Front disc brake rubbing noise when out of the saddle
Old 01-22-20, 12:44 PM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times in 440 Posts
Originally Posted by ajbarickman
Thank you all for the quick and super useful feedback.
I think my next steps are going to be 1) Clean and check that the pistons are working properly 2) Adjust the centering by eye to provide the most tolerance 3) Swap front and read rotors to see if anything changes. 4) Increase the distance between pads so that there is more room to accommodate any movement.
Nailed it! I would try #3 first though. It the noise stops, it means time to get a new rotor or try to straighten the existing one. I wouldn't mess with #4 and #2 , you might just to more harm than good, but that's just my opinion.
eduskator is offline
Old 01-22-20, 01:06 PM
u235
u235's Avatar
Quoted: 437 Post(s)
Liked 133 Times in 86 Posts
I don't notice any rubbing during cornering. It definitely could be another noise it is hard to tell.
What I was getting at there is the wheel can shift on a hard turn just like out of the saddle and rub against the rotor too. Same rubbing noise. Trying to adjust or move the piston around manually on hyd brakes won't solve anything, they self adjust right back to where they are going to go after using them again.
u235 is offline
Old 01-22-20, 01:52 PM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Unless I misunderstand the functionality, you can adjust the point at which the lever engages the master cylinder, but not the gap between the pads and rotor.
WhyFi is offline
Old 01-22-20, 02:29 PM
ckindt
Bikes: Trek Domane 2020 SLR7, 2016 4.3 Disc, 2017 Raleigh Stuntman
Quoted: 127 Post(s)
Liked 36 Times in 21 Posts
If the correct spacer block wasn't used during the bleeding procedure, there could be too much fluid in the system resulting in pads that are too close to the disc when the brake lever is released.
In other words, not enough gap between the pads.
ckindt is offline
Old 01-22-20, 03:12 PM
WhyFi
WhyFi's Avatar
If that were the case, it would sort itself out as the pads wear or you could simply push in the pads/pistons manually and let them self-adjust when you pump the brake levers. Doesn't seem likely, though, as it's not making noise otherwise and (that I'm aware of) the current gen levers/calipers are coming filled and pre-bled from Shimano.
WhyFi is offline
Old 01-22-20, 04:19 PM
ckindt
Quoted: 127 Post(s)
It would only sort itself out as the pads wore, unless you bled some fluid out it has no where to go in a sealed system.
It may not be likely, but it is possible. If the OP has the block that likely came with the bike they could check its fitment. It shouldn't require force to insert it between the pads.
I was never one to trust others' work.
ckindt is offline
Old 01-22-20, 04:36 PM
WhyFi
WhyFi's Avatar
... unless you bled some fluid out it has no where to go in a sealed system.
There's a reservoir in the hoods, that reservoir is open to the system when the brake lever isn't depressed.
WhyFi is offline
Old 01-22-20, 05:27 PM
ckindt
Quoted: 127 Post(s)
Yes, if you have an open system with a bladder separating the air from the fluid.
No, if you have a closed system with no bladder.
ckindt is offline
Old 01-22-20, 05:58 PM
WhyFi
WhyFi's Avatar
There's air in the reservoir by design; it's why Shimano tells you not to invert the bike - it might work its way between the lever and caliper and cause sponginess. You wouldn't need to open the system up to push in the pistons and gain another half mm of gap.
Again, there's no rub unless standing - that should tell you that it's not that far off. Recommending that the OP open up the system to remove fluid when there are dozen other exceptionally common explanations is pretty... yeah, not prudent.
WhyFi is offline
Old 01-22-20, 06:33 PM
ckindt
Quoted: 127 Post(s)
I only suggested to check the clearance with the spacer. That's easy enough.
ckindt is offline
Old 01-22-20, 11:08 PM
Igotdibs
Senior Citizen
Igotdibs's Avatar
Bikes: Trek Emonda SLR7 Disc, Lemond Poprad, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 69 Post(s)
Liked 576 Times in 162 Posts
My front rotor rubs when I stand IF I run my front tire pressure somewhere around 75psi or lower. I normally ride 85 rear and 80 front with no issues.
