Alexrims Question
Alexrims Question
I have an eight-year-old specialized hard rock. It has an Alexrim and it’s marked HRD double wall 629 x 17. I don’t see any other markings on the rim. There’s a maxis tire that says tubeless ready.
How do I know if the rim is tubeless ready?
There’s nothing on Alexrims website and specialized is completely unhelpful organization.
Likes For bboy314:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
What size is the tire?
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
The ISO is the most useful number in all of this because the sizing can be quite variable as if I said 26" that could refer to potentially 4-6+ different ISOs whereas if I list the correct ISO it will only refer to that one size and make it easier.
They were making a joke on the sizing issue not saying you wanted to go to mars but because we cannot get simple numbers and math correct we cannot go to Mars. However back to your question more than likely the 8 year old bike at the lower end to bottom of their mountain style range is NOT going to be tubeless ready. These days you can get a bit luckier in that but back than it was unlikely those bikes would have them however with the correct tubeless tape and tire you can sometimes get older rims to seal but in the end I wouldn't put a ton of money towards the bike especially if the tourney equipped version just ride it till you can get the bike you want and convert that to tubeless. Tubeless is fine it is not a bad thing but spending a lot of money for the bike is not really a great financial decision. I generally would keep a bike like that running safely as cheaply as possible till I could buy the bike that better suits my needs.
Likes For veganbikes:
Likes For pjoc:
Clark W. Griswold
Liked 4,000 Times
Tubeless was a thing but it was less common and still is less common on the lower end bikes but will probably spread at some point. However I ride with tubes and don't really mind. I don't find tubeless to be that important. For a mountain bike I want to buy one with a good air suspension at the front and then a good drivetrain and brakes but usually they will all come with the better air suspension.
