Moto that has seen better days
Quoted: 3810 Post(s)
Liked 6,690 Times
Picked this up from a young feller who gave up after trying to remove a stuck stem and seriously bending the fork blades. Seems like a decently made frame. Early 80s, maybe? Fork is out and soaking in penetrant. Park fork alignment rig stands ready.
Likes For nlerner:
Incredible balancing act getting the frame/fork home in your pannier!
Sad to see the fork like that. Some folks just don't know when it's time to put the hammer away and find a gentler solution. Working on figuring out that wisdom myself...
Looks a bit small for you. What's the plan?
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
1983 Motobecane Jubile Sport
It's a 1983 Motobecane Jubilee Sport with a frame made of some kind of lower cost Columbus tubing, maybe straight gauge Aellle.
About that time, Motobecane, Peugeot and Gitane all brought out lower to mid range priced bikes with lugless construction.
This was different than classic lugless brazing which built up a thick fillet around the joints - see below. Motobecane called their process "INEXTERNAL BRAZING" and their BS marketing artists billed it as something new!
The technique has been used for many years for brazing furniture and lots of other products made of tubing. It entails using "preforms" made of brazing alloy placed inside and/or outside of the joint to be brazed. The joints are then furnace or hearth brazed.
In reality it was an attempt to save money over lugged construction frames to compete against the low cost Asian bikes that were taking over the market.
The reason I've mentioned all this is the paint at the seam where the down tube and head tube meet doesn't look right. The person who applied enough force to bend the forks that much could have over stressed the brazed joints too!!! I'd inspect the head tube joints carefully.
BTW they're not lugs on the head tube, it's been rolled to look that way.
I've never seen a frame failure in the lugless French bikes made that way in the early 80's but there sure were a lot of braze and weld failures in CHEAP department store kid killer bikes before the CPSC rules came out. That was one of the stupid reasons for crash testing bikes....
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Liked 6,690 Times
Ah, thanks, Chas. There is an "inexternal" Columbus decal on the seat tube that I'll get a pic of. And I'll inspect the welds at the head tube. I did notice that the brazing from fork crown to the inside of the fork legs is really sloppy. Just big blobs of material.
Plan-wise, if I can sort out the fork issue, I'm going to build this one up with parts on hand and sell it off on my very hot CL market. I have a couple of replacement forks, but the steerers are too tall for this little thing (and the guy who gave it to me was probably 6', so I'm not sure he imagined actually riding it). I've been searching for a new pandemic project, so . . . I do need to determine what the BB threading is. I'm hoping it's late enough in the marque to be English, but I won't hold my breath.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I re-worked an identical frame for a co-worker some 7-8 years ago to make him a daily rider (he bought the frame off CL). Kind of liked the frame's lightness but decided the fork looked nicer than it was strong, and was appalled with the internal cable passages in the TT that are just holes punched/crimped in the tube! So Crude! But do not remember that the BB threads were Swiss, I think that detail would have registered.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Liked 6,690 Times
Here’s a closeup of the tubing decal:
I played around with the BB, trying some known English cups and some known French cups. I didn’t force anything, but I think the threading might be Swiss. Yuck.
señor miembro
Liked 6,480 Times
Liked 6,690 Times
So the latest wrinkle on this Moto project is routing brake cable housing through the crude channels under the top tube (pic below). One end goes in, but does not emerge from the other hole but just keeps traveling along the inside of the tube. I tried it with an inner wire, but same problem. Any creative ideas?
Disraeli Gears
Gotta think like an electrician . . .
Start with a thread or fishing line (maybe tie a knot or two in the end) fed in through one orifice, with a vacuum cleaner on the other end.
When you've got that through, then move up to a flexible wire (like stainless fishing leader, use the woven thread to pull that through. Hardest part is fixing that to the brake cable housing. You might be able to drill a tiny hole (think eye of the needle) to feed the small wire through, and loop/twist that back on itself; whatever you do, it has to fit through both holes -- only one and then failure means starting over.
If you're lucky, and use strong enough fishing line (Dyneema or Spectra) you might make it work with only that, and no wire. And it's possible you could simply tape it to the housing for some distance.
Pick up that brake adjuster on the mats, or lose it.
Quoted: 5888 Post(s)
Liked 3,471 Times
Given that you're selling this, I'd be tempted to just use zip clips and the brake cable housing externally. I dunno if I'd trust that fork though.
Nice, nice job of balancing that bike on the back of your Bridgestone.
Liked 6,690 Times
Thanks for the ideas, Charles and Miguel. Figured it out by running a length of solder wire (rigid enough to emerge at the other end, where I could pluck it out with a needle nose pliers). I then inserted the solder into the housing and pulled it through.
Miguel, I’m giving up on that fork. Stem is still stuck, and my straightening efforts have improved it, but it’s pretty much a basket case. The frame is currently wearing a 1” threaded carbon fiber replacement that I had in my stash!
Likes For nlerner:
Liked 6,690 Times
Liked 3,471 Times
That bike has serious street cred in the greater Boston market with a carbon fork. Price it accordingly,
Liked 6,690 Times
Requisite basement pic of the work in progress:
señor miembro
Liked 6,480 Times
The carbon fork asks, "any aero levers in the bin?"
Liked 6,690 Times
You know, that did occur to me, particularly with the aero cable routing, but as seen in the original catalog pic that Chas shows above, non-aero brake cabling. Also gave me a chance to hack off the extended ends of some Weinmann levers set up for turkey wings that I had in the bin though I had to use a set of nice Cane Creek hoods I’ve had for awhile. Parts bin Frankenbuilds are the best builds.
Likes For nlerner:
Quoted: 3464 Post(s)
Liked 2,829 Times
good you retired the fork. Was going to ask about the dent under the top tube- answered.
like Chas’ I don’t like the appearance of the head tube/ downtube weld right now... test, don’t guess... would not be good to sell it off and have the head tube start to tear away.
These Moto’s seem to have long top tubes for their size. I have a Champion Team from the 753, Columbus era and the top tube is over 1cm longer than I expected.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Having spent considerable time in Neal's Man Cave, one could bin build a bike out of what's stuck in the dark corners.
Disraeli Gears
Yeah, maybe he should have a parts-finding party in his basement (with social distancing), with props and a T-shirt for the piece that has the best current "completed listings" price on eBay. Neal's probably lost more parts than are in most peoples' hoard-inventories.
Likes For Charles Wahl:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Looking quite good...I was wondering about the "crimps" along the top tube as well as the seat post-BB, I like those details...glad you used the rod idea for snaking the cable, it has always worked for me..just like a plumbers snake you sometimes need to twist/rotate it a little to get it in position.
Looking forward to the next steps...Aero levers as suggested may be the ticket.
Best, Ben
Best, Ben
Liked 6,690 Times
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
That rear triangle is something. Pencil seat stays and majorly crimped chain stays. Quite the contrast to the beefy looking carbon fork.
