Extended range Chorus cassette
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
I'm considering putting on a newer HO model Chorus RD (11s) midcage which has 32-rear capability. since there is no such thing as a Chorus 11s cassette with 32 tooth large cog, is there anything I could accomplish by frankensteining a Chorus 12-29 cassette (which I have) with a Potenza 11-32 cassette to get a 12-32 cassette?
I'm not sure which comes with which triplets vs. single cogs?
Likes For DaveSSS:
Advocatus Diaboli
Liked 1,532 Times
Good idea as well. I guess what I'm wondering, is what is the difference in materials or weight or quality between Chorus, Potenza or Centaur for that matter. If I already own a pretty fresh 12-XX Chorus cassette, is it a better idea to use the big cog end of a cheaper cassette to complete?
The 8-9 sprockets must match. Campy has letters assigned to them. If they aren't the same on both cassettes, the shifting will suck.
Quoted: 2026 Post(s)
Liked 1,096 Times
The differences will be minor and of no practical consequences. The more expensive cassettes will be a bit lighter due to the larger cogs being joined on a common spider and the most expensive like Record having a some Ti cogs. Otherwise is mostly a shinier finish and higher cost. I've used both Chorus and Veloce 10-speed cassettes and saw no difference in either longevity or shift quality between them.
Advocatus Diaboli
Liked 1,532 Times
Thanks all. It is interesting to note the cost difference between Centaur and Potenza, with a Potenza 11-32 cassette about double the cost of a Centaur. Can it be expected that Centaur is going to be much more prone to rusting? At least for potenza I find reference to nickel-chrome finishing that is absent in Centaur descriptions.
Never had an issue with any Campy cassette.
Advocatus Diaboli
Liked 1,532 Times
FWIW, I did a bit of digging into the spare parts catalog from Campy. The 11-29 cassette for both Chorus and Centaur, for the largest cog triplet on both (23/26/29) have the same exact specified part number listed (11S-369). So, I'm guessing I could purchase the Centaur 12-32 cassette, and marry its largest triplet (25/28/32) with my existing (pretty new) Chorus cassette. The downside is a larger gap than I'd have just using the full Centaur cassette as I would have a jump from 21 to 25, whereas Centaur has a 22 as the cog following the 19-tooth.
Anyway, if there are material/finishing differences, it must be in the smaller cogs between Chorus and Centaur.
