Help me rebuild my '78 Trek TX 900
Quoted: 5888 Post(s)
Liked 3,471 Times
It's time for me to rebuild my '78 Trek TX 900. I robbed the parts off the original build for other bikes. Here's the problem: I've decided on the gearing and now I need to figure out the derailleurs. I'm going to use an IRD wide compact crank (46/30) with a 7 speed 12-28 Maillard freewheel. I have three options:
(1) Simplex retrofriction shifters, Campy NR front derailleur, and Campy SR rear derailleur. I'd love to get away with this but the max chain capacity on a Campy SR is 26 teeth and I've far exceeded that on this set up (32 teeth). I could try to get this to work but I suspect I won't be happy with the results, right?
(2) To heck with keeping the bike campy and/or European and just run as (1) above but with a shimano crane long cage rear derailleur. It's a pretty rear derailleur and it can handle this. The problem with this set up is that if I run a crane RD, I'll be sorely tempted to pick up first gen dura ace front derailleur and downtube shifters. I was hoping not to spend xtra cash on this project. BITD of course no one would have cared if you mixed parts like this (simplex retrofriction shifters, campy NR FD, and crane RD).
(2) (a) I guess I could run the long cages for a campy RD as well but it wouldn't surprise me if that crane shifts better than a campy RD retrofitted with long cages. This set up would be simplex retrofriction shifters, campy NR FD, and Campy RD with a longer cage from Soma.
(3) I could run huret new success rear and front derailleur and simplex retrofiction shifters. That has a capacity of 30 teeth which will work if I change out the freewheel to 13-26 7 speed. I like this because it keeps the drivetrain European (and the parts on the bike are almost all European). I like sachs new success stuff but it's not the best RD out there.
This is the sachs huret new success I'm thinking of using in option 3:
Sachs-Huret New Success derailleur (47.1D)
Here is the bike before I tore it down. The brakes (campagnolo nuovo record) and wheels (mavic hubs, mavic ma40 rims) are staying. I'm only changing the crank, freewheel, and derailleurs.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Well the stuff you took off was perfect. Faced with the remaining choices, I'd pick door number 2(a).
Likes For Hudson308:
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
Liked 3,471 Times
I don't disagree. The cyclone derailleurs are likely better than any of the above 3 options. What can I say, I needed those derailleurs for an early 70s Fuji Finest I rebuilt.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
You should be fine with Option #1 . I ran an SR RD on 50/34 + 12/28 (also a total of 32 teeth) on a couple of bikes and they shifted just fine, even at Eroica in the gravel and in Wisconsin on those steep hills.
Different data point but same result: ran 50/28 with a 12-28 freewheel at Coppi using Dura Ace 7400 6 speed in friction setting. That's 38 teeth and it also worked just fine. Biggest problem is getting the small/big combo right so the pulley wheel doesn't hit the big cog but judicious use of horizontal dropout position and chain tension usually takes care of that.
Or you could sell me that sweet, sweet Trek 900 frame and stop worrying about it!
Liked 3,471 Times
You're right the 46/30 crank, 12-28 freewheel (which is your old freewheel btw!) is designed for those Wisconsin hills. I wasn't sure I could get option 1 to work but I'll give it a shot.
Quoted: 7348 Post(s)
Liked 2,467 Times
I take it you haven't considered a modern drivetrain? The 11-speed stuff is amazing, not because of the 11 speeds but because they've made changes to the design so they work better than anything ever.
Liked 3,471 Times
Yeah that would be plan 4, lol. I could go with something silver in Campy. I'd have to spread the frame though. It's currently set at 123 and I'd have to spread it to 128. Not a big deal but a consideration. Good idea for sure.
Quoted: 786 Post(s)
Liked 520 Times
My '78 930 runs 53/39, 13-28, and the SR RD does fine, with room to spare. +1 on retrofriction, and a Campy FD. And yours must be slightly earlier than mine which has tt cable guides.
Liked 3,471 Times
Beautiful bike. Dura ace crank? I have no doubt that the SR RD can handle a 12-28 freewheel, I'm a little skeptical that it can handle enough chainwrap but I guess I'll find out.
I miss my 930.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Likes For nesteel:
Quoted: 604 Post(s)
Liked 1,063 Times
Nice bike, I’d opt for choice #1 and keep the Campy. I was able to keep the NR rd on my 77 TX900, switching to a Sunrace 12-28 freewheel, and a newer chain. Shifts as well as a NR normally does, which is not near as well as a long cage Cyclone GT would. Possibly my next upgrade.
Tim
Tim
Likes For tkamd73:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
Retrofriction shifters and the Cyclone derailleurs.
Commence to jigglin’ huh?!?!
