Steel is real
Steel is real
I have been using a Schwinn Tempo from the 80s for work ,is converted to fixed gear so only the frame and bottom bracket are original, today i started to hear a noise , like a cracking noise , only at certain moments like pushing hard and such...check this out, no big crashes on this frame.
It cracked on one of the lugs, its supposed to be Columbus SL. ..too many watts?
Likes For Piff:
Likes For Gods lonely man:
Quoted: 4511 Post(s)
Liked 6,378 Times
So only 30+ years out of it?
BB shell and lugs not Columbo so..
Maybe not destined to live forever as a fixed gear.
Yep, probably too many watts, for this one.
Liked 6,378 Times
Most of them still going strong.
Likes For merziac:
Quoted: 800 Post(s)
Liked 753 Times
An early/mid '70s super course would make a fine fixed gear. Straight gauge 531 frame and hi-ten forks/stays makes for a stiff frame (yet comfy given the long wheelbase), and the rear dropouts are already 120mm. And with all the schmutz (components) taken off, I bet it'd come down to around 22 pounds fully built. Still, not exactly lightweight
You'll likely have to take it into a frame builder to get it straightened as well. But I think they ride real nicely, and it'd be worth a try if you see one in your area that looks to be in alright condition. Definitely inspect the lugs for gaps.
Likes For Piff:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Likes For clubman:
Quoted: 1199 Post(s)
Liked 1,355 Times
The Tempo heart broke when you converted it to fixie. This is the evidence of its broken heart. Just kidding. Good thing it didn't completely break off and cause injury to you.
Likes For malcala622:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,483 Times
Took out my 1960 Paramount the other day. It was real ... fun.
I spread the frame to get a 6-speed cluster in there. I need gears to go fast and climb hills on my 60-year old steel road bike.
Likes For SurferRosa:
Quoted: 874 Post(s)
Liked 2,287 Times
Wow , I have never seen a bottom bracket shell crack like that. I am glad you are ok, sometimes frame failure leads to injury.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Your guads are simply too big
Liked 6,378 Times
Not my quads, maybe Gods lonely man
Thanks, now that I think about it, there were a few moments were total failure would of been nasty, I was spinning downhill and I kept hearing the cracking getting louder and louder, scary.
Quoted: 3810 Post(s)
Liked 6,694 Times
Steel is real breakable.
Likes For nlerner:
Quoted: 2363 Post(s)
Liked 1,749 Times
Liked 6,694 Times
Quoted: 1627 Post(s)
Liked 630 Times
Sad But yeah, it sets you up for a New Bike Day.
I'm trying to figure out what caused that weird pea-sized void in the BB shell casting, above the big crack line. I've seen broken bottom brackets before, but I've never seen THAT.
If you're tall, I have an '87 Tempo frame the will be on the chopping block soon. First photo in this thread: https://www.bikeforums.net/classic-v...ger-frame.html
Quoted: 767 Post(s)
Liked 1,898 Times
Dy
Yeah, clearly another case of too much spinach.
Still, as you say, 30 years ain't bad.
Looks to me like they cheaped out on the BB, which is where the failure occurred. It's a little odd to see such a cheap looking BB shell on a Columbus bike, but then it was always pretty common for many bike companies to save a few pennies where they thought no one would notice. When I was wrenching I used to judge bike companies at least a little based on how many cheap components and parts they would sneak in.
Quoted: 378 Post(s)
Liked 1,409 Times
All this stuff is just on loan, anyway.
It’ll end up in the paper-thin layer of the Earth’s crust that will be remnants of man.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
As for the "void" area, I suspect that's probably a paint defect.
Quoted: 4722 Post(s)
Liked 3,036 Times
Fatigue failure, plain and simple. Likely a combination of the BB shell design and excessive heat during application. Excessive heat lowers the endurance limit, while the design causes stress risers. This combination can end up in a region where typical forces will eventually cause fatigue failures.
