How long does a newly built wheel keep in storage?
Quoted: 49 Post(s)
Liked 9 Times
I would like to have a few wheels built on some rims and hubs I've collected. I may rotate them every 6 months or so or I may not. How long will they last without being used once I get them back from the wheel builder? Will they stay perfectly fine for a few years even in the event I never get around to rotating them into use?
Quoted: 2604 Post(s)
Liked 1,933 Times
As far as the rims and spokes, if it's built right, they'll last forever.
The bigger problem is likely to be the grease in the hubs will dry out if you leave them sitting for a very long time. After several years, you might want to repack the bearings (if possible) or drip a few drops of light oil into sealed bearings.
Likes For pdlamb:
worse case scenario, just check the true & tension before switching out the rims.
Likes For justinschulz9:
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...if you hang them up over in a corner of the garage somewhere, where they're not subject to getting bumped or stuff dropping on them, they will do fine. Eventually the grease in the hubs dries out, but that takes years.
Likes For 3alarmer:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
If a wheel is built properly with high, even tension you'll should not need to touch them for the life of the rim. At worst, a well-built wheel will require minor touch-up after the first couple rides.
I've built wheels that did not require re-truing for years. I rebuilt them when the rims wore through on the brake track. Now that my main ride has disk brakes I expect they'll outlive Keith Richards.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Likes For Dan Burkhart:
Quoted: 1857 Post(s)
Liked 664 Times
