Is this unsafe?
Is this unsafe?
The other day I added some spacers to my cog to move it out a bit and get a straighter chainline. I would have clearance issues if I moved the chainring to the inside of the crank spider so this was kinda my only option short of shifting the entire hub over with axle spacers and having to re-dish the entire wheel...ugh.
Anyway, I ended up settling on two spacers between the hub and the cog which gave me a much straiter chainline. However, now there arent enough threads exposed for the lockring to screw down all the way. The way I have it now, the lockring is greased and tightened properly but there are still about 2mm of lockring threads that are not being used. I've been riding it like this with no problems for a few days but I'm still concerned that this is not safe. Am I right to be concerned or is this fine? Am I in danger of stripping the threads on my lockring or hub or anything?
I took pictures of what I'm talking about but apparently I'm not allowed to post them until I've made 10 posts on this forum so we'll have to do with just my description for now.
Thanks!
Thanks!
Quoted: 18376 Post(s)
Liked 4,511 Times
Liked 4,511 Times
Are you using brakes on the bike?
It looks to me like you might be able to get away with one spacer behind your rear sprocket, but not two.
Are you riding this as a "flip flop", or only using the fixie sprocket?
One thing you might be able to do, if you can find a narrower lock-nut, you could put the thin lock nut on the right side of the axle, add a spacer to the left side of the axle, and dish your wheel slightly. However, that wouldn't necessarily work if you're doing a flip-flop.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The lockring is barely even attached to the bike.
It could hold through the apocalypse or it could fail. No one can say.
I wouldn't ride that. I'd want it to be better, even if just for the piece of mind.
-Tim-
-Tim-
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
Remove one of the spacers and test it. I won’t say it’s unsafe, unless you’re back-pedal stopping. If that’s the case, you absolutely need that lock ring properly installed. If you’re only using rim brakes, one could argue that you don’t even need the lock ring. If it were mine, I wouldn’t ride it that way. You may need to address the crank issue, in order to get a decent chainline.
I wouldn't be happy with that, looks like you're risking the threads on the hub/lockring.
I'm assuming your chainring is too big to clear the frame on the inboard position? Have you considered if a combo of a smaller chainring and smaller sprocket would fit and give approximately the same ratio?
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
It might hold, especially if you avoid using your legs to stop (use brakes). But if it fails, the least problem you can expect is ruining the lockring thread on your hub. More serious would be not being able to stop or slow when you really need to. Why risk it? Is there any reason why you couldn't adjust the chainline by e.g. using a slightly shorter bottom bracket axle instead? Or a cartridge that allows lateral adjustment?
Quoted: 2952 Post(s)
Liked 3,106 Times
What about a different width BB spindle?
Quoted: 4806 Post(s)
Liked 3,928 Times
Easy way to get this right (but it involves wheelbuilding skills). Remove the cog spacers. Remove the same amount of spacers on the right (drive) side hub axle. Put those spacers on the left side, Now, loosen the drive side spokes, tighten the non-drive side spokes and re-true.
I don't have time now to spell out in detail how to do this, but this will get you a proper chainline and you have all the treads engaged.
Ben
Ben
Thanks for the replies everyone! Super helpful. Also thanks to Cliffordk for posting the pics.
So it seems like my intuition was right after all. To answer some of your questions:
Yes I do use a front brake with this bike, a disc brake in fact. However I do also stop and slow down using my legs a good percentage of the time as I dont use a rear brake.
My bottom bracket is actually already a 103mm so I don't know how much narrower I can go. My chainring is only 46t too so I think the clearance problem is mainly with the way my frame is made (also, I didn't actually test this configuration so it could just be that I'm terrible at eyeballing...).
Like I mentioned in the OP, I have considered using axle spacers to scooch the whole hub to the drive side a bit and then re-dishing the wheel like some of you suggested. But I just figured I'd check here first to see if my lazy solution would work instead. My main problem with axle spacers, besides the fact that re-dishing the wheel will be a lot of work, is that I couldn't really use the other side of the hub for another cog (flip flop style) with the rim being dished off center.
Sounds like everyone is in agreement that my spacers have to go though so that's what I'm gonna do. I might try one spacer and see if I can get the lockring all the way on. If not I guess I'll just have to use axle spacers and fix my chainline the hard way.
Thanks for the input everyone! Much appreciated.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Generally when someone has to ask "is this unsafe" or "is this safe" the answer is usually pretty clear it is not SAFE. Not sure what your oddball set up is but something is wrong because you shouldn't need spacers behind a cog ever and unless your chainline is so heinous that it causes issues, I wouldn't worry about it but to be as safe as possible bring the bike down to your local shop and have them take a look at it and allow them to make it safe for ya.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
A cassette spacer has no belonging in a fixed gear drive train.
