9 Speed Dura-Ace DT shifter question
Le Crocodile
Quoted: 368 Post(s)
Liked 781 Times
Right side 9 speed index I could install no problem. The left side shifter has a mechanical stop in the portion that butts against the frame.
In the forward most position, should it run parallel to DT, or stop in this slightly raised position? This is where it stops on the internal stop. If this is the correct method/position then it seems odd to me, but stranger things are correct.
There is also a helical internal spring that can be "wound" up for constant tension it seems?
Can somebody walk me through this shifter install? Thanks!
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
That's the way it's supposed to be... you'll learn to like it.
Likes For DiabloScott:
Quoted: 767 Post(s)
Liked 1,898 Times
Here is the link to the tech doc: SL-7700 Shifter Doc
The forward motion does stop before the lever can rest parallel to the downtube. The fixing bolt gets tightened just enough to keep the internal spring from pulling the lever back.
Likes For BFisher:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Slightly raised is correct.
Likes For BradH:
Le Crocodile
Quoted: 368 Post(s)
Liked 781 Times
I did install it correctly. Just seemed a little crazy!
Likes For BFisher:
Likes For krakhaus:
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
That’s a great color on the frame!
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, took me awhile to get accustomed to that oddity with DA downtube shifters after using Suntour and others that came to a stop in a more cosmetically appealing position.
Ditto, the paint on that bike. More pix, please. That subtle fade into a diamond, checked or snakeskin pattern looks great.
Nice motorcycles too. That one in the back against the bench looks like a friend's customized Yamaha SR500.
In yet another unforgivable slight to left-handers, the higher resting position for the left/front lever makes it easier for the right thumb to engage and move the lever. From the right side of the frame, natch. You don't have to rotate your right wrist nearly as much to engage the lever.
Bah, humbug! sez I.
Bah, humbug! sez I.
Fuggedaboutit!
Fuggedaboutit!
Not lost wanderer.
Quoted: 885 Post(s)
Liked 986 Times
I ran a flat bar shifter 10 speed with a DT front shifter and it frustrated me try to get it to be flat while in the small ring.
I finally found that info sheet above and realized it was made that way.
It was a fun bike to ride as I rode it like I had a high/low range.
This last one shows it laid forward almost parallel to the DT.
Likes For bwilli88:
Quoted: 23 Post(s)
I've never tried the DA shifters but if they work anything like my 6400 7s left shifters with the spring assist system, they are amazing.
Does anyone know if the current R400 8s front derailleur shifters have a similar design?
Catching Smallmouth
Quoted: 88 Post(s)
Liked 134 Times
The R400 shifters have spring assist on both front and rear shifters, however, they can't be switched to friction and the front shifter sits parallel with the down tube when in the small ring.
Quoted: 1607 Post(s)
Liked 2,213 Times
Same experience with the 8V DT DA on the Pinarello. Converted to Ergos.
