Touring racks for suspension forks?
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
I have also carried gear both ways. If I'm going to carry 40 liters of gear up front, it'll be in panniers. But the way I've dealt with this is to not have 40 liters of gear up front. I generally have 15 to 20 liters up front when I am using my hybrid, bikepacking set up. I don't find that it compromises steering. I also don't put the heaviest stuff in my handlebar roll. It's basically my tent and sleeping gear, which is all fabric. While I agree that carrying weight lower is better. If you can pare down your gear to the point where you are carrying less than 20 liters up front, then I have found that I'm much happier skipping the extra weight of a front rack and panniers, and just carrying the gear on my handlebars. I know you have strong, contrary feelings otherwise, but I've also tried it both ways and don't find my current, front-end set-up to be as onerous as you find it.
When I bikepack, my load is very similar to yours with the exception of using a rear pannier. Although I've posted this before, here are two configurations I've used recently
DSCN1255 by Stuart Black, on Flickr
2020-01-26 16:51:13 by Stuart Black, on Flickr
The first is similar to another configuration that I used that resulted in a biffed helmet on a steep downhill when the high load surprised me. I used a Revelate Design Trangle instead of the Oveja Negra Super Wedgie on that ride. The handle load each time is identical: A tent, sleeping bag and pad, and some food in the front pocket. Inside the frame bag in the first picture is the most dense equipment I carry...a stove, fuel canister and cup and some food. I carried some freeze-dried food in the pocket on that trip.
The second picture adds the small panniers so that I can carry a bit more freeze-dried food (it was a longer more remote trip) and some on-bike food which I could have used on the other ride. I added the fork leg bags to carry the dense equipment and to free up some space in the Super Wedgie. The weight of the trip is only slightly more because of the extra food.
I, like you, don't get into the handle bar roll except to make camp. The bike still feels top heavy compared to a regular road load and can be sketchy on steep rocky downhills. Riding it requires constant attention to rider position and care when roads and jeep trails become steep.
I agree in general, but that's why I like the hybrid approach. Anything I pack on the front of the bike, I don't need access to during the day. Getting into and out of my handlebar roll to retrieve something multiple times a day would be a hassle, so my handlebar hold my sleeping stuff. I only need to get into it once a day, and when I do, I'm emptying the entire thing, so it ends up not really being a hassle at all. And some of that can mitigated by the attachment system. I use a bag and cradle combination currently that makes removing and reattaching the bag fairly simple. Not as simple as my panniers, but it's worth it for me to not have front rack. When I was just strapping a dry bag to my handlebars, it was a lot more fiddly, but the bag and cradle combo is pretty easy to use.
And, even at camp, the bikepacking bags can be difficult to deal with. As I live in bear country, the bags with food have to be removed and either stored in a bear vault or hug from a tree. I've done the same with panniers and, again, they have convenient handles.
Stuart Black
Stuart Black
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 389 Post(s)
Liked 768 Times
For those of you that have mounted racks/bags to suspension forks, have you noticed any change in fork performance? Since you're adding to the unsprung weight of the fork, I'd imagine that it would be slower and less able to react to bumps, washboard, etc...
I did not notice that. It seemed to work normally. Now that I have a stiff fork, sometimes I miss the suspension
Likes For MarcusT:
My fork is an old airless, oilless one from the late 90s, using springs and those compression foam things, although it was a high end one back in 97...
it was clearly affected, but it also is a stiff suspension fork, so it is less affected, but more importantly I didn't have much weight up front. Certainly tons less than other riders I've seen, although I suspect the individual fork is a big factor and weight of course.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
