The Next Big Thing?
The Next Big Thing?
The following have all become big, with many but not all thinking they're desirable:
Electronic shifting
Wider tires
Deep wheels
Disc brakes
Power meters
Anything new or on the horizon that looks important? (Thinking of a new bike and want to make sure I at least am aware.)
Electronic shifting
Wider tires
Deep wheels
Disc brakes
Power meters
Quoted: 644 Post(s)
Liked 1,532 Times
The only thing I can think of that is available now would be completely hidden cabling/wiring or perhaps storage in the frame for spare tube, etc.
Likes For katsup:
Sunshine
Quoted: 11019 Post(s)
Liked 7,565 Times
Anytjong coming up that looks important? No.
Changes on the horizon?
- increased use of recyclable materials in packaging.
- a push towards lighter bikes since the last few years trended away from that.
- a push for cable routing that isnt the result of your bike engineer hating you.
- more threaded bbs.
Well I guess 1, 3, and 4 could be viewed as important in some ways. So sure- there is important stuff on the horizon.
What isnt important is 13sp Campy or making an ebike look even more like an analog bike.
Likes For mstateglfr:
Expired Member
Quoted: 3708 Post(s)
Liked 5,545 Times
Equally or more important than getting the next "improvement" is not getting stuck with something that is on it's way out. Press fit bottom brackets, QRs on disc bikes and tight tire clearance come to mind.
Quoted: 20810 Post(s)
Liked 9,456 Times
PF BBs don't bother me so much as long as there's enough room for a decent adapter (I think that Trek's outgoing BB90 was really the only one with too-narrow of a bore to accommodate).
And yeah, I want ~30mm tire clearance, but will take 28mm in a pinch.
Likes For WhyFi:
Quoted: 850 Post(s)
Liked 344 Times
I think that the industry has gone a bit hog-wild on the low pressure thing. ENVE, Zipp and even Giant don't recommend pressures above 5 bar or so. In the near future, tire and wheel technology will get good enough that hookless wheels will be able to support pressures that people actually want to run. I used to think I was on the ultra low end of the spectrum for running 55psi in 28mm tires at 135lbs. I'm not sure how 75psi is supposed to suffice for a 220lb dude running 25mm tires.
So once the tech catches up, the marketers will fire up again and tell us how running high pressures is actually faster in many cases, like when climbing out of the saddle or on smooth roads or for heavier riders. But people will have gotten used to the cushy rides + grip provided by fat tires and low pressure, so there will be a strong demand for bikes with some sort of suspension. We already see that happening with the roubaix, madone, domane etc. but I think it will go mainstream enough to dominate the WT.
I also predict that, if wide rims get popular enough, we will even see one or two radial ply tires. These tires will be optimized for those wide rims, just like motorcycle and car tires currently are. They will probably be more compliant, more efficient and grippier, but less durable. We'll probably see it in use at a WT TT. We've seen radials semi-recently, like the Schwalbe Ultremo R.1 and the Maxxis Radiale but those were made when everyone was using ultra skinny rims. I'd probably want something like a 28-29mm actual sized tire (so 25c marked) on 23mm (internal) rims.
I would go with something like the Domane (suspension, tire clearance, T47) with wide rims (the Bontrager Aeolus 3V is good). The integrated storage is also a good future-proof feature. Saddle bags are probably going to get unfashionable in the next couple of decades.
Likes For smashndash:
Likes For noodle soup:
Quoted: 850 Post(s)
Liked 344 Times
Fine. Even less fashionable due to the introduction and normalization of integrated storage? I personally hate carrying stuff in my pockets... not sure why so many roadies prefer that over using a saddle bag.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
That's what has been lost in the hype: the fact that bigger tires only have lower CRR than smaller tires when inflated to the same pressures. 25mm at 80 psi is slower than 25mm at 90 or 100 psi.
Quoted: 850 Post(s)
Liked 344 Times
My predictions aren't based entirely on objective reality. They're what I believe the industry will shove down our throats regardless of the truth.
Quoted: 18462 Post(s)
Liked 15,723 Times
Rim brakes.
Bikes: 2008 fetish illustre
Quoted: 10 Post(s)
Liked 8 Times
Electric bike technology.
Eventually they'll make it from the portly bikes currently out with 50 mile range to some featherlight that will do 200 miles on a charge. Just wait, it'll happen!
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Custom tailored 3D printed saddles will become reasonably priced and popular.
Quoted: 696 Post(s)
Liked 910 Times
Wavecell
Port
Quoted: 990 Post(s)
Liked 1,887 Times
Road tubeless.
Likes For Rocket-Sauce:
Quoted: 229 Post(s)
Liked 327 Times
I've never ridden a bike with less than 32 mm tires so "wide tires" isn't something new to me. But being new to road biking I really like good disc brakes and, especially, my power meter. Though I think both of these are minor compared to an e-bike. My wife and I can ride together now with each of us putting out the same relative effort. And nothing beats being able to do that.
Likes For guachi:
Sunshine
Liked 7,565 Times
Ugh, that would be absurd to see as commonplace. Whats scary is that while it sounds dumb, it is totally something that I could see happening because- well this industry of marginal gains and marketing hype is just that disconnected from reality.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Bike aware driverless cars should open up a lot more open road space to those cyclists too nervous to ride off the mup.
Liked 15,723 Times
Likes For indyfabz:
