27" tires????
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
27" tires????
Wheres the best place to find a decent not too expensive 27" tire.
I'm thinking under $30 each.
Quoted: 3810 Post(s)
Liked 6,699 Times
Likes For nlerner:
Quoted: 796 Post(s)
Liked 522 Times
When I am looking for cheap I go to Amazon but you can sometimes find deals at Biketiresdirect or Treefort Bikes. I have a entry level Miyata I am rehabbing to sell and I ordered cheap Sunlite tires for it as it was all I could find at the time and compared to the Panaracesr I am used to they are heavy and not easy to mount. If you are doing a bike for yourself look for deals on Panaracer Pasela's they are worth spending a bit more for IMHO. Supple nice riding.
Likes For ryansu:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
You can spend $35 for a set of crap or $60 for Paselas.
#nobrainer
Likes For SurferRosa:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Specialized All Condition (Armadillo) tires are nice, but more like $90 a pair. 😳 They seem pretty decent so far. 🙄😉
Quoted: 938 Post(s)
Liked 2,941 Times
I recently shopped for 27s and a lot of places are out of stock. Ditto that Paelsas will probably be the best.
Likes For ascherer:
I tried to order some of those Panaracers for the old Raleigh I'm working on but couldn't find any. Ended up going to my local bike co-op and getting a cheaper set of 27" wheels. They said they usually carry a lot of 27" stuff as they're used to rebuilding older bikes. If you have a local bike co-op, maybe try that.
If you need new 27" tires this year you're probably going to have to take whatever you can get your hands on, and feel lucky you were able to get them. I understand that QBP (wholesale supplier for most bike shops) had 27" Paselas come back into stock the other day... and they were all gone within about five minutes.
Quoted: 1627 Post(s)
Liked 630 Times
Panaracer Paselas are the only 27" tire I've used that is both good and cheap. There are some other choices in the 700c size, but not 27".
If your bike frame has enough space and, you want a bigger more comfortable tire try out the Michelin Pro-Tek. The smallest size they come in is 32mm. I've got no idea about availability.
https://www.performancebike.com/mich...93474?v=333740
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
I enjoy both the Pasela and the Sand Canyon tires.
Commence to jigglin’ huh?!?!
Quoted: 5888 Post(s)
Liked 3,471 Times
Liked 3,471 Times
One thing to keep in mind is that a lot of 27 inch rims are older technology and lack a hook bead. If your rims lack a bead, get a tire with a wire bead and run it around 75 PSI or less depending on what you can get away with.
Likes For bikemig:
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
These are quite a bit wider and heavier than the Kross Cyclo 1-3/4" tires, so can be run at considerably lower pressure. This bodes well for their possible use off road.
I run them on my upright hybrid bike. They're mounted on 27" rims on an old Raleigh Technium. I've taken the bike down well compacted gravel paths frequently. The Pro-Teks do just fine.
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Thanks for the responses DDDD and Ramzilla. I'm going to purchase a pair for my next gravel grinder project and give them a go. I found, already, that the Kenda Krosscyclo tires are heavier than my road tires, but maybe that's not a fair comparison. The Kenda's are the only tires I've purchased for gravel, so I don't have anything to compare them to. Anyways, "gravel" seems to encompass a lot of different road materials and conditions, and what might be fine for my situation could be just "okay" for someone else's situation.
Quoted: 7348 Post(s)
Liked 2,470 Times
There is also a Continental tire in 27". I haven't tried it, but generally, Continental tires are very good. The only 27" tire I've tried and liked in recent years is the Pasela but if I needed one, I would take a chance on the Continental.
Quoted: 767 Post(s)
Liked 1,898 Times
Yep, Continental makes the Ultrasport in 27. I have them on my Raleigh, 27x1 1/4 size. They are wire bead, work well on the old hookless rims, and are a nice riding tire for such a low price. I think Paselas are nicer, but the Continentals are pretty decent and don't cost much. They are a good option.
Quoted: 604 Post(s)
Liked 1,064 Times
32 Dollars will get you some decent Continentals, from Universal Cycles, but that doesn’t include shipping.
Tim
Tim
