E-bikes for heavy riders?
Any e-bike recommendation for heavy riders? (120+ kg / 260+ pounds). Are there special designs and models for heavy riders?
Quoted: 882 Post(s)
Liked 821 Times
I would think most MTB-style e-bikes would be adequate. 260 isn't that big. My Haibike, a Yahama-powered hardtail, seems like it would accommodate you easily.
Likes For 2old:
Quoted: 668 Post(s)
Liked 529 Times
I've weighted as much as 260, currently at 235. Like said above, not that heavy. I do like 36 spoke wheels but other than that I don't have issues overpowering bikes.
I just put a Bafang BBSHD on an 80's vintage MTB. Loving life. Sucker can sustain me at 30+ mph.
Only other suggestion is that mid drives put the gearing between the motor and the wheels. This helps the rider keep the motor operating at a more efficient RPM, even when powering up hills at a reduced speed
Likes For Pop N Wood:
"Bafang BBSHD" this seems to be a great choice Pop N Wood ! I am hearing about this one more than once. thank you!
Quoted: 882 Post(s)
Liked 821 Times
BTW, MTB's can offer more upright seating and you can custom fit the stem and bars (with road bikes too), so you should be comfortable (after the ass-breaking-in period). BBSHD is a great choice unless you're more interested in pedaling, then BBS02 is fantastic (my wife and I ride them, but we're more pedal-happy).
Quoted: 668 Post(s)
Liked 529 Times
BBSHD is overbuilt, which I preferred for longevity. Also a bit more heavy and more expensive than the BBS02. Just know that either motor is programmable and it is up to you how much pedal assist you dial in.
Excellent web site with all things BBS related
https://www.******.com/r/ebikes/wiki/bbs_faq
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
These Sondors bikes look good! https://electrek.co/2020/06/23/sondo...electric-bike/
Likes For alloo:
Bikes: 2011 Linear 3.0 XL, Cannondale Adventure 400, Univega Supra Sport, Trek T200 tandem
Cannondale Hybrid conversion
I am close to your size...250 lb and 6’5”.
Last August I had a local bike shop convert my “jumbo” sized Cannondale Adventure 400 hybrid. The frame is built for us big guys and it has a front shock fork and seat post. I used a 750 watt Bafang mid-drive, new brakes, new Schwalbe Ebike tires, shift sensor, Brooks B17 Imperial seat, clipless pedals, and a decent sized battery (48/17) for range.
Original cost of this bike in 2003 was around $550, cost of conversion was around $700. I am very pleased with how well it rides and the performance of the motor. Wen I use my assist, it’s usually in “2” and in the middle gears of my rear sprocket.
So if you can find a regular bike that supports and fits you well, a mid-drive conversion and some other adjustments can give you a very good result.
Good luck!
Good luck!
Very Senior Member
Check out HimiWay - it has a 350 lb weight limit and a RadBikes Cruiser - 275 lb limit. I am trying to decide which one I want. They are similar.
It's better to cycle through life than to drive by it.
Likes For MikeR:
Very Senior Member
I want a Himi !
Quoted: 882 Post(s)
Liked 821 Times
The Himiway seems like a solid bargain. AFAIK, these type of bikes are made generically in China, and you can choose to have your "logo" on them, then bring container(s) in and resell.They made a good choice if the specs are correct.
I am in the same boat and most bikes I have researched are rated for a 240 lbs. rider. For that reason I am looking closely at the YT bikes they have a higher rating. Let us know what you buy.
Quoted: 175 Post(s)
Liked 137 Times
I've seen most ebikes have a 270 lbs limit. So start riding and lose some weight. Even the $1500 ebikes have this weight limit.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
Before getting a fat tyred bike, look into the cost of new tyres. There doesn't seem to be a great selection of street-oriented ones, and most replacements are quite dear.
That seems to apply to the Hemi, as far as the Sonders, I looked at it a lot after it was mentioned here, in another thread. The reason I didn't pull the trigger on it, and it looks great for the money, is the 27.5 tyres. I have that on my current commuter and have found problems, the biggest one is the total dearth of studded street tyres for winter use.
I am in the process of converting my commuter from 27.5 to 26" (I am waiting for the front wheel to arrive). The disadvantages of 27.5 are just too pronounced for me.
BF Risk Manager
Bikes: Road, mountain and folding
Quoted: 21 Post(s)
In terms of weight-carrying capacity and ease of mount/dismount, look at the Tern cargo bike series: GSD or HSD. I am only 200 lbs. but recently bought a Tern HSD 8si with a low step-through height as orthopedic problems from a prior hip fracture are currently preventing me from throwing a leg over my other bikes.
Likes For MillCreek:
Likes For gokhanbas:
Quoted: 175 Post(s)
Liked 137 Times
Another great brand for heavy riders. https://electricbikecompany.com/ up to 380 lbs.
Bikes: Dunlop Special
I would recommend a fat tire ebike or as MillCreek said a Cargo ebike. I guess it depends on what kind of riding you want to do as well.
Quoted: 882 Post(s)
Liked 821 Times
Somewhat interesting report (mostly what we already know) in electricbkereport.com about this subject and some recommendations. Also read about the world's lightest ebike @ 15 pounds plus a smidge.
2old's advice for the Haibike is the best reply on here. Its a quality bike all around and wont give you any grief.
As for all the other Chinesium consumer direct bikes? Dont waste your money. While some have success stories many more do not. I've pretty much had enough of those brands with trying to get parts when they are broken, AND they use proprietary crap on them so I cant use typical replacements..
Electric bike weight limits are usually set in the range of 220-300 pounds (which is 100-140 kg). Some e-bike models, which are designed for specific needs, such as cargo, for example, could carry more weight. This weight limit would normally include rider and cargo weight.
Quoted: 668 Post(s)
Liked 529 Times
Haibikes might be very good bikes, but xenophobic comments aside not sure how these are better than some of the more popular Chinese brands.
