Removing braze-ons for the sake of making a "perfect" setup?
Edumacator
Quoted: 2439 Post(s)
Liked 3,123 Times
I'll take two perspectives:
1. You are not worried about restoration for the low-end Mercian. Once you paint it, it's no longer a Mercian. You are not looking for historic/monetary value, and anyone who might in the future, wish to buy it, won't care. Have at it, and do a nice job respectful of the heritage. Once you repurpose any antique, it is no longer the antique (steam-punk designs using vintage items). Once you remove stuff, it is no longer a Mercian, per se.
2. On the other hand, you can use a different frame for the fixie, and take your time restoring the Mercian and maybe find some personal intrinsic value to it.
If it were a vintage Italian steed, such as Rossin, Chesini, Faggin or Bottecchia, I'd scream sacrilege!!!!
Quoted: 3464 Post(s)
Liked 2,829 Times
I do not see a question here.
Set Fear aside.
Set Fear aside.
Quoted: 767 Post(s)
Liked 1,898 Times
Curious what made you change your mind?
https://www.bikeforums.net/classic-v...-sun-wasp.html
This is one of those itches that I've had myself at times in the past. I agree with above. Throw some parts together and see if the ride works for you, then you'll have a bit more data to go forward with.
If I was looking for a fixed gear, I'd go for something like a Raleigh Pro Track like noglider's. But you ain't me, so whatever works best for you is best for you.
Quoted: 981 Post(s)
Liked 1,844 Times
cudak888 I'll definitely set it up as a fixed gear ride with the original paint, but the photo I posted does not show the various faded areas, etc... It really doesn't look very good upon close examination. As mentioned, a fresh set of Mercian decals are already in hand!
JohnDThompson I don't want a track frame. Not trying to fool anyone! I'm after the feel of a post-war British fixed gear road bicycle but I plan to use an assortment of much more modern components to recreate the look without breaking the bank. I already have two beautiful frames c. 1950 that require a great deal of restoration and parts collection, so adding another to the list is not an option.
Quoted: 981 Post(s)
Liked 1,844 Times
Anyway, thanks all for the perspectives. As I said, either way this frame deserves a fresh coat of paint and that's the plan. Maybe I'll paint it without removing any braze-ons, set it up as a 10-speed and sell it to fund another more suitable frame for my purposes. Maybe I won't remove them and set it up as a fixed anyway, or maybe in the end I'll just put it under the knife. I'm probably a few weeks out from getting started so I'm sure there will be more back and forth. Cheers!
-Gregory
-Gregory
Quoted: 3241 Post(s)
Liked 2,512 Times
Howdy folks,
I have a lovely 1979 Mercian Campionissimo frame set. It was meant to be a 10-speed and has a peg on the down tube to hold a shifter boss in place, three shift cable guides, and two brake cable guides. It has stamped dropouts with no derailleur hanger. It was the "low end" frame offered by Mercian at the time and has Prugnat lugs, but is still built fully from butted Reynolds 531 tubing.
The frame is just my size and I really want to keep it, but I have enough multi-speed bikes and other frame projects that are less suitable for modification. I am missing a fixed gear bike in my stable, and I specifically want relaxed road-going geometry and don't necessarily care about track ends. I would like to keep and enjoy this frame, and have a rather elaborate paint scheme in mind for it as well. I can only imagine being bothered by all of the unused braze-ons after taking the time to paint the frame and set it up specifically as a fixed gear.
Assuming I actually pour a lot of time and effort into the paint, and know that I'll surely keep and enjoy riding the bicycle for many years to come, would people be put off by my chopping all of those little bits off of a Mercian? It strikes even myself as sacrilege to some extent but the frame is otherwise perfect for what I want - not to mention the fact that I also just really want a MERCIAN!
What say ye all? Time to let some controversial opinions roll!
-Gregory
-Gregory
Quoted: 981 Post(s)
Liked 1,844 Times
The rest is not a hindrance except aesthetically, only considering the idea that I would be investing a lot of effort in painting it. Hence my quandary.
Friendship is Magic
Bikes: old ones
Quoted: 26414 Post(s)
Liked 10,380 Times
...I have a California built Masi that some previous owner wanted to fit with bar end shifters. I guess this was before those little fittings that pop on over the braze ons were available, and all he had was a strap around the tube adapter. He ground off the braze ons and put on some touch up paint where he removed the DT braze ons. I wish you had not reminded me of that, because it still chaps my ass.
