Water Bottle Cage Mounting- Elegantly??
Old 06-19-18, 07:10 AM
Tandem Tom
Quoted: 310 Post(s)
Liked 37 Times in 31 Posts
My wife's Miyata Mixte does not have bosses for a water bottle cages. What is a "elegant" way to mount one?
Tandem Tom is offline
Old 06-19-18, 07:21 AM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac, 196? Torpado Professional
Quoted: 812 Post(s)
Liked 335 Times in 234 Posts
Just Google water bottle handlebar mount and see what you get. Seems to be lots of those to choose from...
randyjawa is offline
Old 06-19-18, 07:24 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1739 Post(s)
Liked 536 Times in 325 Posts
There isn’t really an elegant way because it needs to clamped on. Do you want it on the downtube? If it is a Mixte some of the nicer clamps may have too much standoff to fit.
https://www.ebay.com/i/262690030610?...75d978fff59689
https://www.topeak.com/us/en/product.../332-cagemount
Bianchigirll is offline
Old 06-19-18, 07:57 AM
Ex Pres
Ex Pres's Avatar
Quoted: 396 Post(s)
Liked 44 Times in 32 Posts
Twofish makes velcro removeable mounts for just about any place on a bike. I've used one of their products for lights, and liked it.
For bottles, I use my jersey pockets.
Ex Pres is offline
Old 06-19-18, 08:00 AM
AlmostGreenGuy
Intrepid Bicycle Commuter
AlmostGreenGuy's Avatar
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 71 Post(s)
Liked 79 Times in 29 Posts
I've been battling the same issue. I tried mounting a standard bottle cage last night, using a set of Velo Orange bottle cage clamps, over some lengths of innertube. The job came out okay, but I need to work on getting the clamps a little less crooked.
AlmostGreenGuy is offline
Old 06-19-18, 08:27 AM
AlmostGreenGuy
Quoted: 71 Post(s)
I'm starting to think that the easiest and lowest profile solution might be
. Strong stuff.
Old 06-19-18, 08:45 AM
ksryder
Bikes: yes
Quoted: 1048 Post(s)
Liked 291 Times in 174 Posts
Platinum-plated hose clamps, duh.
ksryder is offline
speedevil
I never finish anyth
speedevil's Avatar
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 290 Post(s)
Liked 109 Times in 73 Posts
The mixte frame has two smaller-diameter tubes that leave the headset, pass on either side of the seat tube on the way to the dropouts, right? You could drill for rivnuts, but not in those small tubes. Installing rivnuts in the seat tube would work, but you need to consider how deep the seatpost slides in the seat tube.
Using self-fusing silicone tape under clamps is a good idea as well. I use that to secure the end of the handlebar tape, and to hold the cables in place before I wrap the bars. No messy adhesive if you need to remove it for some reason. The tape is certainly easier than drilling the seat tube and setting rivnuts - but you asked about elegant - so rivnuts win on the elegance score.
Dale, NL4T
speedevil is offline
Old 06-19-18, 09:05 AM
Vintage_Cyclist
Vintage_Cyclist's Avatar
Bikes: yes
Quoted: 384 Post(s)
Liked 56 Times in 31 Posts
A pair of DMR Hinged Clamps. Rock solid.
Vintage_Cyclist is offline
Likes For Vintage_Cyclist:
Old 06-19-18, 09:12 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2170 Post(s)
Liked 536 Times in 369 Posts
If clamps offend you, you could always use rivnuts, as is routinely done with non-steel frames.
JohnDThompson is offline
Old 06-19-18, 09:21 AM
Aubergine
Bad example
Quoted: 775 Post(s)
Liked 18 Times in 15 Posts
I use the Velo Orange clamps with Zefal Vintage bottle cages. The combination of vintage-looking bits is harmonious, particularly on an older bike. If I were using modern aluminum cages I would go with the DMR clamp mentioned above.
Aubergine is offline
Old 06-19-18, 09:50 AM
madpogue
Quoted: 1492 Post(s)
Liked 565 Times in 434 Posts
There are a few back-of-the-saddle options, that go either on the rails or on the seatpost.
madpogue is offline
Old 06-19-18, 10:14 AM
John E
feros ferio
John E's Avatar
Quoted: 815 Post(s)
Liked 171 Times in 137 Posts
Handlebar mount! (I'm biased.)
I didn't want to cover or damage the downtube decals on my 1959 Capo (pump along seat tube), or cover Ratshausmann on my 1960 Capo Sieger (pump pegs on downtube), so frame mounting was out for both.
John E is offline
Old 06-19-18, 11:18 AM
AlmostGreenGuy
Quoted: 71 Post(s)
I'm impressed. That's pretty clean looking.
Old 06-19-18, 01:48 PM
Jadesfire
Jadesfire's Avatar
Bikes: '88 Bianchi, '94ish Trek
Quoted: 1067 Post(s)
Liked 124 Times in 55 Posts
Thanks for that. I was just kicking myself that I placed an order from Wiggle this past weekend and hadn't seen the DMR clamps. I have a Velo-Orange shopping list still going, though, and these just made it on there. These look a lot cleaner than the hose clamps I was going to use.
Everyone thinks they have had a long strange trip, until they look at other folks' journeys. Then they realize everyone has had a long strange trip, just using different modes of transportation.
"The mystery of life isn't a problem to solve, but a reality to experience."
Jadesfire is offline
Old 06-19-18, 01:53 PM
phtomita
Bikes: '86 Nishiki Tri-A, '84 Centurion PT15, '87 Centurion IM Master
Quoted: 194 Post(s)
Liked 59 Times in 46 Posts
This - I have it on my head tube
Lixada Bicycle Bottle Cage Adapter Mount Adjustable
phtomita is offline
Old 06-19-18, 02:27 PM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon
Quoted: 246 Post(s)
Liked 38 Times in 29 Posts
It seems to me that if you want the utility of mixte-ness, that step-through opening from not having a top tube, you might find a bottle cage on the seat tube or somehow on the mixte tubes (hand-fab some w-shaped plates to sandwich the mixte tubes?) is something you might avoid because it would to a degree fill that space.
Is there room UNDER the mixte tubes?
Larry:1958 Drysdale (Grey Ghost?), 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974ish Falcon as Grocery bike. Susan: 1976 Windsor Profesional.
tiger1964 is offline
Old 06-19-18, 02:29 PM
Vintage_Cyclist
Bikes: yes
Quoted: 384 Post(s)
If you want to go the handlebar route, there's also the Minoura BH100C-S. It mounts to either side of the stem and swoops over to the center.
Old 06-19-18, 02:37 PM
Vintage_Cyclist
Bikes: yes
Quoted: 384 Post(s)
Haven't had a reason to try it, but I wonder if an appropriately sized pair of P clamps attached to one of the mixte tubes, with the bolt holes centered between them, might work for a cage. Or even better, a pair on each tube, if you can get the bolt holes to line up.
Old 06-19-18, 03:29 PM
Aubergine
Bad example
Quoted: 775 Post(s)
That’s a nice idea!
Old 06-19-18, 05:21 PM
tiger1964
tiger1964's Avatar
Quoted: 246 Post(s)
As the mixte tubes converge, the upper and lower pairs of these clamps won't have the same spacing, but sounds like a good place to start.
Old 06-20-18, 06:49 AM
AlmostGreenGuy
Quoted: 71 Post(s)
Just a quick update. I got my VO clamps straightened out last night. I'm much happier now.
Likes For AlmostGreenGuy:
Old 06-20-18, 08:07 AM
ollo_ollo
ollo_ollo's Avatar
Bikes: Still have a few left!
Quoted: 338 Post(s)
Liked 45 Times in 33 Posts
Currently working on a better solution than the original clamp on wire cage that came on my 75 Jubile Mixte. Don't have a good pic though, just these (as found of the Mixte). Will add a pic later with what I do for the Grand Jubile.
I like the Zefal Vintage cage on my Stella. Don
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
ollo_ollo is offline
Old 05-20-20, 06:02 AM
Brisbotica
So clean!
A pair of Rock solid.
Do you have a link to the cages?
sorry I can’t quote the pictures as I am new and can’t post links.
Brisbotica is offline
Old 05-20-20, 07:37 AM
Chr0m0ly
Chr0m0ly's Avatar
Bikes: '84 Miyata 610 '85 Miyata 710, ‘86 Miyata 710, ‘91 Cannondale ST600, ‘84 Trek 610, 520, 620, ‘91 Miyata 1000LT, a few frames, some odds and ends....
Quoted: 619 Post(s)
Liked 224 Times in 145 Posts
I don’t know if you’ll get an answer, this is a two year old post :-)
But here are some P-clamp links, you need to know the diameter of tubing you want to clamp onto. P-clamps have a lot of uses, they’re not just a “bike thing”.
Welcome to the Forums! There’s a ten post min before you can post pictures, and a 5 post per day max just to prevent bots and spammers, but it goes fast.
https://www.mcmaster.com/p-clamps/
https://www.amazon.com/p-clamp/s?k=p+clamp
Chr0m0ly is offline
