New Chain Recommendations
Old 01-05-20, 08:46 AM
Kabuki12
Quoted: 874 Post(s)
Liked 2,287 Times in 1,278 Posts
I ride vintage racing bikes and yesterday I replaced the chain on my Medici Pro Strada. I only recently acquired this bike and by all appearances it is a very low mile bike with no rust. I noticed the rotten tires first thing and thought the bike had been sitting for a really long time , AND the grease in the bottom bracket had solidified. The anodized Mavic wheels had zero brake rub and the paint is very nice. After cleaning up the bike I was still not happy with the bike. Oh , it was a blast as far as handling and speed , but when I was in low gear , it felt rough as I really pedaled hard up the hills. The cogs were not worn and the chain rings were like new. I took it to my local bike shop yesterday and Mark put it on the stand and immediately suspected a worn out chain! He had a gage and it only took a few seconds. I chose the KMC chain as it was very close to the original width of the original chain. This is important when running 5 or 6 speed free wheels , too narrow and the chain will slip between gear changes( don’t ask me how I know ) . I am so stoked that Mark figured out the problem . I have never had a chain give this symptom before where it feels like the bearings in the BB are bad. Joe
Kabuki12 is offline
Old 01-05-20, 10:17 PM
DOS
DOS's Avatar
Quoted: 253 Post(s)
Liked 69 Times in 56 Posts
Originally Posted by bpcyclist
Yeah, read that. Had not heard of YBN before. Here is one.https://www.amazon.com/YBN-Speed-Cha...g-goods&sr=1-3
I took the plunge.It just arrived today.Time will tell if the Ti Nitide coating really offers the longevity they promise.
DOS is offline
Likes For DOS:
Old 01-06-20, 08:14 PM
Kabuki12
Quoted: 874 Post(s)
I know from experience that titanium nitride is excellent for wear resistance. It also has some lubricity properties that would be favorable for this application. Although there are other PVD coatings that would be better. I would like to see AlTiN with a molly coat , now that would be a good chain! Joe
Kabuki12 is offline
Old 02-12-20, 09:05 PM
randallr
Bikes: 2017 Gunnar CrossHairs Rohloff, 2022 Detroit Bikes Cortello
Quoted: 131 Post(s)
Liked 155 Times in 89 Posts
Originally Posted by randallr
Wipperman Connex 11SX is going to be your longest lasting choice due to minimal corrosion (it's stainless steel). I run their 8SX and change out chains a lot less often than I used to with SRAM PC870.
And here's some data to back that up:
https://www.connexchain.com/fileadmi...ments-2018.pdf
And now one of the main dealers for Connex (Cantitoe Road) has all their chains at 20% off (starting about 10Feb2020). I just placed an order for 7 ea 8sx chains, which I expect will give me a total of 25000 to 28000 miles
randallr is offline
Old 02-13-20, 08:25 AM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
How's that chain working out?
Rides4Beer is offline
Old 02-13-20, 06:39 PM
DOS
DOS's Avatar
Quoted: 253 Post(s)
I haven’t installed it yet. Trying to get through til spring on my current chain.
DOS is offline
Old 02-14-20, 09:55 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1097 Post(s)
Liked 559 Times in 446 Posts
For TiN to be of value, the coating has to be applied to certain critical areas, like the ID of the roller and the holes in the inner plates, or the pins. TiN on the outer plates, where is looks pretty isn't of much value.
I just measured a popular KMC X11.93 chain over it's full length and found substantial elongation, compared to my Campy chains with the same my mileage that had no significant elongation. Elongation that creates a change in pitch is entirely due to the wear between the pins and the inner plates. The only way to measure it properly is between the pin center lines, not between the rollers.
A chain can show little elongation, but still be extremely worn. I dissected a Campy 10 chain, many years ago, that was meticulously maintained over 6,000 miles of use. It had very little elongation - not even .25%, but the wear on the hole in the rollers was huge, the roller ODs significantly worn and side clearance between the inner and outer plates was twice that of a new chain. I now take measurements of the space between rollers, to get a better idea of when to toss a Campy chain. That one should probably have been tossed a 3,000 miles. With the different wear patterns between brands, there's no specific measurement that gives the user any assurance that the chain was completely used before it was tossed. Most chain checkers add roller wear to the true elongation. Those that don't tell you nothing more than a check with a precision 12 inch machinist's ruler.
Rather than toss chains prematurely in an attempt to avoid new-chain skip, I alternate the use of several chains. Even a few hundred miles of use can make the difference that avoids the new-chain skip problem.
DaveSSS is offline
Old 02-15-20, 08:54 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
That article had me looking thru an online etailers listing. Hadn't heard of YBN, so what else is there? A run thru Universal Cycles pages, you can get in 11speed, chains from all sorts of (to me) obscure (or at least didn't know they made/sold chains) companies.
FSA Team Issue chains (only $25)
Gusset GS-11 chains.. over $50 - putting it in a similar league to YBN's normal retail or Campy Record
Sunrace still makes chains evidently
Sy Reene is offline
Old 02-15-20, 10:14 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
No complaints at all about FSA Team Issue-- I put on a decent amount of miles, so $ per mile is significantly more important to me than possibly saving a third of a watt.