Quoted: 2338 Post(s)
Liked 2,822 Times
bare metal, acid etch primer, sandable primer, multiple coats of coleor, multiple coats of clear so process may be a bit different than the hot rod process (not counting your cool paint job work)
Likes For squirtdad:
Quoted: 800 Post(s)
Liked 753 Times
I say go for it if you really want to, except for the fender/rack braze-ons and the pump pegs. If you find yourself wanting a rear brake it's easy to use clamp-on guides that also look slick. Attachable pump pegs and p-clips aren't nearly as well designed to look pretty. I don't think it's unlikely you might want to throw a rack on the bike at some point, and it's nice to have the option.
Quoted: 767 Post(s)
Liked 1,898 Times
I understand about the Raleigh Pro that you mentioned. I don't know that an altered Marcian like yours is going to break many hearts, and if so, it is your bike.
What about the paint scheme you have in mind? Wanna reveal any details?
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Out of curiosity, what do you think of the guys around here who specialize in adding lots of custom braze-ons for touring setups or extra bottle cage bosses, dimpling stays for 650b tires, etc? That's sort of where I'm coming from when I look for justification - whether things are being removed or added, the original frame specifications are being altered and quite a bit of work necessary to return them to stock again. I still see some beautiful results around here from the custom crowd! Sort of my inspiration for getting "just the right look," if you will.
-Gregory
-Gregory
My main reason against, is that you are removing function from that frame, for no real gain. What if you decide you love how it rides and want to make more versatile? What if you hate how it rides and you want to sell it? How well do you know the frame at this point? I’d give it some time, and some miles before committing either way.
With that said, my opinion really is worth what you paid for it. I’m in no position to decide what is right or wrong for anyone but me. There are many bikes out there, too many to be worried about what people do to them. As long as it is ridden and loved, what else is there? That’s why we all love bikes, right? Sometimes, rules just ruin the fun for everyone.
Liked 2,512 Times
To be honest with you, after that new paint job, people will notice more what clothes you are wearing or type of facial hair you have while riding it. Your call, but taking away function strictly for aesthetics? Again, it's your call
Quoted: 1088 Post(s)
Liked 1,205 Times
If you're uncertain enough to ask opinions here, I would take the slow approach and build it as a geared bike first, just to get a feel for the frame. You can always move forward with the original plan if you're not impressed with it as a geared bike, but you can't replace the braze-ons. (Well, you can, but you know what I mean.) In the meantime, maybe a beater frame will come along that begs for a repaint (for practice) and maybe even has track dropouts. I love that color orange. And the gold decals. And imagining the original paint all shiny.
I would say just give yourself a little time to judge whether this is an impulse or a plan. Impulses pass.
Likes For Mr. 66:
Quoted: 981 Post(s)
Liked 1,844 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
And the rest of those braze-ons: top of BB cable guides never looked super elegant and collected grime. Drilling a small hole in the future, tapping and adding a plastic below the BB cable guide is easy (and far nicer). OK, you might have to use a chrome stop on the chainstay. Rear brake cable guides should be on top ala the early '80s. Even chromed guides are better than what's there (in my opinion). The good pumps are frame fit so that's not an issue.
This bike is a super road fix gear. Sweet, long road dropout that can handle a real mix of cogs on a flip-flop hub so you can ride the hills like the old days and stop and flip the wheel. This can probably handle a 16-22 swap. That's real. Yes, the Bob Jackson track frame can probably do more, but track ends suck for quick, easy road flips. Also, rear brakes are nice, especially in serious hills. The levers for standing - something we do a lot of, rear brake for speed control and alternating brakes for cooling. (Between that and the fix gear, I run cooler rims than anyone else on really steep hills.) And again, for those really steep hills, good old redundancy. I would much rather be telling my grandkids about that scary descent where I had only my rear brake and the pedals after the front failed. Road dropouts mean that the rim can stay withing the brake pads as you play with wheel flip and big cog differences. (Also far easier to deal with if you ever go to fenders. Edit: keep the eyes. Fix gears are sweet rain bikes.)
