How often do you all find yourselves needing to pump/refill your tires?
Liked 7 Times
Hey there!
So I was just posting this mainly out of curiosity and building a bit of a consensus. I have just recently purchased a Worksman PAV 3 stretch trike and I've been really loving it so far. I've been getting about 5-10 miles per riding day currently and only working up to try and do more! Currently I have one 20x2.125 for the front and two 24x2.125 tires for the rear. The backs need a slight refilling after 3 days or so but the front usually needs it every other day or so. I'm presently 6'5 at 414 pounds and I have the electric kit installed on it. Gonna keep monitoring everything and be certain if there isnt anything else i can do (Aside from losing weight) to really make the tires go the distance. But enough about me.
How often do you all find yourselves needing to refill your tires back to safe riding conditions?
Quoted: 3243 Post(s)
Liked 2,091 Times
5 different bikes, from 25mm road to 2.4" mt. tires, I check and typically add air every ride,
Likes For Steve B.:
Likes For Bmach:
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 913 Times
check w/ floor pump every ride, most bikes are tubeless
Rule #10 // It never gets easier, you just go faster.
Likes For LethargicRush:
Lance Legweak
I check and put in a few pounds before every ride. The higher the pressure the quicker it will lose a little.
Likes For HIPCHIP:
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Depends on the bike. My carbon road bike, I check before every ride (a day or two between rides) and usually need to add a few pounds. The bike I ride off road (I don't say gravel or mountain bike because these rides are back roads and two tracks) have heavy duty tubes and go several rides without needing air.
Likes For Inusuit:
Likes For 10 Wheels:
Quoted: 969 Post(s)
Liked 1,632 Times
Listen to "The Fred"...
There used to be a time I just checked and topped them off about every third day. Not any more. Do note that my Pre-Flight Check List is getting longer and longer...
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
I give my tires a squeeze with my carefully calibrated fingers before each ride. If it feels too smushy I'll add air. That ends up happening every second or third ride.
Likes For MattTheHat:
Top off road bike weekly. Usually needs about 10 lbs. Sometimes I get lazy and go two weeks.
Low tire pressure heavy errand bike, only every couple months.
That's how long it takes to go from pumped to the top of the recommended range ~60lbs to the bottom ~30 lbs.
Likes For GMoser85:
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,447 Times
I check and top them off weekly. Daily I just give them a pinch to make sure they still feel solid and somewhat near the correct pressure. It ain't rocket science.
Likes For skidder:
When I was at my heaviest, I would usually check them and have to add air before every ride. Alway seemed to be down a couple of pounds after every ride.
Likes For dfritch:
Likes For sean.hwy:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
About once a week. Also I normally push my fingers into my eyes tires before every ride to make sure they are not significantly deflated. In my experience good tubes (Schwalbe or Conti) hold the air longer.
Quoted: 2281 Post(s)
Liked 1,710 Times
I generally air them up no less than once a week. If I'm going on a long ride I'll make sure they're topped up before heading out.
Seems like your tire needing air every other day or so might indicated a leak, but you didn't say how far down it goes. If it loses a few pounds, that's not unusual but if it's like half flat or something I'd check it out.
Likes For Milton Keynes:
Bikes: 2019 Trek FX2; 2011 Fuji Absolute 3.0; 1997 Trek 830 (converted to hybrid); 1992 Trek 800 Antelope
Quoted: 36 Post(s)
Liked 906 Times
I am running tube tires. I check every second or third riding day, or if I haven't ridden in more than 4 days or so.
Likes For rje58_too:
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I pump up the tires before each ride. I don't like pinch flats.
Likes For cyclist2000:
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
One of the harder to accept habits about bicycling is the use of a tire pump almost every ride to top off your tires. I have worn out several floor pumps over the decades and expect to wear out a couple more, the universe willing.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Why is it hard to accept? I’m not aware of a pneumatic tire system on any vehicle that holds air forever. Topping off bike tires is just part of the routine. It’s not a big deal.
Expired Member
Quoted: 3683 Post(s)
Liked 5,447 Times
And why the bunch of necro-revivals?
