New bike build
#51
Bikes: Flex, Volkscycle MarkX
Quoted: 26 Post(s)
Liked 12 Times
I'm in Oregon so i'm subject to hills every now and then, At my age I need every little bit of help I can get to keep the ambulance from coming.
#52
Quoted: 1944 Post(s)
Liked 2,164 Times
Well now you’ve changed the subject. You need to see what the current lowest ratio is on your current bike and go from there. If it is 42-28 and you have no issues with hills, then a 34-28/30 should not be a problem for the foreseeable future.
Howevet, I would get a rear derailleur that goes to 34t so that if one day the 34/28 is a little too tall you can swap out the cassette.
John
Edit added: This does open up the large/outer ring size. You need to figure out how much top end you need. With hills, what do you need. I’ve always felt that an 11 speed is great with a 1x so I would try to maximize the use I could get out of the large ring.
If my normal spin-out works with a 42t or 44t I’d reduce chain wrap and go that route. But I’m a relic and have no idea what 11 speed chainrings are out there. Just because a ring ratio works best doesn’t mean it exists.
John
#53
Quoted: 26 Post(s)
Liked 12 Times
Here's what it looks like I have now, I may be a little off, my bike is hanging upside down in the garage. Low gear seems pretty low. 48/37/29 and 30/26/22/20/16/12 for the casette. What do you think, will I be good with the new setup?
#54
Liked 2,164 Times
I would think that a long cage road derailleur rated for 34t would go to 36t.
The other end is the 50-11. Right now you are at 4:1 with your 48-12. If you are using that combo a lot, the 50t might be fine. The biggest question is whether you ride in your 48t or 37t most of the time. If you are in the 37t the majority of the time, then it might be worth your effort to go to a smaller outer chain ring and keep your 4:1 but make it more usable.
You are never going to get to your 37-30 ratio from the outer ring of your new setup, plus you will have a pretty severe cross-chaining, you might be able to mitigate it a little by fiddling with your chainline.
At this point others can chime in with what 11speed compatible outer chainring will fit your setup. Personally, if you are at 48t now, 46t, or possibly less, might be a good way to go.
I would think that trying to find a ring that will keep you in the outer ring for 75% of your rides would be good.
John
#56
Liked 2,164 Times
Nice!
John
John
#57
Quoted: 26 Post(s)
Liked 12 Times
O.K. so I need help with the assembly of the fork. It is threadless with a Star nut that goes into the fork. How do I determine how high to cut the fork? BTW the owners manual is useless.
#60
Liked 2,164 Times
You don’t. At least not yet.
You get a headset and then take the frame to a shop to make sure the head tube and bottom bracket shell are faced parallel and then have them press in the bottom bracket and headset cups/crown race.
Then you get the rest of your parts. There may have a few stragglers, but you don’t build based on what FedEx happens to deliver that day.
John
John
Likes For 70sSanO:
#62
Quoted: 26 Post(s)
Liked 12 Times
O.K. I have taken the frame to the Bike shop. They are going to install it so I do not screw it up. I can install the BB myself. I test fitted the drive side and it slides in pretty nicely, I have a tool coming and can thread that on. it is a 386EVO Wheels Mfg,.
#64
Quoted: 26 Post(s)
Liked 12 Times
The spacing on my rear is 138.71mm. Do I need a 135mm hub or 142mm? There seems to be enough movement for either one.
#65
Why rush the wheels? You aren't going anywhere. The wheels are unconnected to the other parts of the bike. You need a crank, derailleurs, brakes, saddle, bars, shifters, cables, bar tape...
#66
Quoted: 26 Post(s)
Liked 12 Times
I'm not rushing, trying to get it up where I can work on it easily, I have some of the other stuff. Knowing what the rear spacing is will be pretty crucial if something pops up, I'm thinking its 142 because then the thru axle will not be 1/2 to 3/4 out the other side of the frame. I can't install the derailleurs, brakes, shifters, cables until the wheels are on.
#67
Quoted: 26 Post(s)
Liked 12 Times
O.K. According to the distributor the rears are 142 so it's what I thought. I also found these, any input?
https://www.ebay.com/itm/Alex-Rims-7...oAAOSwA7Jegmnh
#68
Liked 2,164 Times
I’m probably not the best person to recommend wheels, but it would be a cold day before I would buy unidentified Alex rims with unidentified Shimano hubs.
Not saying you should buy this one, but it is a wheelset you can actually research:
https://www.ebay.com/itm/DT-R500-Dis...53.m1438.l2649
They are both from Velomine, who typically will provide weights, unless....
John
John
#69
Quoted: 26 Post(s)
Liked 12 Times
I have those under consideration also. The wheels from Alex are RS 470
#70
Quoted: 26 Post(s)
Liked 12 Times
O.K. so I got the pair mentioned by 70sSanO. now I need tires, I'm just going to be riding on pavement 99% of the time but I want a good set what is the forum consensus?
#71
Liked 2,164 Times
I do hope the wheels work out. They seem to have decent hubs and disc only rims which, in theory, are lighter than the same rim brake rim since there is no brake track. There can always be arguments about the number of spokes and the weight of the wheelset. I don't have experience with 142 disc wheels to know where 2100 grams fits for general riding. Obviously less weight further from the hub makes more impact than weight in the hub.
One thing I recommend is to check the hubs bearing adjustment when you get the wheels. I do this with every set I have purchased since poorly adjusted cup/cones will ruin the hubs. From what I gather the process is the same for thru axles as it is for QR. I've done a lot of cup/cone, but if you have not, you may want to have a shop make sure they are setup correctly. Done right, hubs can last a very long time.
John
John
#72
Quoted: 26 Post(s)
Liked 12 Times
O.K. I will do that when they get here. BTW How large of tire can I safely run on that rim?
#73
Liked 2,164 Times
I'm probably wrong person to ask as I'm running 2" wide tires on 14mm and 17mm wide rims.
That said, it depends on the frame as to the tire width that it will accept. Being a gravel type bike, and rims tubeless ready so you're less likely to pop a bead, I imagine 40mm would work fine on 22mm. If it is strictly road, then I probably wouldn't go past 32mm; but that's me and I'm still running 25mm on my 23mm road bike rims. Then again, I have no options to go any bigger on my frame.
John
John
#74
Quoted: 26 Post(s)
Liked 12 Times
Can I run Conti Gatorskins on the rims I got? The rims are tubeless but I cannot find out if the gatorskins come in tubeless or if it matters.
#75
Quoted: 26 Post(s)
Liked 12 Times
So my rims got here yesterday and I notice that stems holes are for the skinny stems, is there a reason for that or can I just have them drilled out for the schrader valves?
