Mixing bar end and down tube shifters
Anyone mix bar end and down tube shifters on the same bike? I'm thinking rear derail. on the right bar end, and front derail. on the drop tube. This allows for a bar end mirror on the left side. Any thoughts? I hardly shift the front, so don't think it will be a big deal.
Thanks!
Thanks!
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
You could do that but I don't know why you would it will look odd. Lance had a downtube for the front shifter but he was also using heavy STI levers and was trying to lose a little weight from his bike since back then you actually had to work a little to get under the UCI minimum.
Quoted: 1591 Post(s)
Liked 1,018 Times
I don't see any reason this wouldn't be viable. I prefer DT to bar end myself, but if you like bar end this would allow you to keep the mirror.
BTW, the Italian Road Bike Mirror is by far the best bar end mirror I've tried.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I do this exact thing on my 520. FD shifts on the downtube, RD shifts on the barend. Barend mirror on the left side. I love the setup, and the FD shifts like a dream on the downtube. Doesn't look odd at all....go for it!
Likes For SalsaShark:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
While not a Bar end, it is a flat bar with a DT for the front
Quoted: 1104 Post(s)
Liked 1,825 Times
In the early days of STI, some racers used a DT shifter on the front to save weight and retain total control of FD cage trim. Hampsten was one, there was another guy but he turned out to be a fraud
Likes For nomadmax:
Clark W. Griswold
Liked 3,994 Times
It is hard to be a fraud when most of the rest of the peloton is also doing it. Yeah he was a jerk about it but I am going to give it to him, if everyone else is doping and he still "won" he had to have been better than everyone else even if they were all scumbag dopers. However I won't strong arm this thread into a different direction.
Likes For veganbikes:
Quoted: 18415 Post(s)
Liked 15,545 Times
Don’t forget the late Marco Pantani. At one point he used a DT shifter for the front. When I was at the ‘95 Giro, riding to the stage finish at the Bianchi factory, he came spinning by in the opposite direction. He was sitting out the race due to injury.
Likes For indyfabz:
Quoted: 2495 Post(s)
Liked 738 Times
Let me see if I have this right: buy both a set of DT shifters AND BE shifters, and use only the RH units of each type, so a LS BE mirror can be used? Is that not a bridge too far when the mirror can easily be mounted to a helmet?
Liked 738 Times
The barrel of a true 3x DT or BE shifter will be thicker than a 2x so that in the same 170* of total throw it will pull enough cable to get the FD across all three rings. A 3x shifter can also shift 2x but a 2x may only shift 2x. Obviously there are exceptions.
I don't think I've ever heard of a "triple-specific" front friction shifter. Some shifters back in the day literally didn't even have left-right variants, like the popular SunTour LD-1400 ratchets. Friction shifters nowadays generally spec as "2x/3x" or don't specify anything.
Liked 738 Times
to continue the thread drift, I have a 2x Shimano 600 front downtube shifter on my cross bike, and it does pull enough cable to shift a triple. in fact I have it mounted into the original bar-end shifter mount, on the handlebar end, and I prefer it to the original shifter.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Tragically Ignorant
Liked 9,098 Times
Likes For livedarklions:
Quoted: 4806 Post(s)
Liked 3,928 Times
Mirror choices are like chain lube choices. Don't go there.
Likes For 79pmooney:
Triples weren't invented in the 1980s, they've literally been around since the 19th century. Mass-production front derailleurs generally didn't have modern triple-specific cage shaping before the 1980s, but that's true of double front derailleurs as well: before then, people just used the same front shifters and derailleurs for 2x and 3x drivetrains, and it worked fine.
Likes For ClydeClydeson:
Tragically Ignorant
Liked 9,098 Times
I always love seeing setups I know I'd hate working for someone else, it's part of the charm of talking about bicycles.
I already have all these parts in my spare parts box, so I'm not really buying anything new.
