Cervelo paint matching?
I dropped a chain and have a few scratches on the frame of my S5 as a result, and after looking around it appears that Cervelo ops to use their own proprietary paint formulations in lieu of something like an automotive manufacturer’s paint code and doesn’t sell touch up paint or offer assistance with finding a match. Any suggestions on what I should do here?
Some have suggested using fingernail paint but that seems like a sloppy solution given the cost of the bike.
Quoted: 6199 Post(s)
Liked 4,816 Times
All the auto makers have their own formulations too for color. So why should bike makers be any different?
If you don't like the idea of fingernail polish then go to your local auto parts store and browse through the touch up paint. Still whether it's auto paint, fingernail polish or the actual bike paint, how well a job you do is going to stand out way more than a slight color mismatch.
Still, try the fingernail polish. It'll probably flow out smother and it'll cost you less since it'll come in smaller quantity.
Or do what I do for scratches. Nothing.
Sunshine
Quoted: 10970 Post(s)
Liked 7,498 Times
...or leave the scratches.
Likes For Hank_Scorpio:
Liked 4,816 Times
yes, most automakers have their own color formulations but they publish them such that they are widely available from third parties in addition to being published to open-source databases, such that automated paint mixing machines can produce a perfect match to the original paint on an ad hoc basis. In many cases the OEM produce their own branded touch up paint, which has been the case with every car I’ve owned. Bike manufacturers do none of these things, so that is the difference.
A lot of auto parts stores can now match paints and sell you a rattle can of it, also a clear coat if needed. They can do a computerized exact match but need a 2 inch or so flat part of your bike to put their scanner on. Problem is there's no such place on most bikes,at least not on the two I've tried this on. Not the fork or top tube ,which I thought might work. But, the paint guy/girl in the store has likely gone to paint school and can usually come real close on his own. It's worth a shot. Keep in mind that after a can of primer,one of paint and one of clear you'll be out 80 bucks or so, but those cans will last forever. I've been very satisfied with the results when I've gone this route. You might even find something premixed on the shelf that could come close,all depending on your level of discernment.
I'll edit this to add that you need to find a helpful store. First place I went it was off the shelf or nothing, second place had a great younger person that took it as a challenge and mixed up a few samples before nailing it. You might ask at a bike store if they can recommend a place.
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
I'm dealing with an insurance claim after getting hit by a car a couple weeks ago. Damage to the bike, a Caledonia-5, includes a few scratches to the frame. The frame is warrantied for life. I sent an inquiry to Cervelo support about methods to repair the frame damage. This was Cervelo's response:
Make sure any repairs are limited only to minor touch-ups.
...attempting to repair or repaint a frame beyond simply applying touch-up paint will void the warranty that applies to your frame. Much of that has to do with the safety of the frame. Once it is repaired or altered in any way up to and including sanding and repainting, we can no longer vouch for its safety and this is why the warranty becomes void in cases of attempted repair and repainting.
