Park chain tool CT 3.3
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4423 Post(s)
Liked 4,527 Times
I busted the pin on its first chain break. Yes my fault I didn’t have it lined up properly but I hardly put any force on the tool and the pin bent. I since ordered replacement pins. Got out my antiquated chain tool and it did job. 25 years of biking I never once broke a chain tool. If it wasn’t lined up straight I could tell right away and adjust it. I’m just surprised.
Quoted: 1438 Post(s)
Liked 1,092 Times
You will bend/break any chain tool if you do not align it properly, the pins are not designed to resist side forces.
Life Feeds On Life
Liked 4,527 Times
Completely busted .. have new pins on the way.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I don't like the replaceable pins. Would rather have a pin that stays in the tool. Nothing like having to use a chain tool by the side of the road and the pin falls out!
Quoted: 114 Post(s)
Liked 119 Times
I love that Park tool sells replacement parts. I have a Park floor pump (15+ years) and the head leaks and sometimes doesn't auto switch between Presta and Shrader. But for $2.99, I can get a replacement head unit and the pump will be good as new!
Likes For MudPie:
Life Feeds On Life
Liked 4,527 Times
This chain tool is for the garage I used my mini tool to fix the chain after I broke the push pin. The replacement threads into the tool and stays in place. I didn’t line it up right and broke it. Next time I will put the chain under a brighter light. Replacement pins like on Shimano chains I don’t care for so I use KMC.
