The Water Cooler, Scuttlebutt, Chit Chat Thread
#5026
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
He's referring to a turbomolecular pump. These are common on many scientific instruments that require a deep vacuum to operate.
"Your beauty is an aeroplane;
#5027
Quoted: 8281 Post(s)
Liked 9,052 Times
. Mazdaspeed 3, Focus ST, Civic Si, something like that. big john do you have an recommendations for models like that???
Likes For big john:
#5028
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Get a miata.
Tbh im semi looking for a new to me car as well. I have an 06 Acura TL that just hit 150k but is starting to develop some electrical and/or trans issues.
Kinda thinking a 2012 v6 rav4 or a newer cx5 to cover bike and snowboard duty.
I guess you've never seen a subaru or European car then huh?
#5029
Quoted: 1851 Post(s)
Liked 679 Times
TMonk, drive the Corolla til it dies. With 130k on it, you're just breaking it in.
If you want a fun car, look for an old Miata and keep it as a third/weekender. They don't have much power, but they are small, light, RWD, easy to find in manual, and cheap - to buy and maintain. Plus, where you live, the convertible would be a bonus.
Likes For topflightpro:
#5030
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
Your ICP-MS is 10 years old? Time to start working on a procurement plan for a new one. Working on old ones is a PITA as the tubes etc. get brittle and break if you touch them.
#5031
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
I'm hoping mine starts afloat. I'd like it to see me through training... At least the next year if that's not possible.
Likes For ridethecliche:
#5032
Not actually Tmonk
Liked 3,153 Times
I've that door fail, zero counts per second... odd; after that I always listened for the opening noise right after torch ignition.
I tried to at least keep the system under vacuum by jamming it in there past that resistance and turning the pumps on. and it did stay on for a lot longer than we were used to. few hours vs a few minutes, but I guess it wasn't the best seal as the turbo eventuality shut itself off.
#5033
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
Yeah for sure it's loud. It wasn't opening freely when we did manual control in the engineering mode, you could see it like buck out to the side a little bit and not full open. I vented the system by opening the analyzer chamber so I could physically pull it out, and there is a few mm of resistance at the end of the stroke, I think like a worn gasket or O-ring or something. For this reason the gas pressure is not enough to open/close it at the moment. Gas lines and fittings are fine. I've never taken apart a slide valve and I guess I could/should sincei t's old, but we're getting a FSE to come out and replace it anywho.
Less than ideal vacuum won't fry your EMT detector unless you run high voltages. A tiny bit of leak is a free collision cell against polyatomic interference. Kidding... sorta.
Likes For Enthalpic:
#5034
Not actually Tmonk
Liked 3,153 Times
or also maybe free O2 reaction mode
the detector is already probably a it pissed from being at atmosphere this whole time, I expect to have to crank voltages higher once it gets back up. Sucks cause its new. I've never tried to mess with the pressure cutoff/setting in the chamber, could be worth a try if it means saving some wear on the detector while we get a new valve.
Likes For TMonk:
#5035
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
I thought the turbomolecular pump was referring to a new smart trainer design that enables enhanced Zwifting capability.
Likes For Hermes:
#5036
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
I asked the wife if I could go do Johnson City omnium, I was denied. If ever there was a race made for my physique. The road race and the TT both being a ton of uphill. A bit disappointed. I wish my teammates the best. A couple of guys definitely over 90kg's will be going up the mountain. God bless, have fun.
People have different opinions on racing right now and states reopening with bad health numbers rising. I guess I just forgot for a minute the current world we live in. Our household isn't really doing anything like that yet. Just our choice. Hence how I mention I just got excited seeing that and forgot.
I'll do the local hobby TT going on. That bike is almost back together.
#5037
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
The electrical wiring in this house never ceases to amaze. Almost always to code, but just really creative. We're updating the office so I can actually use it since I'm working from home full time for the foreseeable future, probably until we move at any rate.
They have two lights and a fan in the ceiling, which we're replacing with 2 lights and then one light, on separate switches. The two lights are on a 3 way switch, with the lights after both switches. But that's the normal part. They used 3 wire cable from the box with the fan and light switch, and used the red to run straight through all the lights and feed the fan, so they only had to run one cable. It makes sense and might be super common, I dunno, but it looks confusing as hell when you pull all the lights down and try to figure out what's going on.