The real roadies of England, when that bike was made, would not cringe at you turning it in to a fix gear specific ride. In fact, they might applaud a good job.
Additional edits for typos
Ben
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
FWIW, I'm in the don't drew it camp. I like fixed riding and used my Sakai tri-bike as one for years but I'm glad it's unmolested as it's now being rebuilt up for road again.
Somehow I think adding bits to a frame is improvements. Removal is unnecessary and generally bad.
Quoted: 1607 Post(s)
Liked 2,216 Times
Kilroy1988 Like others, your bike your decision. I bought a Trek610 that had been rattle canned and drewed. I didn't have any problem with stripping and adding bits to support the intention of the bike which is sport touring. So adding bits is a bit different than removing them and is dependent on what you start with. Finding something close that has already been abused is not that hard and is easy to justify mods. IMHO.
104_PaTrek., on Flickr
125_PaTrek, on Flickr
119_PaTrek, on Flickr
PaTrek STI 043_Cable Stop_01, on Flickr
Quoted: 5888 Post(s)
Liked 3,471 Times
Howdy folks,
-Gregory
-Gregory
It's your call on the frame but you know that most here wouldn't do it for what it's worth.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
If the finish were trashed, nobody would bat an eye. However, it IS your bike, and you do intend to do it more than justice when you refinish it.
You say you want to retain the pump peg (which I actually might not have decided to keep). I would advocate for also retaining the fender eyelets and the brake cable guides (yes, it's going to be a fixed gear, but I mount brakes on all my bicycles that are going to be used in traffic with the general public). This really doesn't leave very much to be removed though. lol
Eager to see how this ends up. Re-imagining bicycles can be a very sweet (if not entirely linear) adventure.
Liked 2,822 Times
Quoted: 981 Post(s)
Liked 1,844 Times
I'm not sure about the brake cable guides yet but I'll definitely retain the fender eyelets. Removing them is not an option if I'm going for a proper British look from any era!
Clip on cable guides were common for when riders did choose to use both front and rear brakes. I'm not advertse to that at all assuming I'll mostly just run a front brake anyway, as I always have in the past with my fixed gear bikes.
The wheelset I have for the bike has double fixed cogs. No single speed for me! That seems counter-produxtive considering the advantages in strength and cadence gained from riding fixed.
Liked 3,928 Times
I thought about gugie and asking to do just that, with the classic "road/path" frames in mind. Robust track dropouts with fender eyelets look pretty cool!
If you want to mess with the dropouts, get 1/4" steel plate and make yourself a road "L" dropout. Just a little work with a bandsaw and file. The rest is identical to a 3rd party track end.
I had adjusting screws fitted for my dropouts which I love on my winter fix gear (brainless wheel fits after late night flats coming home in the rain) but quickly stopped using the screws on the custom because flipping was so much fun. (Spend the money for a track quality crankset. The roundness makes setting correct chain slack very easy. My custom has a Sugino 75. Well worth it just for the time and work it saves on wheel flips. (Chain barely lightens and loosens as I go through the pedal stoke. Set the 1/2" slack - and I don't even need to be very close) and the bike is ready to ride. Cheaper or road cranksets and you may find you have to spin the pedal several revolutions to find the tightest and loosest points. The makers of road cranksets hae zero incentive to keep things round. Slightly oblong cranksets shifter better and faster.
I know people are fans of track ends with stops but again, I ask why? They are not needed to keep the wheel in place. Very strong velodrome riders have been riding sprint races for a century without them. (Look at photos of Nelson Vails - he didn't use them. I'll bet his nemesis, Mark Gorski, didn't either.
I was riding fix gears on the road 20 years before they became popular; on road bikes like most of us from those days. The track bike as a popular option for road fix gear fix gear riding started in the '90s with the hipster crowd. Yes, some have always ridden them as road bikes. But never large numbers until it became the thing to do. Peer pressure is an impressive force. Completely overrides decades of experience.
(Now I get to sit back and watch myself get blasted.)
Ben
Likes For 79pmooney:
Quoted: 981 Post(s)
Liked 1,844 Times
Ben,
I just like the look but am well aware that many British riders simply used road frames with regular drop outs for their fixed riding. It'll certainly be easier not to change that aspect of the bike! I just meant to mention that I did in fact consider it since I know we have some local talent who could make that happen!
