Going tubeless?
Going tubeless?
Old 06-11-20, 12:35 AM
venomx
Quoted: 64 Post(s)
Liked 7 Times in 5 Posts
Going tubeless?
If I get another puncture I’ll consider tubeless. Ideally I want to be able to replace inner tubes on my own but it’s impossible with this current setup. I suppose now they have been used and stretched a bit it might be easier next time. ( it took me and a mechanic 1hr30 just to get my tyres on the rim) I’ve also ordered that tool someone suggested from amazon
https://www.amazon.co.uk/Bbb-Cycling.../dp/B00A855QRY
I’ll do some research into tubeless, are you less likely to get punctures that way ?
My rims are tubeless ready so always an option
Only thing is if you get a puncture with tubeless tyres and the sealant can’t fix it, you have to buy another tyre ?
venomx is offline
Old 06-11-20, 01:57 AM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Triban Road 7, Benotto 850
Quoted: 402 Post(s)
Liked 215 Times in 137 Posts
Why it's impossible to replace a tube with your current setup? It shouldn't be.
Amt0571 is offline
Old 06-11-20, 02:02 AM
venomx
Quoted: 64 Post(s)
the bike mechanic said it was the most difficult set of rims he’s ever worked with. And it took both of us to do it. Therefore it’s impossible on my own
venomx is offline
Old 06-11-20, 02:23 AM
Seven1816
I have only used Schwable Pro One tubeless 25C onto carbon rims so far, but I have to agree virgin setup is the worst, in my experience it takes two people, 2 pairs of hands to actually mount the the tyre, and I have done 3 pairs of them. Taking them off and remounting is much much easier as the bead will have stretched, if stranded by the side of the road fitting a tube is doeable.
Seven1816 is offline
Old 06-11-20, 02:31 AM
Amt0571
Quoted: 402 Post(s)
Something is wrong there. I'va had some rim / tire combinations that were difficult. In some instances I have broken tire levers. But in any case, it should be something doable at the side of the road.
What are you supposed to do if you get a puncture 50km from home and you can't repair it?
Amt0571 is offline
Old 06-11-20, 02:54 AM
venomx
Quoted: 64 Post(s)
thats what I’m getting at. It’s not possible to do it on my own. And to be fair I don’t go far from home anyway . If i get another puncture I’ll consider going tubeless or getting rims which are easy to put tyres on . Bike mechanic lives near me so shouldn’t have a problem either way
venomx is offline
Old 06-11-20, 02:59 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
For road riding, it isn’t that you get fewer punctures, it’s that the sealant are able to deal with most of them unassisted. You might need to top up the pressure though.
That CAN happen, if the cut is long enough. Often it’s possible to remove the tire, then put a patch on the inside to get some more life out of it.
dabac is offline
Old 06-11-20, 10:19 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
I just bought a new pair of GP5000 tires and thought for about a nano-second about trying the tubeless variety. Then I remembered the video I watched...
zacster is offline
Old 06-11-20, 08:45 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
What kind of rim tape are you using? Switch to a thin/slippery "tubeless" rim tape if you haven't already.
I've come across combinations that were very difficult over the years. I avoid those. Tubeless is not a "solution" for a tire/rim combination so difficult that even your mechanic complains (but it's also possible your mechanic is no good.) Get different tires if you have to. I never carry tire levers, because I can remove all my tires by hand.
FastJake is offline
Old 06-11-20, 10:18 PM
zacster
Quoted: 22 Post(s)
My hands are raw after taking off and putting on tires today without tools.
zacster is offline
Old 06-12-20, 02:14 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
If you get a puncture that won't seal on its own, you'll need to use road bacon. If the road bacon doesn't work (very serious puncture > 1/4") you'll have to insert a tire boot and tube.
Elvo is offline
Likes For Elvo:
Old 06-12-20, 02:21 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
+1
Sealant is first line of defense, bacon strips 2nd line of defense, spare tube + boot 3rd line of defense.
tyrion is offline
Old 06-12-20, 02:56 PM
BritishV8
Bikes: 1979 Bridgestone SkyWay, 1990 Bridgestone RB-1, 2002 Specialized Hardrock Comp, 2018 Soma Smoothie
Quoted: 25 Post(s)
Liked 12 Times in 10 Posts
Are we talking about a road bike, where you might go 50 miles from home? I tried tubeless... specifically Pirelli PZero 700x25c tires on Fulcrum Racing3 2-way wheels. What an expensive mistake!
IMHO, for tubeless to make any sense at all you need wider tires and also wider wheels than I've got. Much wider.
Apparently all "bacon" repair plugs aren't equal - the Lezayne variety didn't well work for me! If you're gonna rely on bacon plugs, you should probably practice using them at home before trying them along a roadside. Once plugged, you should plan on installing a brand new tire at the first opportunity because riding at road speeds on a plugged tire is a very bad idea. Note: if the plug is in the part of the tire that contacts the road,
you'll hear and feel a bump on every tire rotation. That's the road, trying to pull the plug out. Come to think of it... you should probably avoid turns.
You should certainly plan on carrying a spare tube, plus shop towels because you're gonna be a sticky mess when you install them. It won't be a quick job.
venomx... I think a different set of wheels might be a good investment for you, so that you can swap tires/tubes independently and much more easily.
