Repair
Repair
Hi I have a MTB with Shimano Octalink Crankset. The thread on the right crank arm has gone where the pedal is attached. Is it possible to replace only the arm or would i need to replace the whole crankset.
Thanks
Raymond
Thanks
Raymond
Quoted: 529 Post(s)
Liked 255 Times
If you got one which is the same length but different design, you could replace just one, but it may look odd.
If you want it to look good, and don't find an identical one, you should replace both.
Likes For alo:
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,463 Times
Find an old-school bike mechanic and they can tap and coil your crank arm to restore the threads so you can use it again. Ask around your local shops. Chances are someone will be able to help you.
Brent
Brent
Quoted: 1324 Post(s)
Liked 927 Times
Is there a bicycle co-op near you? If so and when they open after this COVID-19 thing is under control, you might get lucky and find another right side crankarm there.
Cheers
Cheers