Trek Emonda SLR7 Disc, 58cm
Bontrager Aeolus Pro 3 TLR wheels
Conti 5000 TL tires
I weigh 170 lbs
Igotdibs is offline
Old 01-23-20, 07:27 AM
eduskator
eduskator's Avatar
Quoted: 989 Post(s)
Conti 5000 TL tires
I weigh 170 lbs
But does it rub on all the surface, or is it only on a specific area? Is the sound constant or intermittent?
The guy said his rotor was warped - this is the problem.
Old 01-23-20, 08:13 AM
Igotdibs
Senior Citizen
Igotdibs's Avatar
Quoted: 69 Post(s)
Only standing and riding hard, only on the down strokes. My point in posting was to illustrate that sometimes it can be such a simple fix... I didn't see where the OP had figured out the problem.
Igotdibs is offline
Old 06-21-20, 11:38 AM
jfbaraldi
Solved?
Did you solve your issue? I bought the same bike last year. I’ve been struggling with this issue since then and still trying to find the solution on the net... I tried: swapping rotors, re-centering the pads, increasing tyre pressure, I also tested riding without one of the rotor (alternatively). Nothing worked!
It happens when I’m pedaling out of saddle (and pushing). I can’t bear it anymore...
jfbaraldi is offline
Old 06-21-20, 02:34 PM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times in 339 Posts
My new Canyon did the same thing when I stomped on the pedals out of the saddle, at first. After a few rides I finally got around to checking things over and snugged up the front through axle. No more rubbing out of the saddle. All I hear now is the drope of the hamer.
AdkMtnMonster is offline
Old 06-21-20, 04:22 PM
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Liked 203 Times in 135 Posts
Originally Posted by SalsaShark
This happens on one of my bikes, and seems to be caused by the flexing of the frame and fork when applying excess power.
I have the Canyon Ultimate CF SL 8.0 Di2 as well, and there is no brake rub standing, and I regularly put in 700-800W on hill sprints out of the saddle. (And, no, that's not even beer league peak power.)
However, I also make a point not to excessively rock the bike; it might only lean 5-10˚ back and forth, and I pay attention to riding in a straight line. This avoids side loading wheels, hubs, tires, frame, etc, and keeps the sidewalls off the pavement and away from debris. It also makes me ride in a straight line, which is the shortest path between two points, so I cover less distance while more energy is put into propelling me forward as opposed lean angle induced losses. (As a result, it'll feel a little harder. The same reason riding out of the saddle on a trainer feels harder.) And, yes, it requires pulling hard on the bars.
sfrider is offline
Old 06-23-20, 01:40 PM
ajbarickman
Hello. Kind of... I straightened my rotors, adjusted the brakes as best I could on a stand and then just tried to ignore it. After a bit, the sound went away. I do notice that each time I put my wheel on I have to live with a similar noise for a bit of my ride until it seats itself properly again. Super frustrating for sure.
ajbarickman is offline
Old 07-02-20, 05:12 PM
dvai
Quoted: 106 Post(s)
Liked 4 Times in 4 Posts
Originally Posted by Dean V
I would ride it for a few weeks and see if improves with the pads bedding in.
My Domane did.
Same here. When new, the disc rubbed a bit when out of the saddle.
After 60 miles, the issue resolved. Note the rub was VERY mild
dvai is offline
Old 07-05-20, 12:20 PM
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Here's an exercise: get out of the saddle on a hill, DON'T rock the bike, keep it as upright as possible, and try to ride in a straight line. If you draw a line where you tires went, it should be straight. No weaving. Yes, it will be harder than if you rock the bike, but the reason for this is you put your energy into moving the bike forward up the hill. In addition, it forces you to counteract the rocking motion with your core muscles and shoulders, engaging a wider spectrum of muscles. And indeed it will be harder initially. But you may find even dropping one gear it's sufficiently more efficient to be worthwhile, not just because you put your effort where it matters, but also because you're not trying to ride your bike tilted; even high end wheels and frames that do relatively well tilted will do better upright.
sfrider is offline
Old 07-05-20, 02:51 PM
justonwo
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times in 34 Posts
My Canyon Ultimate does this as well when standing and cranking. I would just ignore it, honestly. I stopped chasing disc brake noises a long time ago. There’s always something.
justonwo is offline
