Suntour aRX Front Derailleur Adjustment
Old 06-24-20, 10:32 PM
dwguy
I have a Raleigh Racing USA Grand Prix and it has the Suntour aRX parts on it. I think of the drivetrain is original, but I had to find the original, or a similar, Raleigh crank, since the last owner put some single chainring crank on the front.
Anyway, I was messing with the limit screws on the front derailleur, and there's no way for me to get the derailleur from coming out too far out. I can pretty much push the chain off the big ring, away from the bike, like the derailleur was built for a triple. Was this how these components were? Do I just have to be aware of how far I move the downtube shifters? Or is there something I'm missing?
Thanks in advance all!
dwguy is offline
Old 06-29-20, 09:42 PM
dwguy
No response and I'm thinking this query would have done better with a picture
dwguy is offline
Old 06-29-20, 09:58 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 4072 Post(s)
Liked 1,041 Times in 665 Posts
Your pic shows the limit screw is hitting the plate and the dersilleur isn't pushing the chain off the large ring. The limit screw looks like it can go further in, but it obviously can't. Thats odd.
Is the bottom bracket spindle original? If its shorter than what the crank should use, then the front derailleur may effectively push too far when its simply doing what it's designed to do.
mstateglfr is offline
Old 06-30-20, 03:44 AM
HTupolev
Quoted: 1510 Post(s)
Liked 392 Times in 222 Posts
I don't have any aRX components, but I have a SunTour BL front derailleur from 1983 that has its limit screws in a similar position. On my derailleur, there's a tab that the high-limit screw makes contact with, which is mounted on the parallelogram pivot above the derailleur cage:
It's actually able to pivot on the pivot: when the high-limit screw isn't jamming against it, it can be freely rotated within a small range of motion.
Edit: Here's the derailleur from the side.
The little metal object sitting in the notch below the head of the high-limit screw is the tab thingy.
HTupolev is offline
Old 06-30-20, 06:10 AM
seypat
Quoted: 1524 Post(s)
Liked 414 Times in 297 Posts
Have a mod the thread to C&V. You will get more responses there.
seypat is offline
Old 07-06-20, 09:57 PM
dwguy
Thanks all, esp HTupolev for the pics. I went back and looked and it does look like something snapped off where the stop for the upper limit would be. I guess I'll just live with it.
dwguy is offline