#5038
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
#5039
No matches
Liked 444 Times
Something I hadn't considered about working from home. If the power is out I'm not making money. Already down 3.5 hours earlier today, no estimated restoration. Gonna borrow a very small generator hopefully big enough to get internet and my laptop and monitors going. Probably still gonna lose all the food in fridge and both freezers.
Next on the house list after we finish my office is gonna be a transfer switch and generator big enough to run the majority of the house at least.
#5040
Quoted: 4236 Post(s)
Liked 2,949 Times
Solar panels? I mean, that doesn't help at night, obviously, unless you've got some great batteries.
#5041
No matches
Liked 444 Times
On this 2-4 year timeframe house? A decent sized portable generator we can take with us, plus a service rated transfer switch to pick up whatever loads we want. The transfer switch will be a small selling point, especially to the right people. I'll make it somewhat pretty (and to code, I might even open my book to check, who knows).
#5042
No matches
Liked 444 Times
Now it has an estimated restoration time at least.
August 7th, at 11 PM. It'll be my late in the day birthday present I guess. Yay... I hope they're underpromising so they can overdeliver.
I know other people in the world have worse issues, but man, it still sucks. It's gonna be 85 today too. Little kids don't love the heat, and houses aren't built to not have AC.
#5043
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
After a non cycling related incident today I think I'm going to be riding indoors a fair amount for the next couple of weeks...
What fans are you folks using to keep cool indoors? I was thinking of getting one of the industrial floor fans...
I think it's time I start doing a little bit more structured stuff indoors especially on nights I'd be out riding past dark with a light setup.
#5044
#5045
Liked 2,949 Times
I use two lasko pro performance fans, which are the gold standard among many, and I have a third fan, lasko cyclone, which I also use but isn’t as good. I don’t have AC in my basement and lately I train in upper 70s and humid conditions and while not totally pleasant it works. I’d be so happy if I could keep the space 70 and below
Right now my cooling "solution" is a cheap lasko 20" box fan strapped to some stacked wire crates and I reach over to turn the dial roughly halfway (and again 3/4ths of the way) into my race/workout (and distract myself from the pain by calculating when those points are and how far away they are). I'd love an additional fan like one of those blowers, but would like to be able to regulate the speed. I mean I could just replace the box fan with one and reach over to control that, but I'd like an additional fan, not just a single, more powerful one where the one is now and it'd be awesome to control the strength so it's not blowing me away when I first start.
#5046
Quoted: 842 Post(s)
Liked 469 Times
Has anyone figured out a way to run those with a remote yet? Like, is it possible to plug one into a smart plug and then have your phone (or smart speaker or whatever) control how much power it gets?
Works pretty well, though I can't say its the best because I haven't tried many...
#5048
Unfortunately no way to control speed of fan, since that's a manual control. I have wifi sockets I keep the fans plugged into and turn on as needed (I keep the fans at high). In the summer I'll just turn them all on at the start. In the winter I'll start my warmup with all fans off, then turn on one then the others as I progress to the main sets
#5049
Quoted: 842 Post(s)
Liked 469 Times
We had a really bad month in our house. My wife manages COVID for her company (which has locations nationwide) and when it hit it was bad. She felt really guilty about some things that happened (when in reality she was mocked by other managers for being to harsh about safety measures) and resigned. I wasn't happy because her quitting meant I would retire 10 years later. She didn't want to work at all. So her work gave her a month off and she accepted.
So I've changed my perspective; I'm going to use my 30 years of experience to make every penny I can outside of work. Realizing that my retirement is no guarantee was really upsetting. I'll still ride my bike and hopefully race, I need the bike for stress relief. All my spare time is going into my current project now. In the past, I've always thought making a company to produce something is 'scamming people' but I'm trying to change my outlook on that.
Likes For furiousferret:
#5050
Liked 679 Times
My car is back in the shop. It needs another expensive repair. I really like driving my BMW, but I'm getting to that point where repairs are coming frequently and are expensive.
I try to keep cars for 10 years or 200k miles, but I think when we pay of my wife's car early next year, I'll be getting something new. I'll only be at 8 years on the BMW, but I don't want to keep paying to keep it going.
