How do you protect your floor?
Quoted: 5224 Post(s)
Liked 3,585 Times
how do you protect your floor from solvent & lube drips during cleaning & maintenance
cardboard? old towel? something else?
concrete shop floor, or do it outside.. on that concrete surface.. inside? put down a Tarp. but then use no solvents..
do that definitely outside.. well ventilated area...
Quoted: 4806 Post(s)
Liked 3,933 Times
Garage floor. It used to house cars. Maybe someday I'll clean, prime and paint it but probably not.
Ben
Ben
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
I've got those rubber interlockable floor mats. When they get too messed up, toss and pop in another one.
Poseur Extraordinaire
Quoted: 41 Post(s)
Tarp. More specifically, a large piece of plastic from some large item works for me. When it gets too dirty, I replace it. I currently have two or three 'spares' tucked away.
Quoted: 303 Post(s)
Liked 136 Times
Something absorbent sounds better, plastic lets the lube puddle, then you step in it, roll the tire in it or put your hand
in it. Newspaper on top of plastic or cardboard would suffice with the plastic preventing bleed through.
Quoted: 2952 Post(s)
Liked 3,106 Times
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
It has never occurred to me to protect the concrete floor in my workshop. It is not a showplace, not a palace. It is where I build things and it has all of the dings and stains to prove it.
Dean
Dean
Quoted: 92 Post(s)
One of the shops has 1/2" rolled rubber that was/is an extension from my home gym (middle section of basement) the other portion of my shop has 2'x2' interlocking 1/4" thick commercial vinyl tiles. In that part of my shop I have a thick foam shop purpose mat (3'x5') that goes right in front of my stand. As far as that back shop, I have to throw a large cheap tarp down when I paint frames/forks and to keep the mess/overspray at bay. In the front shop, I built a custom 3'x6' bike wash and have a separate de-greaser station. Because of all of this ^^^^ I don't have any big problems with stuff(s). And it's in a basement anyway.
I feel for the guys that have to work about temporarily in the finished portions of their house. For temp. spots, I would throw some cardboard down and use that 3'x5' rolled foam/rubber mat. Then when you need the space back, roll the mat up and out of the way and put the cardboard to the side.
Quoted: 7353 Post(s)
Liked 2,481 Times
I do bike work in the living room which has a wooden floor. If I'm getting messy, I spread newspapers or paper towels. I clean up with furniture polish. My wife hasn't complained except that I once left the floor too slippery.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Inexpensive rug, like under $30 delivered from Amazon. Get a dark colored one, dropped parts show up better. Roll out when needed, roll up when done, toss out and buy another every 3-5 years or as needed.
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
I sometimes take a project to my man cave in the winter. Absolutely NO solvents! Rarely a little oil, grease is OK as it's use is controllable and localized. I work over a big rug on the floor under the bike work stand. It catches any dropped bits of dirt and crud. When done I roll the rug up, shake it outside, and vacuum my man cave carpet.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
One annoyance is losing small parts on a hard floor, when they drop and bounce.
I have a small 5 x 8 canvas painter's dropcloth with a waterproof plastic layer. I should put it down under the bike stand. Canvas dropcloths are way better than plastic sheets, much easier to walk on.
Quoted: 1163 Post(s)
Liked 442 Times
+1 to the rubber interlocking squares. They have saved my part more than once when it slips out of my hand. The opposite is true with concrete: I have gouged parts more than once while letting them slip out of my hands and fall onto the garage floor or concrete driveway surface.
Liked 10 Times
Piece of a large cardboard box under the work stand to catch anything dripping from lube, cleaner, etc. current one is nasty, proving that it works. I need to cut up a new one.
The only time stuff will drip is when I lube chains. I just put a piece of cardboard under the bike stand. Since we have a lot of stuff shipped, Blue Apron, Chewy, etc, etc, there is a never ending supply of the stuff.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Someday, I would really like to refinish the floors in my work shop, 1930s heart pine, but I am too messy. At least I pulled up the hideous shag carpet!!!
I use a mat under the bike . when done take it outside and hose it off , it save the floor .
Quoted: 18 Post(s)
I just lay a large sheet of corrugated cardboard under my bike. I swap it out every year or so. I also put a rubbermaid container lid under any area getting a lot of extra liquid (wd40, oil, solvents and oil falling ball bearings).
I do some real messy stuff in the bathtub.
If I think things will drip overnight (like after lubing the chain), I'll toss a strip of tinfoil down and put some paper towels over it. Works pretty well.
If doing something really messy with fumes, I'll go outside and use the sidewalk (though living in a high-rise on a busy street, I try to avoid doing that too much).
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Part of my Man Cave, has a wooden floor (was a dance floor back in the day) , just put down old newspaper and toss when done. Chain cleaning done outside (before winter hits ). KB
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
My concrete garage floor is mostly covered with a large scrap of turquoise shag carpet that we ripped out when we bought the place because it was hideous. I don't care if anything gets on it, one of these days I'll 'shop' for a free large carpet remnant on craigslist to replace it.
Sometimes I set up in the living room to work, and I have an old bedsheet (that would otherwise have been thrown away) that I put under the bike stand, to catch any falling grease or dirt, and soften the impact of dropped metal tools on the bamboo flooring.
Quoted: 569 Post(s)
Liked 589 Times
I have two stands, one gets cardboard where I lube chains the other naked floor. Other than chain oil no real issues. As said above cleaning/solvents other then alcohol wipe down is done outside or in a ultrasonic.