Work on chainline from the crank. Are you running the correct bottom bracket for the cranks? Is the chaining on the right side of the crank spider?
So is the consensus that spacers + track cogs = bad news in general? I feel like I've seen other people do this. The spacers came with my hub too so I just kinda figured it was a valid option.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
yes and yes. I have sugino rd2 cranks with a 103mm bottom bracket. The chainring is on the outside of the spider (I bought the cranks in a set with a messenger chainring and it came installed like that.) Like I said before, it doesnt look like there would be enough clearance if I moved the chainring to the inside of the spider.
- Soli Deo Gloria -
Liked 736 Times
Ben
Ben
-Tim-
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
how far is your chainline off that you would even consider this a good option?
what frame are you using? What is the rear spacing? I notice that you are using a set of velo orange grand cru hubs, which are a bit different than typical track hubs, because they are specifically designed to be used with 120,126, 130 & 135mm spacing. Normal track hubs are 120mm only. So your hubs have different spacing and longer axles. My guess is this is where your issue is. Your hubs also have more threading than a standard track hub for a fixed sprocket does, to allow more threading for a freewheel. This is unique to these hubs I believe, and velo orange mentions this on its website. This can pose a problem with some fixed sprockets, depending on how the sprocket teeth are ‘dished’ on the sprocket. (not all sprockets have teeth that are centred) What spacing do you have the hubs set to? Yes you can use spacers. Your hub came with those spacers did they not? But the amount you can use is very limited because there is only so much threading, and if you are riding fixed and using back-pedal braking to any degree, you need a properly installed lock ring. My guess, is that with a standard 120mm track hub, your spacing issue wouldn’t be so severe. The problem is that track hubs are designed for 120mm spacing. Deviating too far from that becomes an issue. A hub designed to be able to be used on spacing as wide as 135mm, is going to create its own issues.
I actually took one of the spacers off last night and the situation improved alot. Ill post them once i have 10 posts and the forum lets me...
Nice touch hahaha.
Yeah I get it. Obviously I'm not a bike mechanic of anything. I've just been riding for a while and have recently started to get into doing my own upgrades and bike maintenance. Part of the fun of the hobby no? I guess part of learning is making dumb mistakes and getting called out by people with more experience. Basically the purpose of the clickbaity title of this thread.
To answer your question. The chainline is not heinous or anything. Im just enjoying the process of trying to get it right. I used spacers that came with the hub for the simple reason that it was the easiest and cheapest solution available to me at the time. The lockring thing in the OP concerned me though so I started this thread to get some input from people who know better than me.
Thanks for all the input so far guys!
Sorry for the triple post but that last one made 10 so now I can post pictures.
Like seamius and CliffordK suggested, I took one of the spacers off and Id like to hear everyone's input. I would love to try the other solutions that people suggested but most of them require me to either spend money on new parts or dish my wheel off-center which would prevent me from using the threads on the other side of the hub.
Like I mentioned before, I don't really have a huge issue with my chainline that effects the quality of my ride. It probably would at most effect the longevity of drivetrain but its not like I have 100s of dollars invested in it. I'm mostly just doing this for a bit of fun.
That said... I don't think crashing or ruining new hubs is fun so I want to make sure everything I'm doing is above board.
So here are some pictures with only one spacer. Better? Still stupid? Is the minor improvement not worth the risk?
I ended up taking off one of the spacers.
And I still get a pretty strait chainline.
The lockring goes on much more satisfyingly now. It looks to be sticking off a bit still but it has a bevel that makes it look like that even without a spacer. All of the threads are engaged.
Took a closer look after my ride today and it seems that this may be contributing to weird chainline issue (?). Looks like the bottom bracket isn't flush with the frame. I had this installed by a bike shop because I didn't have the right tool so I hadnt paid it much attention till now. Since I didnt do this myself i dont know how it works, could I just screw it in further to shift the cranks over a few mm? Or is that not how it works?
PS. Please forgive the griminess of my bike in these photos. I commute 8 miles each way in downtown Chicago. Its January...
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Quoted: 278 Post(s)
Liked 122 Times
Long as you don't plan on running bmx pegs anytime soon it looks nicer with the extra axle gone. You can use a hacksaw, make sure to leave axle nut on while cutting.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Pretty standard to have that lip on the drive side of a bottom bracket. It’s what allows the unit to be threaded in to the correct depth and torqued down against the bottom bracket shell.
