Flip Flop safe?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Flip Flop safe?
I expected a Flip Flop hub to have a narrow strip of 1.37x24 with provision for a lock ring on one side.
The other side having only a wider strip of 1.37x24 and no lock ring provision.
I've researched and found pictures of exactly this setup.
My Dura Ace rear HB-7710 hub has 1.37x24 and lock ring on both sides.
Obviously it is designed to accept a cog on both sides, is this still safe & OK for freewheel installation?
For example, I don't wish to damage the LH threads with the freewheel.
Barry
Barry
Your cog is slipping.
There are two kinds of double-sided rear track hubs - fixed/fixed and fixed/free.
There are people who will argue about this until they have a stroke but it's perfectly safe to use a freewheel on fixed threading.
Likes For Scrodzilla:
Quoted: 2952 Post(s)
Liked 3,106 Times
Personally, I don't know why they aren't all fixed/fixed.
Likes For caloso:
Quoted: 4791 Post(s)
Liked 3,918 Times
Yes you can run a freewheel on both sides. The different hubs were made for different audiences. The trackies want a hub they can gear for two different events or to ride to and from the track. The mixed hubs are for people who want to try fix gear but have a freewheel bailout. I'd only known of mixed fixed-free hubs until I asked the Portland fix gear guru if a fix-fix existed. Now I have a bunch of them.
As many of you know, I am a fix gear die-hard. My last singlespeed was my UO-8 up till 1976. Then I put on a fix gear wheel. Never looked back. I've had at least one fix gear in my stable since then (currently 3 of 5 bikes. 2 have fix-fix hubs. Have all the cogs from 12 to 24.)
A little off topic but the one hub that didn't pan out for me was the beautiful fix-fix Miche of their high end boxed set. Not enough available lockring threads using a very track-common Eurasian 1/8" cog. Stripped both sides. Rode Cycle Oregon last fall with no lockrings, (Well, one was on but only for decoration.) As others have said, if you are aware, ride smart and use brakes, not an issue. I blasted down the north entrance to Crater Lake on a 42-12. Only issue was the aching cheeks from the ear-to-ear grin. My all time favorite fix gear descent. And that is a great gear for it.
I've had zero thread issues with the considerably cheaper Miche fix-fixes Some of mine now have many thousands of miles and lots of cog swaps. I do wish their axles had slots with tabbed washers. The lock nuts unscrew. If you sock the hub nut down on the unscrewed locknut, you break it but you won't notice until the broken nut falls off next time you flip the wheel. Never been a ride ender,, but still, Miche, you can do better.
Ben
Ben
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Thanks guys.
Got it, mine is fixed/fixed and I can use it fixed/free with no issues.
Standards are a wonderful thing, which is why we have so many !
Barry
Barry
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
I thought this was going to be a thread on keeping your sandals secure from thieves. I personally just leave mine in the closet but maybe I should be keeping them in the firearms safe? What if someone steals them?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
You used the”F” word. I’m telling dad!
Barry
Barry
Clark W. Griswold
Liked 3,958 Times
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
You can't damage the LF lockring threads with the freewheel, because they are a smaller diameter, and the freewheel fits over them without making any contact. Think about it, how could you install a fixed cog on the inner RH threads, if it couldn't slip over the LH lockring threads without damaging them ?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Barry
