homemade rim strip easy
I was rehabbing a really old bike yesterday and was out of rim strips and didn't feel like running to the bike store so I made one. Took about 10 minutes. I took and old innertube which most people have or can get free from any bike shop. I hooked it to my vise so I could easily stretch it out and cut it. Then I cut a long skinny strip from it being careful to follow the seam lines so it was straight. Then I stretched the strip along the wheel to get correct length allowing 1" extra. I took some thread and sewed the overlapping one inch with a few quick stitches and punched a valve hole with my paper punch. Voila worked fine and stronger than the flimsy usual rim strips.
Likes For cmcanulty:
Quoted: 5793 Post(s)
Liked 2,585 Times
I guess we all define easy differently.
If I need rim strips or tape, I make the effort to hike upstairs to the bathroom, open the cabinet and swipe the roll of cloth surgical tape from the first aid supply.
The hardest part is remembering to replace it.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 2604 Post(s)
Liked 1,933 Times
I'll give O.P. cheap, but I have to agree with FBinNY on easy.
Really easy would be having the spare rim tape float up to the top of my spare parts box when I need it.
Likes For pdlamb:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Rubber is too bulky for some tight fitting tires. I use two layers of 10mm kapton tape from eBay. Super inexpensive.
Likes For SurferRosa:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Rim strips are cheap to begin with. I'd rather spring for an extra bick or two, be able to thrown them on in 10 seconds and not worry about flatting because my homemade strip gave up the ghost at an inopportune time.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
one problem with using an inner tube as a rim band... Spokes poke holes in INNER TUBES, which is why we should all install Actual Rim strips.... or Medical bandage tape...
Likes For maddog34:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
back in my day we used packing tape. I still am using a wheel from the early 90's that has had the same piece of packing tape on it since probably 1993.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
I've used red electricians tape with good success. Not sure if it's stronger than standard black electricians tape...
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
+1 but I now have three different widths of Kapton tape for various rims... it adds up. Works great, however.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Sr Member on Sr bikes
Likes For _ForceD_:
Quoted: 4410 Post(s)
Liked 1,566 Times
I cover every spoke hole with a Tricot-Mesh Band Aid™.
Quoted: 968 Post(s)
Liked 1,631 Times
That's allot of work. Its gonna work well...
I use High Temp Wiring Loom Harness Self-Adhesive Felt Cloth Electrical Tape (Amazon). Its cheap. I keep several rolls in the beer frig and no longer worry about having the right size rim strip.
It also works good for Bar Tape.
Man... I am such a cheap bastard too...
Quoted: 569 Post(s)
Liked 588 Times
Never had a problem with two layers of cheap 10mm kapton tape which stays in my bike tool box.
Quoted: 2338 Post(s)
Liked 2,827 Times
I am still a velox cloth tape only guy for tubed setups
Likes For squirtdad:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
I'm with maddog on this. The inner tube might look the part but there's nothing to keep it from poking into the spoke hole like ... an inner tube.
Likes For shelbyfv:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
While I don’t prefer them, I’ve used a lot of rubber rim strips in the past. They aren’t much different than a tube section. They also fail for the same reason, but take several years to do so unless your spokes are too long. Other than Velox I’ve used several kinds of tape, generally without issue. It’s even easier on double walled rims where you just have to bridge the holes.
Hello
Fiberglass Filament tape
To the OP, Kudos, for a low/no budget solution, and making things worth, with what you got.
Rhapsodic Laviathan
I've had wheels where the previous owner used duct tape. I usually use electrical tape in a quick need of a rim strip. I was at the co-op last month and they didn't have any, so I used a rubber rim strip on top of the rubber rim strip on one wheel.
Quoted: 839 Post(s)
Liked 1,064 Times
Yes to packing tape (with fiberglass filament). It has no stretch. Is, latitudinally tear resistant. Buy a wide roll as it is easy to tear straight longitudinally, so that one roll serves different rim bed widths (perfect custom width every time).
Cantilever believer
Quoted: 536 Post(s)
Liked 1,841 Times
At Recycle Your Bicycle, we go through rim strips by the hundreds in just one weekend, and we just heard our distributor is out of stock on some sizes UFN.
I've tried making rim strips out of old (next size down) tubes, but my experience in trying to cut or punch a Schrader-size hole without creating a plane of weakness that eventually tears has not been good. We can go to the ol' "3 loops of inexpensive electrician's tape", but were hoping there might be a better option. And no, our budget is nowhere near that which would allow the use of "real" cloth rim tape for hundreds of bikes.
Do you use the 3/5", 3/4", or 1" width? The 3/4" (18 mm) looks like it would be the most useful width. By my calculations, we could do about eight 26" rims per roll.
Likes For JanMM:
Passista
Quoted: 868 Post(s)
Liked 721 Times
BITD we used to make rim strips with inner tubes, gluing the ends instead of sewing. Worked OK on single wall rims/low pressure tires, but not on double wall/high pressure, as the tube would force the strip into the spoke holes.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...Kapton tape is pretty cheap, and it comes in various widths, in bulk rolls. I used to use Velox, but Kapton tape is cheaper, and it works a little better.
Likes For 3alarmer:
Quoted: 4806 Post(s)
Liked 3,932 Times
That inner tube strip might expand into the spoke holes in box section rims. I thought the rim strip's job was to prevent that. (Big fan of the Velox strips and their shelf life seems to be near forever so I have no excuse for not being stocked up. Except during COVID, choices were so slim I bought wide rolls knowing I was going to slice them to size with a sharp knife.)
