Changing a bottom bracket to a cartridge unit.
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I'm thinking of changing the bottom bracket on my 85 Sequoia to a cartridge unit but I'm not sure what I need.
The shell is 68 mm and the spindle is 114.5mm but as near as I can tell the drive side is 2mm longer than
the non drive side. Here is a photo of the spindle.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I think what you want is to preserve the length of the longer side, which means you'd want a 118mm (closest size).
And pay extra for a UN55 cartridge, instead of the UN26. You probably won't have to change it again.
[edit[ Also, that's assuming you have a JIS spindle and cranks, and not ISO. Not sure what's available in ISO.
Quoted: 677 Post(s)
Liked 459 Times
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...personally, I usually do the slightly longer spindle thing, but it's also possible to shift the cartidge over a couple of mm by using a spacer or spacers on the drive side, that fits between the lip of the cartridge on that side and the BB shell. So then you can get away with a spindle closer to your original length. Look here for you question on JIS/ISO.
Likes For 3alarmer:
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Your spindle should be marked JIS, probably. What are the other markings?
Quoted: 677 Post(s)
Liked 459 Times
Not much difference, but enough to mess you up if you try and mix the two. The link that @3alarmer gave should clarify.
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Actually, never mind about the ISO stuff...it's late and I'm tired. A Specialized Sequoia would almost certainly have a JIS spindle.
Vintage spindles were asymmetrical. Modern cartridge BB typically use a thicker drive side cup to shift the whole assembly to the drive side. This accomplishes the same thing, more or less. IOW a similar spindle length is probably going to work, or at least partly work. Unfortunately crank design has changed slightly too. Try and fit is the only safe method. If the crank has decent clearance now, I'd probably risk it with a 115 and a couple BB spacers, just in case. Might need 118 though. Hard to predict. This is something I usually recommend people take to their LBS, unless you're comfortable buying at least a couple BBs.
I can't remember who made the Specialized bottom brackets. Think it was Sugino. They won't necessarily be to a modern JIS standard.
Once you get a couple of them wrong and reorder you will start to have a little inventory to pick from on your next project. I was upset that I had guessed wrong and had to reorder the first time I replaced one, the second time I wasn't sure so I ordered 2 different ones. The next two times I had one in my stash that fit perfectly. Now I am back to square 1 on the next project
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
I also have found it preferable to choose the shorter spindle on the newer symmetric cartridges, and use a spacer on the drive side - it helps prevent the NDS crank arm sitting way too far outboard
Bikes: 1978 modified Fuji S10S-ltd, 1982full Campy Terry Osell bike, 2012 Cannondale Super Six Hi Mod Dura Ace
Try phil wood
Take a look at thePhil Wood web site. I bet most of your questions will be answered. I put a Phil titanium bb on my Osell (campy crank)about 20 years ago and never looked back.
Cheers
Cheers
Quoted: 677 Post(s)
Liked 459 Times
I thought it might be easier to put in a new cartridge bottom bracket but after reading all
this I think Ill just replace the old bearings with new ones lol.I have it all taken apart
and everything seems to be in good shape.
Likes For robertj298:
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
...I never replace a cup and cone original with a sealed unit unless there's something wrong with the cups or the spindle. I know there are people who do, but I can't understand why.
Likes For 3alarmer:
Quoted: 677 Post(s)
Liked 459 Times
I thought it might be easier but it doesn't seem that way to mebut I guess the sealed unit stays cleaner.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
I'll assume you're using your existing crank and only replacing the BB
You have
114.5/2 = 57.25 = CL if it were symmetrical
Per your measurements 2mm longer on DS.
57.25 + 2 = 59.25 which would be CL for the longest end if symmetrical
59.25 X 2 = 118.5 for a symmetrical spindle
Do you have 0.5mm clearance on your DS?
You could also use a decent quality steel ruler, measure between the raised bearing bosses on the old spindle and mark a CL on the old spindle, then measure to the longest side and double it.
You have
