It seems like you can't trust much at all these days
Quoted: 3352 Post(s)
Liked 1,054 Times
Late last summer I bought a new RD for my trike. It seemed to work fine. But then yesterday I was doing my pre-season checks, cleaning, and repair on the trike. Among other things, I pull off the RD, pull the sprockets out, and clean and lube them. When I pulled both of them out, there was almost no grease or oil in either one!!! The bearings were glazed over with pretty much dry grease. I guess those of us that do almost all of our service work need to pull apart RDs and other assemblies to make sure they are lubed right before we use them. But why is this**********
Quoted: 811 Post(s)
Liked 1,946 Times
Ran into this same thing with spark plugs that were difficult to reach (car had to be raised and the front right rim/tire removed). Now I ask for all my parts and check if they are legit. Some mechanics are unethical and looking for the quick way out thinking you will not check nor complain. One should know enough about bike repairs to know what the details are even if not wrenching yourself.
With a mighty wind
Quoted: 1073 Post(s)
Liked 841 Times
Meh,
If they weren't squealing or binding, it doesn't matter. Does anyone know how fast a pulley turns at 100rpm?
It's not fast. It won't bind up. It doesn't generate heat.
Quoted: 980 Post(s)
Liked 776 Times
Quoted: 6882 Post(s)
Liked 10,872 Times
Quoted: 18319 Post(s)
Liked 15,288 Times
Never had any such problem.
Likes For indyfabz:
Bikes: Trek 7.4 FX
Quoted: 1026 Post(s)
Liked 912 Times
Although I may not inspect the RD pulleys on a new bike... within the first month or 2 I will usually partially disassemble the moving parts to ensure proper lubrication is in place. Granted, I don't buy a lot of new bikes, but if anything is handed to me that is used I will go through it with a fine tooth comb no matter how much the seller assures me it was recently taken care of.
Likes For TakingMyTime:
Non omnino gravis
Likes For DrIsotope:
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,092 Times
Taking something apart to put more grease in it for no reason other than you think it needs more grease is wrongheaded. It might even be detrimental. We tend to overload bearings on bicycles with grease and all it does is attract dirt to get into the bearings that we think need more grease. The load on bicycles is small and the friction reduction needs are very low. Slathering grease in a thick layer on everything isn’t a general solution to a problem that probably doesn’t exist.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1063 Post(s)
Liked 771 Times
Likes For flyjimmy:
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
But the question is; did you buy it online or from your LBS?
The manufacturer should care enough about the product to properly lube before sending it out.
I just replaced the presta / schrader valve tip on my Nashbar 35+ yr old floor pump. The new one won't stay on the hose. GRRRRR I'll have to pick up some "o" rings and try to fix it.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
It would seem that anything I've purchased in the last two decades is only lubed with "assembly" lube. Which means a very thin coat of something that resembled oil or grease at some point.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
If you had only paid for Dura-Ace you would have ball bearing pulleys and you'd know that Shimano had oiled them with their special oil in their special room
Genesis 49:16-17
Genesis 49:16-17
Quoted: 2428 Post(s)
Liked 2,885 Times
I worked in bike shops for many years starting in the early 1970s. I don't recall ever seeing any new derailleur with visible grease at the pulleys, except maybe the Huret derailleurs that used pulleys with ball bearings. Huret's were also the only pulleys that ever seized, as I recall, ending up lopsided from chain abrasion.
Quoted: 663 Post(s)
Liked 496 Times
I once had a new derailler that wore out within a year so that the cage wobbled left to right excessively causing poor shifting. It may have been poorly machined in the first place. I don't know why your derailler had no lube but I do know that is is not uncommon for people in a beaurocracy to be promoted beyond their level of competency. The outstanding example is the Challenger disaster and more recently Boeing's headaches so this occurs at all levels.
Likes For berner:
Quoted: 693 Post(s)
Liked 903 Times
Quoted: 1572 Post(s)
Liked 642 Times
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Derailleurs? How many gears do you need?
WALSTIB
Maybe DR made on a Monday or Friday. Or cost savings have reached a peak into madness
I think the pulley assembler somewhere in the Orient was sick that day so the pulleys didn't get lubed. Turned out the guy had Coronavirus, so the OP should be much happier.