I do a two chain rotation on each bike, with two bikes roughly splitting my annual mileage. Buying the cheapest 11-speed chains I can find has me spending $80 a year on chains, and it's usually a cassette every other year.
I've used Connex (Wippermann,) SRAM, Shimano, FSA, and KMC. They all last the same mileage, within about 10%. I buy whatever's cheap at the time. Brand doesn't seem to matter.
Currently running the FSA chain, as they were $16 each some months ago (now $27 each.) The cheapest SRAM, the PC-1110, was out of stock for ages but now back at it's $15 pricepoint, and I've never gotten less than 3,000 miles out of one.
The same I've gotten on every chain.
DrIsotope is offline
Old 02-15-20, 12:36 PM
August West
Quoted: 152 Post(s)
Liked 173 Times in 105 Posts
I use YBN quick-links since they are advertised to be good for 5 uses instead of 1 like everybody else which adds up pretty quickly if you wax your chain and rotate through 3 different chains. Molten Speed Wax sells their products and their chains aren't cheap but are suppose to be good.
August West is offline
Old 02-15-20, 07:42 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
I use the same quick-link for the life of a chain, removing and reinstalling it at least 10 times. It's fine.
Likes For DrIsotope:
Old 02-16-20, 06:48 PM
Rides4Beer
Quoted: 733 Post(s)
I was thinking about trying it out when I need a new chain for the new bike, because it's the only reasonably priced black chain I've seen. Would look great on the new bike with a black sunrace cassette.
Old 02-17-20, 09:44 AM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
Black chain and a black cassette screams "I'm cheap".
noodle soup is offline
Old 02-17-20, 10:36 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
OTOH, black rotors...
Sy Reene is offline
Old 02-17-20, 12:05 PM
Rides4Beer
Quoted: 733 Post(s)
How is that when none of them are cheap? I can get silver cassettes and chains for half the price of a sunrace cassette and YBN chain. lol
You don't think black would look good on this?
Well, black arms at least lol When I get new wheels they'll have RT-81s, clean and simple.
Old 02-17-20, 12:12 PM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times in 439 Posts
Hi, gang. It is time for a new chain on my 2018 BMC SLR02 with 105-5800. The current chain is a 105 FC-5800 chain on an 11/28, 50/34, 172.5 setup. Quite happy with how the chain has performed, though I am certainly no sort of bike guru--I just ride a lot. I don't race, I do put up quite a few miles (7200ish for 2019). Shimano is of course out now with their 105 R7000 stuff. Wondering if I should go with that, or look at Ultegra or the Dura Ace option. I do quite a bit of climbing--it is quite hilly/mountainous here in Western Oregon. Conditions here usually later October through and into May are extremely wet and grimy. It can literally destroy a bike, if you don't take care. I clean the drivetrain farily well after every ride and very thoroughly once a week without fail and keep it generously lubed, so I do think I am basically doing my part. It is not making any noise--it is utterly silent, but it is time, based on miles.
Anyhow, would appreciate recommendations on what my next chain should be. Many thanks for taking a minute to help me out.
Wippermann Connex
eduskator is offline
Likes For eduskator:
Old 02-18-20, 09:44 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
I resemble that remark! LOL
Reading comprehension on my part..."black cassette"....carry on! LOL
jadocs is offline
Old 02-18-20, 10:32 AM
noodle soup
BITD, all low end bikes had blackish/dark brown freewheels and chains, and the new black chains/cassettes look about the same.
this is an example
https://www.amazon.com/SunRace-Speed.../dp/B00XIFI9LQ
Old 02-18-20, 11:13 AM
Rides4Beer
Quoted: 733 Post(s)
this is an example
Gotcha, I haven't been around bikes long enough to know any previous trends.
Likes For Rides4Beer:
Old 05-10-20, 08:48 AM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times in 46 Posts
Reviving this thread. I'm about to replace my Shimano R8000 cassette and am considering the YBN or Shimano Dura-Ace chain after reading the Cycling Tips article. I'm curious if anyone has personal experience with YBN and the Ultegra cassette. Comments appreciated.
Robert A is offline
Old 05-10-20, 11:49 AM
SlvrDragon50
Quoted: 45 Post(s)
Liked 13 Times in 9 Posts
Update on the TiN? I know TiN works wonderfully on my firearms. As wellas Robar NP3.
SlvrDragon50 is offline
Old 05-11-20, 06:31 AM
eduskator
eduskator's Avatar
Quoted: 988 Post(s)
What I'm getting once my current KMC chain is dead (efficient & long lasting):
https://www.connexchain.com/en/11-speed-chains.html
https://bikerumor.com/2018/01/29/wip...lasts-longest/
Old 05-14-20, 10:31 PM
Robert A
Quoted: 562 Post(s)
What do you gain by getting a different brand than from your groupset manufacturer?
Robert A is offline
Old 05-15-20, 06:47 AM
eduskator
eduskator's Avatar
Quoted: 988 Post(s)
Better efficiency & lifespan.
Old 05-15-20, 12:25 PM
Robert A
Quoted: 562 Post(s)
Enough improved efficiency relative to, say, the Shimano DA chain? I read that there's a 1/2 watt difference and wonder if this is really worth the bother. But if there's better shifting or a smoother experience, then that's something else.
Robert A is offline
