19mm tubeless tape for a 19mm internal width rim?
Quoted: 800 Post(s)
Liked 512 Times
This might seem like an obvious question, but a second opinion never hurt.
According to the specs on the web, my 44mm carbon wheels have a 19mm internal width.
I am looking to replace the tubeless tape.
Based on the 19mm internal width, does this mean I need to 19mm tubeless tape?
Thank you.
Thank you.
Quoted: 513 Post(s)
Liked 448 Times
Wide enough to cover the spoke holes and then a little more. When you inflate the tire the tape will "bubble" a bit at the spoke holes, and you don't want inflation pressure to pull any gaps. Conversely, never use tape so wide that it covers the inside of the rim from bead to bead. The tire bead must come in direct contact with the rim bead.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
