Dahon Speed Uno electric conversion questions
HI,
I am considering combining the Bionx system set up in the video below (the BionX PL 350) with the Dahon Speed Uno.
https://www.youtube.com/watch?v=SE1Mz9RcxO4
Given that the non-electric Dahon Speed Uno is one speed, should I anticipate problems or difficulties with such a conversion? (I'm new to electric bikes)
Obviously, i'm trying to save money on the bicycle side in order to afford the better Bionx system. So the related question I have is will the quality of the Dahon Speed Uno be decent given its low price? Am I getting a better bike than if I were to purchase say a Produco Mariner 7 or should I just get the Mariner 7?
Thanks.
Thanks.
Someone in yahoo answers just told me the one speed Daho Speed Uno would not work with the Bionx system. Saved me from making a big amateur mistake, obviously. Basically said I need something with more speeds and hand brakes.
So with that in mind, let me reword my question:
What would be the least expensive 20" folding bike I could put the BionX PL 350 system on? Or am I still better off going with the Mariner 7?
I was thinking about a Gotham Citizen or a Vela. No good?
Thanks again.
Thanks again.
Quoted: 113 Post(s)
Liked 8 Times
The Speed Uno wouldn't work because of a rear dropout width of 120mm .. the Bionx system is 135mm .. so you would want a folding bike close to that width.. if it were me, I'd look for a good used Dahon Speed P8 (they turn up frequently on C/L) .. the frame is chromoly which should suit a 350w motor better than a folder with aluminum drop outs.. also the Speed P8 has generally better components than the competition in its price range, rides well, and is a tried a true design ... personally, I wouldn't slap a $1500 e-kit on a low end folder... what part of the country are you in?
I'm in central, NJ. Nothing in NJ on CL as of yet. Nobody makes a 20" electric with the motor on the back wheel?
Edit:
Found one. What do you think of Golden Motor? : https://www.goldenmotor.com/JDbike/ebikeprod.htm never heard of them myself.
I'm looking at the 20" pictured a little down the page at the link.
Edit:
If you were looking for a new 20" folding Dahon for this Bionx system on the Dahon website, which one would you pick? Are there other models available with the chromoly frame? Or perhaps you would choose something other than a Dahon then?
Thank you once again and sorry for all the alterations to my question. Obviously, I'm new at this.
btw, how do I find the dropout width for bikes I look at online? lol. Is that something you just have to know from experience or should it be somewhere in a bike's specifications?
Dahon uno conversion
Do you happen to have a recommendation for a conversion kit for a Dahon Uno?
Thanks again.
Thanks again.
Quoted: 882 Post(s)
Liked 821 Times
Seems to have a coaster brake which pretty much precludes the use of mid-drive or rear hub motor. Need to check the front hub spacing (from the inside of the dropouts. Then check ebikesca since they sell front hub conversions for Brompton but an individual here had very bad luck with them and they're expensive. Report back with the hub dimension; if it's 100 mm (about four inches), you're in luck. If not, time to begin searching.
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,989 Times
Having a lot of people who are quite happy with their bikes I can certainly recommend it as something of quality. Plus it gives me the option if I already have a good folding bike to keep that good folding bike as a good folding bike rather than a meh conversion with little to no warranty.
