Cheap cables failed
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
Cheap cables failed
*Edit*
I think I did this with poor cable routing, I'm going to try with slacker cable bends.
I installed this cheapo brake cable and the housing split before I used it.
I have more housing from the kit, and I could redo it, but I have safety concerns.
Should I just get a jagwire kit, or give this one more shot?
And anyone ever see this kind of failure before?
Quoted: 293 Post(s)
Liked 218 Times
I have used inexpensive housing without an issue for years and thousands of rough miles. I have also used quality housing on non-commuter builds. Honestly I never had an issue with either one. Perhaps there was just a defect in that particular spot?
Quoted: 1088 Post(s)
Liked 1,205 Times
Is it the Schwinn or Bell brand stuff, or even cheapo-er? Just curious, because I have used the Schwinn set on a couple of bikes with no issues. I recently bought a Jagwire kit for $17 shipped on eBay, including cables, housing, and ferrules for shifters and brakes. (Shifter cables are stainless, but brake cables galvanized.)
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,285 Times
Is the OP saying that the metal coils of the housing collapsed?
Or, was the covering pushed back at the ferrule, then buckled and split?
I've bought cheap housing (generic off ebay) where the vinyl covering was prone to splitting, but in my life I can't recall ever seeing a coiled cable housing collapse on it's own where it wasn't severly stressed off of it's lengthwise axis.
Do we get to see what's under the split vinyl covering?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3867 Post(s)
Liked 6,452 Times
Death fork? Naaaah!!
The bend to the stop is rather abrupt. Just say'n....
Top
Top
Likes For top506:
Quoted: 684 Post(s)
Liked 370 Times
It's the vinal, not the coil.
The split is at the bend, I think my top tube wrap has pushed it into the edge of the seat lug.
Sounds like a redo, with a gentler bend, and not wrapping the cable past the braze on might do it.
This is the kit,
https://www.amazon.com/Yakamoz-Unive.../dp/B07GCK7BG1
I've used the Schwinn kit before, but this seemed like it might be better. 🤷♂️
This is the kit,
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
+1, came here to say the same only to scroll down and see Top beat me to it. That does seem awful abrupt. I normally try to run about an inch more slack in mine to arch about a half an inch above the binder, if not a little more. Tubes prefer gentle arches over taught runs.
@SurferRosa thanks for the link. I needed something like that for my personal bikes. I buy this for all my lower-mid quality flips, it handles all shifting and brakes and actually works with the tighter-tolerance cable-end Simplex shift levers. Under $10 to cable an entire bike and never seen failure like OP is posting. https://www.amazon.com/gp/product/B00L8NDVD6/
Liked 1,285 Times
Toptube wrap? That's going to complicate cable servicing, like having housings hidden along the bar.
But, for a bike that appears to go around in public wrapped with tape, is the split in the vinyl covering even an issue, cosmetic or otherwise(?).
Perhaps more tape is the answer(?).
Sorry, I couldn't resist. Having said that, I haven't lived in NY in a loooong time.
Quoted: 684 Post(s)
Liked 370 Times
I'm going to redo it, when I get the cable off, I'll post a snap of the inside, but it's just coiled steel, nothing to amazing.
Likes For Chr0m0ly:
Quoted: 684 Post(s)
Liked 370 Times
PM me your cotters
Liked 588 Times
Quoted: 684 Post(s)
Liked 370 Times
Looks like it WAS the ferrule after all, it did push up the housing. That plus the sharp bend did the trick.
Quoted: 684 Post(s)
Liked 370 Times
That should do it
Quoted: 789 Post(s)
Liked 1,739 Times
*Edit*
Quoted: 684 Post(s)
Liked 370 Times
Quoted: 18350 Post(s)
Liked 4,502 Times
What direction do the wires in the cable housing go?
"Shift" housing has longitudinal wires.
"Brake" housing has coiled wires.
You are not supposed to use the shift housing for brakes as one has too much force on them.
Quoted: 3464 Post(s)
Liked 2,827 Times
Likes For repechage:
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Ive had Issues wih those cheap plastic cable end Ferrules a few times , Even the new "metal" Ferrules will will buckle and pinch/ruin the end of the cable. They are making them so thin that they crush themselves when you apply the brakes.
señor miembro
Liked 6,452 Times
Likes For SurferRosa:
Liked 1,285 Times
I had an '84 Trek 520 I used as a commuter for several years, I believe the front brake cable went to the left and the rear brake cable went to the right of the stem because of the cable hanger, and I can't recall how the cable went past the seatpost.
I'm trying to figure out what the thieves think of the black tape wrap-ups, I'm sure that they know it's the better bikes that get wrapped.
Quoted: 1635 Post(s)
Liked 823 Times
If I cannot find good NOS for my C&V bikes, My go-to cable and housing is the ones from "Porkchop BMX", sold at eBay for very reasonable prices (Around 14 bucks/set, IIRC). I like the Porkchop cable sets as they have it in clear casing where you can see the spring. It looks exactly like what many bike makers used back in the 80's. I never had any problems with them splitting like that, so far.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
