Wave Cell helmets by Bontrager
Old 09-17-19, 06:43 AM
GaIslander
GaIslander's Avatar
Bikes: Trek Domane 6.0 DI2, Trek FX 7.5, Electra Townie Path
I am curious to know what others experience is with the these helmets. I purchased a Specter Wave Cell Helmet which looks and fits great. I have found that the helmet is so poorly ventilated it is unusable here in warmer weather and higher relative humidity. I am thinking of cutting out sections of the wave cell material blocking the vents to improve the air flow.
GaIslander is offline
Old 09-17-19, 08:58 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 969 Post(s)
Liked 193 Times in 140 Posts
Don't do that. Your helmet is designed carefully to protect your noggin, and cutting stuff out will leave you unprotected in unpredictible ways. But doesn't Trek/Bontrager have a 100% satisfaction guarantee? If the guarantee applies, trade the thing in for a MIPs model (the Bontrager Circuit MIPs is the same price).
The research seems to show that the Wave Cell and MIPS technologies both do a good (significantly better than non-MIPS and non-Wave Cell) job of protecting your noodle.
Thanks for sharing this data point, in any case.
WizardOfBoz is offline
Old 09-17-19, 09:39 AM
JasonD67
Bikes: BMC Teammachine SLR02 Disc, Cannondale CAAD 4
Quoted: 77 Post(s)
Liked 13 Times in 9 Posts
I read several similar complaints about the wave cell helmets...poor circulation. I bought a MIPS helmet instead. I guess a wave cell helmet would be great in the winter when you don't need cooling?
Definitely don't cut out the lining material, that would be negating the benefit of the wave cell protection.
JasonD67 is offline
Old 09-17-19, 10:38 AM
tagaproject6
tagaproject6's Avatar
Quoted: 542 Post(s)
Liked 239 Times in 127 Posts
Any chance of returning the helmet and getting a different one?
tagaproject6 is offline
Old 09-17-19, 02:08 PM
sarhog
Bikes: Specialized Roubaix, Salsa Cutthroat, Santa Cruz Tallboy
Quoted: 19 Post(s)
Liked 18 Times in 9 Posts
I’ve been using a Specter Wave cell helmet since April with no issues. Many 90+ and high humidity days. I guess ventilation is subjective.
sarhog is offline
Old 09-17-19, 04:06 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 66 Post(s)
Liked 29 Times in 22 Posts
Any Bontrager product can be returned within thirty days for any reason.
Rogerogeroge is offline
Old 09-17-19, 09:03 PM
canklecat
canklecat's Avatar
Quoted: 3491 Post(s)
Liked 973 Times in 649 Posts
Save it for cooler weather. Several friends got WaveCel helmets this year and wear 'em even in Texas summer heat. But the helmets looked hot and felt heavy to me.
I got a POC Omne Air Spin. Best ventilated helmet I've worn -- the design really scoops air across my scalp, and I can feel it even through my hair, which is long and thick. Other folks with POCs say the same of their Octal and Ventral helmets. POCs have thicker EPS foam than most helmets and should offer good protection.
The POC Omne Air Spin is their lowest priced helmet, more of a commuter style helmet but with excellent ventilation. The Octal and Ventral are more roadie oriented. But I'm pretty satisfied with the Omne Air Spin, although I can see the overhanging brow at the top of my peripheral vision when I'm in the drops on my road bikes.
canklecat is offline
Old 09-17-19, 09:38 PM
GGreenhorn
Bikes: Giant Escape 3
I was going to buy a different helmet (Bell Z20) than OP from Trek and asked about return policy. The lady said 14 days to return and it cannot have been worn, unless it was just around the house for fit and sizing. So it would seem they have a diffident return policy between Bontrager or other brand products... I did not use, returned and bought a Specialized Tactic III from a different place. Reason being the Bell Z20 was a bit much bubble head and I wanted something with a small visor.
GGreenhorn is offline
Old 09-18-19, 10:21 AM
Igotdibs
Senior Citizen
Igotdibs's Avatar
Bikes: Trek Emonda SLR7 Disc, Trek Madone 5.9, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 63 Post(s)
Liked 423 Times in 128 Posts
I've been using a Specter WaveCel helmet since mid June and I don't find it to be heavy or hot. (shrug)
Igotdibs is offline
Old 09-18-19, 11:30 AM
Hiro11
Bikes: To the right: opinions, not facts.
Quoted: 511 Post(s)
Liked 71 Times in 38 Posts
I'm pretty happy with this helmet. I have not found it "hotter" at all and i use it all the time in hot weather. I am bald and clip my (remaining) hair short, which apparently makes a difference when it comes to ventilation with this helmet. It does weigh 50-100g more than a comparable MIPS helmet, something I don't personally notice but others might. I will say it's very comfortable for me and has a very good retention system. Also, the magnetic clasp is very easy to use. Turn your glasses upside down and the helmet can retain them well in the vents.
Two relatively minor complaints I do have:
1. The helmet is cut fairly low in the front, likely for impact reasons. This does not impinge on the glasses I wear but it gets close, especially with a cap on underneath the helmet. I would check fit with glasses and a cap before buying this.
2. The chin strap loosens too easily. I have to re-tighten mid ride every once in a while. Hardly a deal killer but annoying.
Hiro11 is offline
Old 09-20-19, 10:30 AM
GaIslander
GaIslander's Avatar
Returned the Wavecell Specter for a Circut MIPS
After reading all the replies, I still felt the helmet did not have enough ventilation for me and my area. I took the Wavecell Specter to the my local Trek Dealer - LBS and they quickly exchanged it for a Bontrager Circuit MIPS helmet. All is good. Thanks.
Old 09-20-19, 11:05 AM
livedarklions
Cyclesomatic
livedarklions's Avatar
Bikes: 1994 Specialized Allez Pro; Motobecane Fantom CX; Giant OCR A1
Quoted: 3576 Post(s)
Liked 2,299 Times in 1,318 Posts
It's almost like OP lives in Georgia and you live in Washington state.
livedarklions is offline
Old 09-21-19, 10:04 AM
Theycallmegio
Quoted: 26 Post(s)
Liked 5 Times in 3 Posts
I have wave cell helmet.
i definitely feel less ventilation. What irks me more is not being able to scratch my head through the vents when I get an itch.
I also like to dump water on my head periodically during a ride, wavecell kinda sucks for that.
Otherwise its a fine helmet
Theycallmegio is offline
mrblue
Road Cycling
54
08-03-17 01:22 PM
noglider
Winter Cycling
7
01-12-16 02:56 PM
ganchan
General Cycling Discussion
13
10-19-15 12:59 PM
B2mac
Hybrid Bicycles
1
04-24-14 02:45 PM
Phantoj
Advocacy & Safety
33
06-14-11 04:50 PM
