Does anyone build their own wheels anymore?
#51
Quoted: 2236 Post(s)
Liked 1,314 Times
I am slowly going over to the online model simply because it is too painful to deal with local shops who don't know what I'm talking about or worse, say things aren't available when I know they are. Case in point: when I enquired about getting a 29r wheelset in one shop the staff said they doubted there were even spokes that long???
I know there is a wheel builder in Colorado that makes 29r fat wheelsets and am considering making a side trip when/if I go to Moab again this fall or just bite the bullet and order the parts and build them myself.
#52
Quoted: 1079 Post(s)
Liked 1,019 Times
Hello all!
I know that wheel building is a dying art and to do it well you need to use the proper tools which is a bit of an investment. Does anyone build their own wheels in their own set up space? If you work in a bike shop I figure learning to build wheels is part of the training and it's easier with all the tools at your disposal. I feel that wheel building is part art and part science and would like to learn but I don't have the space and I can't justify wheel building one wheel every ten years or so. The cost of investing in the equipment is prohibitive for me...Thoughts?
Cost of equipment isn't really that bad, I learned with a basic 50.00 truing stand that is still available in a slightly improved form for around 60-70, get the park triangle spoke wrench which does your 3 basic sizes, and even a cheap tensionmeter will do you fine. Don't look to it for proper tension, just consistency of tension.
I've built most of my wheels in the past using a bike frame in a work stand or just hanging by ropes before I owned a work stand. Brake blocks or thumbnails are adequate to indicate side play. The only special tool I have is a dishing gauge to center the rear wheel. Even that can be achieved by eyeball. I've built several wheels in campgrounds for ACA tour group members on picnic tables and bikes hanging from tree limbs.
I roll my eyes when I hear the phrase "art of wheel building". Lacing a wheel is basket making 101 as long as you have the correct spoke length. Tensioning is a bit trickier but is not rocket science.
My work station is the kitchen table, truing stand was 150 from Amazon warehouse deals, base was 50.00 at the LBS, tensiometer was 75 NOS off ebay. I like the wheelsmith as each of their tensiometers come with a chart based on the individual tool's actual tension reading.
Built this for something lighter and faster then factory, had the rims laying about nearly new. Ended up with wider more comfortable wheels that are stiffer in a sprint, still lots of room for improvement but no budget for it.
Built these for me, blue White Industries thru-axle Campy compatible hubs, 3 different styles of spokes for best strength/weight and ability to take abuse, green spoke nipples to tye them into the overall build (green frame, blue accents).
#53
#54
C*pt*i* Obvious
I've lost track of how many wheels I've (re)built, sometimes its the only way to get exactly what you want.
I've also bought a couple of prebuilt wheels recently that seem to be holding up OK so far.
#55
I build wheels a couple of times a year. Built a set of 650B couple of years ago because it was hard to get what I wanted otherwise. I recently built a rear up, because I wanted to save a 27" rim and wanted to use a Campy high flange hub. The old freewheel (five speed two notch Suntour) decided it wasn't coming off the Tipo hub, which is pretty used anyway. I have a great resource in Ft Collins, Brave New Wheel. Sat morning called in, two hours later I went by and picked up my spokes. Social distancing of course, curb side pickup. But, I have been doing my own stuff for years and have everything I need. Having been an auto mech for most of my life makes it easier. However, when I wanted a set of Mavic Kyseriums, went to Ebay for those.
#56
Palmer
Quoted: 1659 Post(s)
Liked 1,806 Times
Not $8 wheels from Nashbar department:
SRAM i3 in ISO622 rim
1936 Sturmey-Archer AW hub in ISO630 rim
Chosin Capreo hub in ISO369 rim
Shimano Alfine 11 in ISO349 rim
Sturmey Archer XRF8 in ISO590 rim
Rohloff in ISO584 rim
Shimano Nexus 8 in ISO349 rim
Sturmey-Archer RXRF5 in ISO590 rim
Enviolo N330 in ISO559 rim
Sturmey-Archer Dynohub in ISO590 rim
Front wheels to match a lot of these
Yeah, I build wheels. I get some satisfaction out of riding on wheels I built myself, and with the notable exception of that 32 spoke 16" Alfine, it's been fun, too. I don't consider myself an excellent wheel builder, but I'm better than the guys at the two big LBSs in town.
#57
bocobiking
#58
#59
Quoted: 3452 Post(s)
Liked 1,452 Times
I have never pulled the racks or fenders off to true up a wheel that I had already built and used. If it needed any adjustment after I had ridden on it I never bothered to check for roundness, all I did was fix any side to side play.
#60
Quoted: 595 Post(s)
Liked 281 Times
BobG, definitely a neat way to check on how laterally true the rim is but like so many, you're only checking lateral trueness and have no way to check how "out of round" the rim is. And as for use as a dishing tool, your lines would have to be exceptionally well measured as it would be easy to have both parallel lines a couple of mm right or left of exact center, or am I missing something ?
#61
Quoted: 2599 Post(s)
Liked 1,924 Times
Two things in BobG's defense. First, you can get the masking tape right on the rim when you start, then spin the wheel. If a gap opens up, or the rim shreds the tape, it's not true.
Second, I've rarely had an issue with radial true after the wheel was built. I guess if you broke 3-4 spokes right next to each other, for instance if a stick threw the derailer into the wheel, that could be a problem. But a single loose or broken spoke can usually be fixed without problems.
#62
@robow I'll usually double check dish with my $10 Nashbar gauge but that requires taking the wheel off the bike to do so. Vertical hops? Just spin the wheel and they will be revealed against the tape just as they would by a truing stand plate. That said, I've found that vertical roundness is more a function of the rim quality and evenness of initial spoke tension. Not much you can do to correct it later.
If you want to be that fussy about the masking tape lines just apply the tape, measure the distance between each seat stay, mark the center point with a dot and draw the lines 12 mm left and right for a 24 mm rim. Close enuf!
Not as convenient but just as accurate as any Park stand for occasional use. In comparison, the stand in Russ's photo above looks like it was built by Rube Goldberg with its adjustable caliper and all its knobs and springs! Keep in mind the OP said he needs something to use "every ten years or so".
Robow, I've always wondered ... Is Raybo your brother? Ha Ha, just kidding!
edit- if you look at my photo above you will see the back side a fender bolt marking the center point of the bridge.
#63
You can build and true wheels on your bike using the seatstays / fork legs as a guide. You don't need a dish tool, simply reverse mount the wheel in your frame/fork/truing stand and observe/adjust dish as necessary. Even if dish is off up to 5mm, you will not notice it when riding bike (intentionally offsetting rim to NDS can be useful for higher NDS spoke tension on rear wheels, improves wheel longevity). I have a Minoura truing stand I got from Nashbar on sale for $25 which I've used for a dozen wheel builds. A cheap truing stand is worth the cost for several wheels - it is easier to work seated at a bench (or your kitchen table) with AC, good lighting and easy reach to the work.
#64
Quoted: 595 Post(s)
Liked 281 Times
@robow
BobG, I see that now in your photo and you obviously have a well thought out technique that works well for you. Well done!
A couple years ago I came upon a fellow by the side of the road who had just hit a rather nasty pot hole and he was convinced that his rim was bent because of a hop in the wheel as he rotated it. By holding a screw driver steadily at the junction of tire and rim, it was obvious that the "hop" wasn't from his rim but rather his tire had probably broken a belt and become deformed. It became very obvious when we took the tire off but until then, I don't think he believed me.
#65
Liked 1,019 Times
One advantage to building your own wheels is being able to deal with others' poorly pre-built wheels. Was just handed a wheelset, the drive side spokes measured on my tensiometer anywhere from 40-70, while the non-drive ranged from unreadable to 13 or 15 and half were unreadable. The problem was initially determined when a spoke nipple unthreaded and fell into the rim on the first ride. The owner couldn't tell me, and the rims didn't say what the proper tension was and I had to estimate actual KgF based on the reading, went with 55-60 on the drive side and 15-20 on the non-drive side figuring the high reading of 70 was an outlier and unsafe to the rim structure; also properly dished the wheel. Per my last post of people not noticing dish being off, this one was off by 4mm and the owner didn't notice, now off by maybe a 1/4mm.
Haven't tackled the front which runs from about 20-65 but half sit in the 45 range so I'll loosen all spokes a couple turns till they all read 30, true and round and recheck consistent before tightening them all back up. Good looking wheels but a lousy build. Other thing I should have done and would have if I'd built it, would be to put all the non-drive spokes which are straight pull to the outside of the flange. The hub is so poorly designed that it might even be better off losing half the spokes on the non-drive which I'd also do if it was my build. But figuring these things out is a part of what I call the craft of it.
#66
I don't actually use a dishing tool. I just flip the wheel in the truing stand and always try to get the dish 1mm to the NDS side so not completely central. It's far enough to give a noticeable increase in tension to the NDS side but still not as much to make any sort of difference in handling as there's bigger variance in tires, how they sit on the rim etc.
Likes For elcruxio:
#67
Quoted: 1324 Post(s)
Liked 927 Times
I'm going to be looking for some clincher rims that have the same spoke bed diameters as some of my tubular wheel rims. When I find those I'm going to switch the rims and spokes to the new clincher rims and build the wheels myself. It's worth it to me since the hubs are either Dura Ace EX or Campagnolo.
Cheers
Cheers
#68
Liked 1,452 Times
Cheers
Cheers
Make sure you get the right pattern, I think the proper term is French pattern or European pattern to match your existing rim.
#69
One thing a Machine built wheel from a bike shop's wholesale distributor, will be built with rims, hubs & Spokes at their costs..
and can come in at less, built, than the retail parts cost, minus build labor..
#70
Between Nov and Mar build wheels! A well built wheel lasts a very long time. I broke a lot of straight gauge spokes then built my own with butted spokes. 10 years on,wheels still good.
#71
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
Built quite a few wheels these past couple of years. It's a great way to use the Sturmey Archer hubs I seem to find for cheap over here and allows me to build the wheels I want.
That being said, sometimes you can get a good wheel for less than you pay in parts and that's okay too.
My next project will probably be a 650B wheel for a tandem.
#72
Bikes: 1974 Bianchi Sprint (refurbed in 1986); Pinarello Trevesio, 1984 (fully restored - original in 2012); Cannondale T500 frame with custom build for touring - 2001, Trek 620 - Repainted, modern build; 1973 Raleigh International; 1993 Giant hybrid
Liked 7 Times
Very nice work! Lovely wheel builds.
#73
Liked 1,452 Times
A fairly new you tube video on how to build a wheel.
I watched part of it, skimmed through part of it. Langley is the mechanic that put together the video and he knows his stuff, so there were no errors that I saw, although here and there he used the wrong word and corrected it in text.
But, if someone was going to try to learn how to build bike wheels, I think the write up by Sheldon Brown is also a must read. I gave the link to that in post 12 above, Saddlesores also cited his article in post 11 above. That written piece and this you tube video would compliment each other quite well.
There are a few things that the video and the written article do not agree on, but they are minor items, like which order you do things. I also do things in a slightly different order than Langley in the video, but I would never say he was wrong, we just did things in different order and got the same result in the end.
I would encourage someone that tries to learn how to build a wheel to not just watch the video, but also read the piece by Sheldon, as that is more complete on some minor points.
#74
Quoted: 1300 Post(s)
Liked 1,900 Times
I'm pretty sure I have built thousands of wheels and they are pretty easy to do. But then again I am a professional and use a Var truing stand, along with doing the homework to build each one. I am currently building for a vintage bike that will get Torelli rims and Campy hubs. But the build will take about one hour per wheel and is going to b a great set of wheels. I expect them to last for a few thousand miles, and they will likely fail from road conditions and not from the build. Smiles, MH
#75
Palmer
Liked 1,806 Times
It was said that the late Harlan Meyers could spoke, true and tension a wheel in five minutes or less.
HiE, main
HiE, main
