Cut a quill stem?
Cut a quill stem?
Hi everybody
I want to lower my handlebars. The quill stem I have is very long and is for raising the bars. Is there any reason I cant cut a couple inches off? I know the cut needs to be precise for the expander/pinch bolt to work. I know the bolt itself will need cut or replaced. I realize the minimum insertion mark will not be correct. I'm just being cheap and impatient. I dont want to order/wait for a new one. Your thoughts or experiences?
bike is a 91' trek 1100
Stem is Nitto technomic
heres a few pics
heres a few pics
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...my thoughts are you can probably do this with that stem and get away with it. My experience suggests that to do it properly is a PIA , and that waiting for a new one is what I would do.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I would wait for a new one and sell the old one.
Likes For cyclist2000:
Quoted: 6193 Post(s)
Liked 4,809 Times
Go for it. It might convince you to buy another stem sooner. Which is what you should have done in the first place.
Quoted: 1944 Post(s)
Liked 2,164 Times
If the wall thickness is consistent and you have a shorter threaded bolt to fit the new length, then it should work. If not, you’ll end up with an usable stem and as already noted will be buying a newer one sooner.
I‘m thinking you might end up having to buy a shorter stem just to get the shorter bolt.
John
John
Likes For 70sSanO:
Yeah, I would wait for a replacement rather than cut it. Don't forget, if you're thinking of making it significantly shorter you will likely have to get a replacement expander bolt, or cut additional threads, which is a PIA no matter how you look at it.
I've done stupid and impetuous things with a hacksaw on some classic steel frames when I was younger. And that's a nice looking stem. Somebody out there will be very happy get it. Besides, unless you're determined to keep the 'classic' look, you could put on a quill adapter and then have access to easily changed out modern stems.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
John
John
Quoted: 283 Post(s)
Liked 262 Times
I'm usually a DIY type, but a trip to the ER due to a header from a failed stem would buy an armful of new stems. Co-op or old time bike shop might have a stem in a parts box that would work. 20mph impact with flesh, bones, concrete, trees, cars etc. is a priority of things to avoid.
Quoted: 2604 Post(s)
Liked 1,932 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
If the bolt threads are rolled, which is very likely, there will not be enough material to cut full threads. Unless you have a way to roll threads you will be stuck.
Likes For dsbrantjr:
Quoted: 645 Post(s)
Liked 797 Times
You're going to have to source a shorter stem bolt, 'cos I don't think you'll be able to bodge the one you have. Where are you going to get said bolt of the appropriate length? Riding with the bars too high for a few days won't kill you. Order the shorter stem and do it right.
Quoted: 4806 Post(s)
Liked 3,928 Times
I see no real issue with cutting it down. You need an accurate angled cut but you can get there simply by trying on the wedge and filing until it sits nicely. I"m guessing one of the fastener outfits make a suitable long bolt with a head that will work. No rocket science here. There are also thousands of old stems you can lift a shorter bolt from. Any bike coop.
That said, Nitto (and others) make lots of short quill stems of any quality level you want. There are tons of used ones out there. So why bother? (And who knows, you might age and want higher bars some day.)
Ben
Ben
John
John
Quoted: 325 Post(s)
Liked 109 Times
Stem Comparison Tool | yojimg.net
I just upgraded my wife's vintage road bike and that tool was very helpful in deciding on what length & reach quill stem she needed.
Thanks for the link. Thsts pretty neat.useing the comparison tool on my phone I dont have the minus button so i have to put the value in at 343 degree stem angle. Fun to play around with though. There was one similiar to that for handlebars I used a while ago. Whatbars.com I think it was. Sorry I dont know how to include links.
Quoted: 1528 Post(s)
Liked 718 Times
Ah, quill stems with ye olde single-bolt bar clamp are a pretty good reason not to be into vintage... swapping a stem can take more than 45 minutes instead of less than five.
I reckon if you're gonna use old steel (as opposed to hanging it on a wall), go the hotrod route; modernise everything but the frameset. Quill adapters suck, but there's a bloke on here (joejack?) who's made an awesome refinement to the concept by including the headset.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3887 Post(s)
Liked 6,482 Times
Likes For SurferRosa:
Liked 718 Times
If you consider 'obviously undercooked' a desirable aesthetic, sure.
This system was conceived in steel, remember. Ally quill stems are all flexy, unless you're talking 1.125 MTB, and 1" bars are flat out being securely clamped enough not to rotate when you jump a gutter with your hands on the hoods.
I reckon you'll enjoy life more if you decide to include a rule in your aesthetic criteria that if it works better, that means it looks better.
Quoted: 1104 Post(s)
Liked 1,825 Times
I'm lucky that my best friend is a machinist. He has milled down the length of several stems and quill adapters for me. That said they were all high quality, Nitto, Cinelli etc. You just have to make sure the milled angle is the same as the original and that new marks are made for minimum insertion based on the previous ones. Cutting the bolt and cleaning up the end is no big deal. On every one we did the wall thickness was measured and there was never a deviation.
