Velocity Dyad ERD=598.5?
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
I am planning to build a front 622 wheel with a Velocity Dyad rim. Ideally I would measure (and I will), but I would like to order the rim/spokes/nipples/hub in same order. Most sites list ERD=596 (including Velocity), but FreeSpoke (ksoterz.com, 2013) gives 598.5 for the US version, with a specific statement that it changed from the Australian version of 596.
This seems to be a common rim. I would be grateful if someone knows the number and could verify. Thank you.
ERD is the diameter at the spoke head seat in the rim. ETRTO # is the tire bead seat.,
ERD is an input in spoke length calculations.. hub spoke hole diameter is the other end..
Know nothing of these specific variations from alternate competing sources..
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times
Simplest method: lay rim on flat surface.. stretch METAL tape inside from valve hole to seam.. 32nd of inch is .032.. mm is .039.
Do same at 90 degrees from valve.. do all over again till confident you have correct in inches.. 700c usually ~ 23-24".
Take your inch measurement and divide by .03937 (1 mm) gives IRD. I call inside rim... IRD... ---->ADD 8mm normally for rim thickness, nip head and spoke stretch. IRD plus 8mm gives ERD.
Rohloff manual shows a way to measure your self.
you put in 2 spokes of measured length, on opposite sides of the rim like 12:00 & 6:00
and with a caliper you measure the distance between the 2 spoke hook ends...
those 3 numbers = the ERD
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I just built a wheel today with a Dyad. Measured it at 597. But measure yours to be sure. I have seen variances.
Edit to add. Actually, my measurement confirms the spec from Velocity site. https://www.velocityusa.com/product/rims/dyad-622
Likes For Dan Burkhart:
Quoted: 189 Post(s)
Liked 106 Times
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Effective Rim Diameter is the distance from the end of one spoke to the end of the other spoke at 180 degrees in and already built and functional bicycle wheel.
...hence why many builders will use spokes of known length with nipples set and a caliper to emulate where the ends of their spokes will be for a wheel they are trying to build.
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 189 Post(s)
Liked 106 Times
No it is NOT!
=8-|
=8-|
