getting a new cassette with a freehub, differences??
Bikes: my bikes: Old: 1965 Schwinn 10 speed, 72 Monshee 12 speed, 77 Norco 12 speed, 95 Trek 850, two Specialized Crosstrails, 2016 Specialized carbon Sirrus. New 2020 Trek FX1
Quoted: 54 Post(s)
Liked 36 Times
Hi everybody, took my Trek FX-1 in this morning to have the problematic freewheel setup replaced with a new freehub, new wheel and new rear cassette. The old cassette was a 14-32 and the new one is a 12-28. What will I be experiencing in terms of differences between them?
Thanks
Thanks
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Thanks
Thanks
It shouldn't be a problem. You still have a very low 28 - 28 low gear which is a 1:1 ratio. Unless you are going up some seriously steep climbs that should be plenty low. And you will have a higher top gear as well.
Quoted: 1943 Post(s)
Liked 2,164 Times
Basically a bit more top end and less low end. The rest will be the same.
For 7 speed, I assume...
14-16-18-21-24-28-32
12-14-16-18-21-24-28
John
John
