Can I use rim brakes on a disc brake wheel?
I would like to buy normal wheels for rim brakes since rim brakes are way cheaper than disc brakes. But on my journey looking for the right wheels, I keep finding more disc compatible wheels than normal wheels, and they are cheaper. So can I just buy these wheels and use rim brakes, or will it destroy the wheels or something? (https://northwestbicycle.com/product...hoCdUgQAvD_BwE)
Quoted: 336 Post(s)
Liked 309 Times
No. You have to use a rim-brake compatible rim.
You cannot put rim brakes on the Brand-x frame you are getting though. That requires discs.
Likes For aggiegrads:
Disc only rims often forego a brake track to be slightly lighter,
but there is no reason why a disc brake hub wheel cannot be built with a rim design capable of being squeezed between brake pads..
Suppliers to bike shops produce wheel of their warehoused parts priced reflecting wholesale costs.
so come ready built for less than the retail price of the parts separately..
Quoted: 350 Post(s)
Liked 122 Times
I wouldn't imagine that you'd get good grip with brake pads/blocks if the rim wall surface were curved. Most of the disc brake rims that I've seen are really curvy. Although some models that are made in both rim version and disc version have flat/angled walls, with the only difference being a CNC'd vs non-milled anodized surface.
Likes For tomtomtom123:
Quoted: 645 Post(s)
Liked 797 Times
quite likely - you’ll certainly abrade off any anodizing or paint, the rim section that you’re braking on may not have sufficient thickness to withstand long term use as a brake track. The wheels you linked to don’t look like they have an actual flat brake track, so you’ll get lousy braking, and to make use of any decent amount of rim with these, you have to have the brakes clamp dangerously close to the tires. All in all, this is a bad idea - for your rims, your brakes, your braking, your tires, and your face, if you either can’t brake efficiently or your brake pads wear through your tire.
Likes For Litespud:
cross section of disc only wheel rims are more triangular than box shape
Sun CR 18 rims are fine.. and cheap .... the extrusion die was paid for long ago..
get a wheel built with those..
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Just because the wheel is less expensive than the alternative doesn’t mean that it will work. If you buy it and it doesn’t work, it’s more expensive because you have to buy the wheel set twice. Buy the right wheel for rim brakes.
As for price, look around some more. Jenson USA has a wheel set for about $100
Stuart Black
Stuart Black
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Liked 4,218 Times
There is no indication that those wheels are disc-only. The wheels are disc-compatible - they can be used with disc brakes because rotors can be added to the hubs. But, unless the rims are described as disc-only, you should be able to use rim brakes. Two of my bikes have disc-compatible wheels and each bike uses one disc brake and one rim brake.
Stuart Black
Stuart Black
Quoted: 6193 Post(s)
Liked 4,809 Times
If your bike has rim brakes, you need to buy wheels with rims made for rim brakes.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
But, back to OP’s first post, disc compatible doesn’t mean disc only.
