How do I get these shift-grips off?
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
this collar looks like it was wrestled on there, and it’s stuck tight!
Quoted: 809 Post(s)
Liked 1,018 Times
I might try a hammer and drift first. If that doesn't work and you are not looking to preserve the shifter, then you can use a hacksaw or Dremel to cut through the aluminum body of the remaining part of the shifter.
Quoted: 1074 Post(s)
Liked 295 Times
BITD there was a twist shift made for the ends of drop bars. I have a pair. Don’t remember the brand. An American one. But no undue force required at assembly.
Perhaps simply galling and/or corrosion are locking parts together?
Liked 295 Times
Looking at the change in colour fore/aft what’s been assumed to be the mounting ring, I wonder if those might not mount as bar end shifters - by an expander inside the bar.
Have a look at the end. Pry off any cap if needed.
Quoted: 684 Post(s)
Liked 370 Times
It looks like you’re right, but this was supposedly all pulled off an early 90’s touring Cannondale. I know those ‘Dales came with drop bar shifts, and I find it hard to imagine someone wanting shift grips so much to have hammered them on.
Quoted: 237 Post(s)
Liked 83 Times
Don’t think so. I’m not aware of any flat bar twist shift where the cable exits along the bar.
Quoted: 684 Post(s)
Liked 370 Times
That worked...
Likes For Chr0m0ly:
Quoted: 684 Post(s)
Liked 370 Times
And it’s going on this:
https://www.bikeforums.net/classic-v...ld-thread.html
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
I was going to reply "BFH."
That's what it was.
That's what it was.
Commence to jigglin’ huh?!?!
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
I was going to suggest cutting the bars if needed. Maybe those are the pretty rare early SRAM gripshift that could be seen on Motorola's bikes at one point. It seems like the window on the road vers closed quickly when they realized their future was in mountain biking. I've only seen those in person that were broken. https://www.bikemag.com/blog/exclusi...ged-the-world/
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Those were first-gen Grip Shift. They're pretty specific for brand and number of cogs; there were Shimano 6-speed and Shimano 7-speed, and SunTour 6-speed and SunTour 7-speed. I think that was all.
OP,
Your gripshift resembles the first generation but it's not. You had to drill holes in the handlebars of The first generation. Also the first generation used a different type of shifter mechanism altogether.
I have the original on my '86 Ironman.
