Older Carbon Roubaix on a trainer?
Hello, I have a 2010 Spec Roubaix Expert and I’m the original owner. It has 2,000 miles or less on it, lifetime. I have had many other bikes over the years but also kept this as my first carbon road bike, that I love.
Question, would you have any hesitation making this your trainer bike (Wahoo Kickr)?
I don’t want to use my brand new road bike for 1,000 trainer miles a year, I would prefer to use this one. Just not sure if these 2010 carbon bikes are at risk in that scenario?
Photo attached so you can see what I love about it Thank you!
Quoted: 682 Post(s)
Liked 453 Times
Been using a 2011 carbon Cube with Ultegra 6700 on my trainer (wheel on and then kickr core) for a few years. Bike is doing fine.
Just be careful you cover anything steel. Lost a shifter* to rust and then the bottle cage bolts. Have my fan front right to reduce the chances of sweat hitting the chain.
* bikeradar’s 6700 review back in 2009 said “Cyclo-cross riders and roadies who regularly head out in nasty conditions should also take note that the Ultegra STI levers’ shift internals are just as perilously exposed as they are with Dura-Ace – you can literally see the various ratchets, pawls and springs without even pulling back the hoods.” - and that’s exactly where mine went rusty. Sweat must have found its way round from the hoods. I keep them covered with the towel too now.
Likes For choddo:
Quoted: 432 Post(s)
Liked 461 Times
Not sure what the risk is - are you worried about clamping the dropouts on the trainer? If it's a full carbon dropout I might put on some 1mm nylon washers between the clamping surface and the dropouts but I don't think it's an absolute must.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Likes For datlas:
Originally Posted by tFUnK;[url=tel:23073926
23073926[/url]]Not sure what the risk is - are you worried about clamping the dropouts on the trainer? If it's a full carbon dropout I might put on some 1mm nylon washers between the clamping surface and the dropouts but I don't think it's an absolute must.
Quoted: 682 Post(s)
Liked 453 Times
Asking more about the carbon seat stays and chain stays. I know manufacturers used to specifically call out trainer use as a warranty voiding activity on carbon bikes. I’m not sure it ever proved to be an actual concern and I know they have since stopped those warnings but that is essentially my question.
Likes For choddo:
I use my circ 1999 Trek 5200 carbon on a Wahoo KickR Snap. Probably at least 5 years.
All in the saddle stuff and I certainly am not putting out the big watts like in the picture above.
Do it.
Do it.
Likes For bblair:
Quoted: 682 Post(s)
Liked 453 Times
I can stand and do about 1100 watts for half a second but it’s an odd technique. I think the kickr has a bit more side-side flex with those feet than the core or snap.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
I had the Tarmac version of that bike, it was a Saxo Bank team frame. Loved that thing. I still have what's left of it in the garage. Was a great bike.
I have a 2007 Tarmac on the trainer. I have 0 worries about it.
Likes For ls01:
Quoted: 432 Post(s)
Liked 461 Times
Likes For tFUnK:
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
I have almost 6k trainer miles on my 03 Time carbon frame. Sometimes I put out 1000+ watts. Zero issues.
Likes For Eric F:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,656 Times
Absolutely NOT! But it sure makes hill climbs easier.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Ah yes, the skunk bikes! The trainer is a perfect place for that Roubaix. In fact it is as if the dudes at spesh had that in mind when they designed it.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Actually, I don't know how people can ride a trainer without standing occasionally. If I didn't stand and pedal every few minutes, my butt would become hamburger.
he said member
Bikes: yes please
Liked 1,951 Times
Get a rocker plate if you want to stand up and crank. As far as the chain and seat stays go, it took a 96 Buick le Sabre to have any effect on mine. I doubt if riding a trainer will hurt them.
Likes For ls01:
Instead of a riser block I have the front wheel placed on a stack of books. This allows the front end of the bike to "wiggle" as I ride which feels more natural to my senses.
Likes For TiHabanero:
Quoted: 682 Post(s)
Liked 453 Times
That sounds like it’ll fall in a sprint i just have mine on the mat, because the kickr (and most direct drive trainers I think?) has the back of the bike at the right height for that. My front wheel moves a bit. Haven’t used a riser block since I had a bkool wheel-on.
Quoted: 2490 Post(s)
Liked 2,961 Times
Grupetto Bob
Liked 5,656 Times
Quoted: 3957 Post(s)
Liked 7,310 Times
Habitual User
Liked 8,100 Times
I tend to stand for a bit every 10-15 minutes.
Likes For Eric F:
he said member
Bikes: yes please
Liked 1,951 Times
