Necessity is the mother of invention
Old 06-11-20, 08:22 PM
Jicafold
Quoted: 360 Post(s)
Liked 129 Times in 89 Posts
So I bought an older big tube Cannondale road bike the other day. This is the seatpost that was in it. Looks like someone really needed a seatpost. Strange but true. Not sure how it is fused together but it feels solid.
Jicafold is offline
Old 06-11-20, 08:30 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
It looks to my like smaller seatpost is jammed into a bigger one? I'd want to see a closer look without the seat attached. Regardless, I would NOT ride that thing. The price of failure could be quite painful.
Rogerogeroge is offline
Likes For Rogerogeroge:
Old 06-11-20, 09:18 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4195 Post(s)
Liked 3,837 Times in 2,295 Posts
Lots of seat posts have a press fit top onto the shaft. This looks like the top was removed (by choice or happenstance) from the OEM shaft and then reinstalled in a cut down shaft. Maybe to get a different diameter shaft?? Maybe to clear an inside the seat tube obstruction?? As long as the top stay in the shaft all will likely be good, if ugly. So the question I would ask is whether the top is well secured into the shaft, or not. From a photo we can't tell that. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-11-20, 09:22 PM
Jicafold
Quoted: 360 Post(s)
Yes, that would be a good explanation. But no seat tube obstruction appears. Not sure if that was the original 2 bolt attachment on top or not. I have seen that pressfit type of attachment before...broken. I suspect this was some frankenbike approach to get a proper size post. I could clean, sand, wire brush, paint, etc., to make it look ok.
Jicafold is offline
Old 06-11-20, 10:07 PM
Rogerogeroge
Quoted: 178 Post(s)
Or you could spend $20 for a new alloy post and ensure you're not anally impaled by a suspect looking component for which you have no knowledge of its history and how it's been modified.
Old 06-12-20, 02:41 AM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Triban Road 7, Benotto 850
Quoted: 402 Post(s)
Liked 215 Times in 137 Posts
It's probably safe, although that post looks extremely short to me (check minimum insertion).
It's also extremely ugly. I'd buy a new post and replace it.
Amt0571 is offline
Old 06-12-20, 07:16 AM
Jicafold
Quoted: 360 Post(s)
So that's 3 votes for safe and 1 vote for unsafe.
Jicafold is offline
Old 06-12-20, 07:22 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
Is your family complete?
Retro Grouch is offline
Old 06-12-20, 08:33 AM
alcjphil
alcjphil's Avatar
Quoted: 1815 Post(s)
Liked 1,693 Times in 974 Posts
But 3 votes to replace. I would make it 4
alcjphil is offline
Old 06-12-20, 09:13 AM
Iride01
Iride01's Avatar
Quoted: 6177 Post(s)
Liked 4,794 Times in 3,306 Posts
I vote to replace the saddle. I'm present but not voting on the seat post.
Saddle looks like it has a little cusioning under the cover and if the top is rounded, I'd be uncomfortable for any ride longer than 10 miles and in pain by 30 miles.
But my butt's not yours, so you decide.
Iride01 is offline
Old 06-12-20, 09:40 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
A professional way to do it is a machined seat post sizing shim sleeve ..
note 2 measurements: Inside and out side diameters.
fietsbob is offline
Old 06-12-20, 09:57 AM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I wonder if sometime in the future when riding over a big bump or pothole on the road, if that top section will get knocked down into the lower section and hide that narrower balck section, and if the saddle will pivot when that happens and cause the rider to lose control of the bike.?
To me it looks a lot like an accident waiting for a place to happen.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 06-12-20, 12:18 PM
Amt0571
Quoted: 402 Post(s)
Cheers
It seems one tube is inside the other. If it slides it will slide down. A PITA, but not really dangerous.
I'd replace the post anyway. It's crap-looking.
Amt0571 is offline
Old 06-12-20, 12:21 PM
Miele Man
I was thinking about if the top portion slips into the lower portion and twists a lot at the same time.
Cheers
Old 06-12-20, 12:26 PM
Amt0571
Quoted: 402 Post(s)
Cheers
I see no reason for it to twist. I don't think it would be terribly dangerous either.
Anyway, as I said, I'd replace that POS in a pinch. A seatpost is not that expensive if you don't want something fancy.
Amt0571 is offline
Old 06-12-20, 01:39 PM
Miele Man
I figure there's a good risk of it compressing and or shifting sideways where the parts are joined. Therefore like you, I'd spend a few dollars and get a proper seatpost.
Cheers
Old 06-12-20, 09:54 PM
Rogerogeroge
Quoted: 178 Post(s)
There is a lot of bad advice on this thread!
It's probably safe??? How do you know from an internet pic? Yeah, that NTRAGER post looks short, and the bottom looks like it's been cut cleanly, so I'm sure the minimum insertion mark is valid. (Min. insertion should be atleast 2.5 times the seapost diameter for a starting point).
^This^ is what probably should have been used to remedy the initial prob. We don't know the life story, and we're judging from a couple of internet pics.
Agreed, or the OP could have just 'buffed it out'
Um, could be very dangerous.
Um, again, don't think? seems? probably safe? Yeah, take our word for it!
Old 06-12-20, 10:03 PM
ljsense
ljsense's Avatar
Quoted: 284 Post(s)
Liked 152 Times in 92 Posts
I'd guess it's a 27.2 carbon post epoxied into a 31.8 or 31.6.
The epoxy is not an issue -- it's stronger than the binding force you'd get from tightening a seatpost collar.
The problems may be the length of the carbon post. And whether it was sanded down to fit.
If you can measure the inserted post and it's still 27.2 and it goes a long way -- like 5 or 6 cm -- into the alloy sleeve, the only issues will be aesthetic.
You should just be able to feel how deep it goes by running a spoke or something similar up the bottom.
ljsense is offline
Old 06-13-20, 05:14 AM
San Rensho
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
The mother of invention was Frank Zappa and his band. Sorry I couldn't help it.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
San Rensho is offline
Old 06-13-20, 06:46 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 460 Times in 362 Posts
It doesn't look like carbon to me. I would highly doubt that it is on an older C'dale anyway.
I tried using a 27.2->30 shim with a carbon post and a carbon frame and could never get it to hold. And yes, I used carbon paste too. I gave up and found an original post for the bike, the same as my own original, except mine stripped the ridges that held the saddle angle. It isn't a great design, nor is 30.0 a great diameter. Only Thompson makes an alloy one but I couldn't find a CF post anywhere in that size except an original.
zacster is offline
Old 06-13-20, 08:43 AM
gearbasher
gearbasher's Avatar
Quoted: 451 Post(s)
Liked 882 Times in 377 Posts
When in doubt...throw it out.
gearbasher is offline