BritishV8 is offline
Old 06-12-20, 03:07 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
I would say so, as the P Zero Velos are not tubeless, but straight clinchers. The only tubeless road bike tire from Pirelli is the Cinturato Velo TLR, which are fantastic (I put about 5,000 miles on a set.) So if you had a bad experience with P Zeroes tubeless, I can see why.
Dynaplugs are designed to be used for the life of the tire, and I have done so. I've plugged tires at under 500 miles, and ridden them plugged until cords were showing at +3,000 miles. Almost everything in that quote is wrong, save for the part about not all plugs being equal.
You also don't need ot throw away a tubeless tire with a hole in it. So long as cords haven't been cut, you can patch it from the inside with a typical tube patch. I've also done that, many, many, many times.
DrIsotope is offline
Old 06-12-20, 11:02 PM
BritishV8
Quoted: 25 Post(s)
I grabbed the wrong name... the tires I tried were indeed Cinturatos. One of them got a sidewall cut on the very first ride. The other lasted longer... but still not very long. They were way too fragile for the roads I ride on.
How can you be sure whether cords have been cut? You're supposed to ream the hole a bit as part of the plugging procedure, so it seems damaging cords is likely.
If venomx needs to remove a tubeless tire and patch it from the inside... well, that's not really solving the problem of hard-to-remove tires, is it? If you've had to patch tubeless tires from the inside "many, many, many times", I can't comprehend why you've put up with them. Not when tubes are cheap, when swapping out a tube should only takes a couple minutes, when tubes don't require sealant, etc.
Old 06-12-20, 11:20 PM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
Why? You also said bacon strips can be left in for the life of the tyre. Seems like en unnecessary extra step if you can just plug it, like you said, with a bacon strip. - I mean why all this work to seal up a system that should just self seal with Stans in the first place and that you claimed to be able to seal for the life of the tyre, with a bacon strip, in the even that liquid sealant doesn't do what its supposed to do?
From my experience, big gashes in ordinary clinchers doesn't repair well with ordinary tube patches. They stretch and the gash opens a little. Ridable in a pinch, but lumpy.
Racing Dan is offline
Old 06-12-20, 11:32 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Sealant is good for +90% of punctures. Most happen and I don’t even know, until I see Orange Seal all over the seat tube when I get home. Plugs are for punctures around 3-4mm around. Dynaplug makes “mega” plugs that will fill 6-7mm holes, but I don’t have that tool or those plugs, so they get patched.
The roads here are absolutely awful, covered in thorns, and equally as much broken glass. As I’ve had to say in every single tubeless thread on this forum, I don’t run tubeless tires because they’re chic or en vogue. I run them because without, I would get a flat a week. On these roads, the choices are armored tires like Gatorskins, tubeless, or buying tubes in bulk. I don’t much care for messing with tubes on the side of the road, and Gators roll like garbage, so it’s tubeless.
I'm not trying to convert anyone. I not a proponent of the “tubeless experiment.” You either need them or you don’t. And when you need them, you’ll know.
Old 06-12-20, 11:39 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Things I’ve pulled out of my tires:
  • staples
  • rivets
  • pallet staples
  • nails
  • screws
  • springs
  • thorns
  • wire
  • glass
Just a few days ago I pulled a 1.5” 16ga brad out of my rear tire. Didn’t even notice it until I got home. Try that with a tube. A year or so back, I rode 30+ miles with a 3/4” #9 door hinge screw stuck in my back tire. Got home, removed the screw, put in a patch, and rode the tire until cords were showing.
Old 06-13-20, 06:10 AM
zacster
Quoted: 22 Post(s)
  • staples
  • rivets
  • pallet staples
  • nails
  • screws
  • springs
  • thorns
  • wire
  • glass
Wow. In all my years of cycling, over 50 at this point, all I've ever found in my tires is glass when I've had a flat. Maybe you need to move to NYC to get some better roads.
zacster is offline
Old 06-13-20, 05:30 PM
fullergarrett
"Broke College Student"
fullergarrett's Avatar
Bikes: 2016 Giant Sedona, 1987 Free Spirit Pinnacle
Quoted: 122 Post(s)
Liked 8 Times in 8 Posts
Here in Missouri, it seems like thumbtacks (the flat ones) and nails are the most common cause of a flat...
fullergarrett is offline
Old 06-20-20, 05:19 AM
venomx
Quoted: 64 Post(s)
When/if I get another puncture I’ll strongly consider going tubeless
Only just got these continental contact travels which are advertised as being very puncture resistant. They’re so fast on road and very good off road too
Does the rim tape play any role in tubeless tyres ?
venomx is offline
Old 06-20-20, 07:55 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Tubeless rim tape does 2 things: First, it provides a seal for all of the spoke holes so that the rim is air tight. Second, it is very thin so that it makes it much easier to install a tubeless, and also a tube type tire on a tubeless ready rim. If you are having trouble installing your tube type tires, check to see what sort of rim tape was installed on your wheels next time you have to take the tires off.
alcjphil is offline
Likes For alcjphil:
Old 06-20-20, 08:45 AM
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
+1. If you are using tubeless rims but not tubeless tape, you are making life very difficult for yourself.
aggiegrads is offline
Old 06-20-20, 11:26 AM
venomx
Quoted: 64 Post(s)
If I need some new rim tape is it easy to remove and fit the new one ?
venomx is offline
Old 06-20-20, 01:19 PM
venomx
Quoted: 64 Post(s)
So I’m less likely to get a flatty with tubeless ?
venomx is offline
