Trek Checkpoint rear wheel alignment
Alberto
I have a Trek checkpoint ALR frame that I got as warranty replacement. So, I swapped all the component to this new frame but I have an issue, the rear wheel if it is aligned to the seat post tube is close to the chain stay in the drive side. if I align the wheel to the center of the chainstay, it is out of symmetry with the bike frame. Is this normal, to be a little close to the drive side than the non drive side.
Drive side
Non drive side
Few millimeters to the left side, actual position in the bike.
Drive side
Non drive side
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
My bike has the same issue (mine is a Canyon). I'm guessing its to keep 2x drive train and a narrow Q-factor. Probably not as big an issue on a 1x only frame. I dished my rear wheel to move it over about 1mm.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Brands make all sorts of design compromises to shove fat tires into frames while keeping a short wheelbase(425mm here).
Super pinched chainstays that give up stiffness.
Different shaped chainstays to allow for a road double crank.
Dropped chainstays to give crank clearance.
Elevated chainstays to give crank clearance(pretty sure this also gives up stiffness).
Trek making the DS chainstay closer to the tire isn't a surprise. It lets a road crank be used while still fitting a wide tire and keeping the chainstay length short.
Some could view it as excellent design while others could view it as a compromise to allow for other compromises.
Liked 415 Times
Ugh, its not a defect, it looks to me to be how the frame was designed. Please don’t go modifying your frame or filing anything.
Its not an uncommon design with Gravel bikes (i.e. running wider tires on road components). If you are running 2x, there just isn’t a lot of space between the small chain ring and the tire. Some designers resolve this by making the frame1x only, some by dropping the chain stay, some by using mountain bike bottom brackets, some by giving tighter clearance on the drive side. Its all a balance and compromise when you are engineering something.
Sunshine
Liked 7,491 Times
Wow, if that's a manufacturing defect, it's a crazy one.
The chainstays arent even close to being the same bend- the DS stay is clearly bent at a lesser degree and the NDS stay flares put earlier from the bottom bracket.
I assumed this is due to clearing the chainrings combined with 425mm stays. If they were 440mm stays, there would be less need for the the asymmetry.
Alberto
Thanks for the replies. I went to the bike shop to compare the frame with others of the same model and the variation AL4. The AL3 and AL4 is slightly aligned to the center of the NDS and DS but more centered to the seatpost tube. Now, in comparison with the ALR4 in black and blue the wheel is closer to the DS, but with some extra space. So, I decided to move the wheel 1 mm. Another fact is that the rim is more or less centered to the frame only with a variation of 1mm, this can be due to the shape of the chainstay in both sides.
Bikes: Specialized DIVERGE COMP DSW CEN (MY 2016), Specialized ALLEZ EXPERT DSW SL (MY 2016), Specialized SEQUOIA (Base, MY 2017), Trek CHECKPOINT ALR 5, Cube REACTION HYBRID SL 500 (MY 2018)
An answer would be highly appreciated! Thanks!
Randomhead
Liked 3,698 Times
I'm pretty sure by "moving" he meant adjusting the spoke tension to move the wheel. I'm not sure I would bother, it likely isn't hurting anything
Thanks for the reply. I managed to center the wheel between the seat stays and to the seat tube. To get a little more Clearance to the DS chain stay I moved the rear wheel almost half way of the possible adjustment of the stranglehold dropouts backwards. I only have the feeling that the dropouts are not "perfectly" aligned now because the throughaxle fits not as easy as on the fork dropouts. Also the threaded pins for the stranglehold adjustment protrude unevenly from the adjustment bolts (6 mm on the left to 7 mm on the right. So I tried to figure out wether the rear end of the frame is symmetrical by putting a lace through the dropouts (without and with the stranglehold bolts assembled) and guiding it arround the steerer tube and then measured the distance of the lace to the seat tube on DS and NDS. Turned out that the distance on the DS always is 2 mm bigger than on the NDS even with the position of the dropouts where the wheel is centered. Is that deviation normal or within the tolerance?
Extinct
Quoted: 9 Post(s)
Are the front and rear tires aligned? If you find a long straight crack in the sidewalk or such, if the front wheel rides in crack, is the back tire also on the crack?
did what you suggested in the gaps of our sidewalk and it Looks that the rear wheel seems to be pretty good aligned to the front wheel. I attached two pics of my "measurement" of the rear frame though.
Seems that I am not allowed to add pictures...
Sunshine
Liked 7,491 Times
OK, here we go...
Liked 415 Times
If you want to keep road bike Q-factor, use large tires, and have a 2x compatible frame - you have to compromise somewhere.
Some put a thin metal plate on that part of the chain stay, some go 1x only, some drop the chain stay, some use a wider bottom bracket - pick your poison.
Don't true the thing on a truing stand. Just dish the wheel a little to move it over 1mm if you really want to squeeze the largest possible tire in there.
I thought we answered this 6 months ago. This is not unusual - it is how the frame is designed (and Trek isn't the only one).
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I'd be concerned about this if it were my bike. Why should you have to dish a wheel specially for a certain frame?
I am Not concerned about the asymmetry of the chainstays. It"s the misalignment of the seat stays that I worry about. Because independently from the asymmetry of the Chain stays the dropouts should bei symmetricaly behind the seat Tube or am I wrong? Ist the fact that the DS drop out is a bit more to the right a consequence of the asymmetry of the chainstays?
Likes For eastsideride:
