found it
#71
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
Did a back road ride in southern Tennessee...
... never have I ever been chased by so many dogs. I planned on going 20 mi plus, however all the dogs spooked me into making it a 12 mile run.
Likes For mechanicmatt:
#72
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
If plump knobbies on a touring frame get me in the door, I guess I could post this one, eh?
(NB: before/after thread and more pics)
Likes For francophile:
#73
Quoted: 5888 Post(s)
Liked 3,471 Times
1993 Bridgestone XO 2
This bike is more modern than most of the ones on this thread but it clearly owes a lot to the French 650b constructeur bikes. The 1993 Bridgestone XO 2 has road bike geometry and 26 inch wheels since in '93 that gave you fat tires. It is a very capable gravel bike and a fine road machine. I run 26 x 1.75 tires and 3 x 8 gearing. With a 44/32/22 triple and 11-28 cassette, the bike can handle any terrain.
Likes For bikemig:
#74
PM me your cotters
Liked 590 Times
This bike is more modern than most of the ones on this thread but it clearly owes a lot to the French 650b constructeur bikes. The 1993 Bridgestone XO 2 has road bike geometry and 26 inch wheels since in '93 that give you fat tires. It is a very capable gravel bike and a fine road machine. I run 26 x 1.75 tires and 3 x 8 gearing. With a 44/32/22 triple and 11-28 cassette, the bike can handle any terrain.
Liked 3,471 Times
I like them a lot. I run WTB or leather saddles on pretty much all my bikes. I've put a lot of miles on WTB saddles since I've done a number of multi-day tours on the XO 2 and on a 1985 Cannondale ST 400 which also has a WTB saddle. I don't like using leather saddles on tours because of the rain. I know I can bring a saddle cover but WTB saddles work for me.
Likes For bikemig:
