Rolling resistance ratings and tire wear
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 337 Post(s)
Liked 786 Times
I’m curious if there are any opinions/experience here concerning how tire wear effects rolling resistance?
As my tires develop flat areas over time, I can’t help but think that it must have at least some level of increased resistance?
Although they may still be safe to ride perhaps they become “performance compromised”?
Likes For SpedFast:
Quoted: 20810 Post(s)
Liked 9,456 Times
As the casing gets thinner, it's more likely to be more supple and roll better, rather than worse.
Likes For WhyFi:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
Check out the bicyclerollingresistance.com series on GP5000S for a good demonstration of rolling resistance as tires wear.
Likes For stevel610:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2628 Post(s)
Liked 5,761 Times
Am curious about the flat areas? I take it you are not skidding the rear tire so is it due to unequal material on your tires wearing faster? What brand and type of tires? Very perplexing since I have ridden for decades on all sorts of rubber and never seen this.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 7069 Post(s)
Liked 11,142 Times
Liked 9,456 Times
I assume that he's talking about the squaring off of the rear tire profile.
Likes For WhyFi:
Quoted: 1431 Post(s)
Liked 1,965 Times
if I recall correctly - rolling resistance increases as the tire wears - but at a certain (later) point the resistance will begin to decrease (but not to the level of a new tire)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,572 Times
I have been idly curious about that, since a person running their tire pressure higher to try to get lower rolling resistance will get more squaring off of the tread. How does that affect the rolling resistance versus a tire that has worn down more evenly thanks to lower pressures...
Quoted: 4847 Post(s)
Liked 3,979 Times
Likes For 79pmooney:
Quoted: 337 Post(s)
Liked 786 Times
Quoted: 337 Post(s)
Liked 786 Times
Quoted: 337 Post(s)
Liked 786 Times
Grupetto Bob
Liked 5,761 Times
Quoted: 511 Post(s)
Liked 646 Times
This is correct. Less tread rubber to deflect means lower hysteresis losses. It sometimes amazes me how people tend to draw the exact opposite conclusion of what the data show, and what logic dictates.
Liked 1,965 Times
Likes For t2p:
Before I had this truly crap cheap Wanda king tires. But the walls are so thin it actually had much lower rolling resistance than my current Gravelking plus tires!! I can cruise a couple mph faster on it but flats so frequently I had to let it go. The walls felt like paper, crazy thin, while the gravelking plus felt like thick leader hide.
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,539 Times
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
Tests by Al Morrison and Tom Anhalt show that brand new out-of-the-box tires have slightly higher Crr than a tire that's been run for 40 or 50 km, but that over time Crr slightly increases. The casing doesn't usually get thinner: the tread compound does. The bottom line is that when racing, we often "break-in" new tires for 40 or 50 km. Some of the lowest Crr racing tires are pretty fragile with very thin treads, so if you use them too much you'll flat during a race and the rolling resistance goes way way up.
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
The Vittoria Corsa's I had showed a very weird wear pattern. They didn't wear the outside longitudinal line tread but the tread thickness of the tire grew quite thin before the tread started wearing. For a long while I thought that the tread wasn't going to wear and then suddenly it wore down very rapidly.
Liked 2,572 Times
I wonder if the initial higher RR has to do with the tire taking a slightly different shape when inflated on a rim than it had in the mold, and then break-in is the casing having loosened up a bit to assume the correct shape. The tread theoretically ought to become more flexible as it gets thinner, but it must depend on whether it gets harder first... my takeaway is that you are probably best served with the thinnest tread you can get away with, especially if you take a lot of calendar time to wear tires out (like I do.)
RUSA #7498
Originally Posted by noglider
Quoted: 511 Post(s)
Liked 646 Times
The initial increase in CRR for new tires could well be that once the tire is out in the real world, there is additional stiffening of the tread rubber due to oxidation.
