Hub Grease Question
Quoted: 457 Post(s)
Liked 112 Times
Hub Grease Question
Wondering what you fellow's use when repacking wheel bearings?
I have been using Park Tool been grease. But I just pull my axle ,as I wanted to replace the seal on my freehub body, and noticed that my recent repack of grease has pretty much disappeared.
So suggestions are welcome!
Thanks!!
Thanks!!
Quoted: 380 Post(s)
Liked 106 Times
I use either Park Tool, Phil Woods or some green marine grease. All work equally well. Not sure what exactly you mean by disappeared. Maybe you just need to be more liberal with amount you are using. Roger
Quoted: 2026 Post(s)
Liked 1,096 Times
I also use Phil Grease and have never had it "disappear" from any hub even after 8,000 miles or more between overhauls. As Roger noted, perhaps you need to use more grease initially.
I purposely overfill my hubs and let the excess extrude out through the seals for the first couple of rides. That assures the bearings are well protected and the grease itself forms a good secondary seal.
Likes For HillRider:
Quoted: 457 Post(s)
Liked 112 Times
I usually am generous! I fill the race set the balls then cover the balls with another layer.
When I opened it up the vast majority was gone. Time to get a bigger tub of grease!!
Quoted: 2614 Post(s)
Liked 1,958 Times
Maybe it's just telling you your hubs should be repacked more often.
Likes For pdlamb:
I've tended to put more than less and just wipe off the overflowing excess.
also over the decades I've noticed that higher end hubs, ie xt type level, have better seals and keep both amount and cleanliness of grease better over time.
so could be amount you put in, how long, and how well hub is sealed.
my guess is amount, but probably combo of all factors
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 186 Post(s)
Liked 208 Times
Supertech Marine Grease $4 (Walmart) for full size tube which I spoon into mini grease gun (Amazon $12).
Last new bike 1991
Last new bike 1991
Quoted: 4560 Post(s)
Liked 2,804 Times
I've used Phil's green goo for years. But recently I noticed the same Shimano hubs packed in the original Shimano grease seemed smoother, more buttery, like the shearing property was more cohesive. I'm not sure it translates to measurable differences on the road. But I'm tempted to try the Shimano stuff now.
Quoted: 1951 Post(s)
Liked 2,189 Times
I’ve been using Finish Line Teflon on hubs. I used to use Phil’s, but now I only use Phil’s on headsets, non-cartridge bottom brackets, pedals, and any other part I need grease.
John
John
Quoted: 114 Post(s)
Liked 119 Times
https://www.jensonusa.com/globalasse...o/cm228b00.jpg
Likes For MudPie:
Liked 1,958 Times
I just noticed the Shimano grease is made in Germany.
Pass the Pedro's, or the Parks, or the Phil's, or ...
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I've heard of grease disappearing from hubs... usually from carrying the bike on the outside of your vehicle at 70 miles an hour... maybe the wind did it.
I personally had Phil W grease disappear from a front hub, but I was crossing a creek on foot, using the bike as a prop to keep me from falling in the water and the front hub submerged a couple of times. Next time I cleaned it noticed the hub was gritty..... opened it up and the grease had VANISHED. !!!
Maybe if you are in PNW or really wet areas go for the marine trailer grease.
